Restoration of Miura 1021 | Page 12 | FerrariChat
Discussion in 'LamborghiniChat.com' started by alberto, Feb 5, 2012.
  1. 360C
    360C F1 World Champ
    It would be extremely expensive to tool up for a production volume of one.
    I looked into it when I wanted to replace my F50's perspex engine cover years ago. I thought Ferraris price was nuts until I looked into commissioning my own.
  2. alberto
    alberto Formula 3
    Aug 25, 2001
    2,404
    San Diego
    Alberto
    I agree. Each louver would have to be individually custom made, so this is out of the question in glass for sure, likely also for lexan or plexi as the labor component is the main cost driver.
    If you want a fun exercise, take the metal louvers off your Miura, don't label them, mix them up and then try to put them back on the car. Fun entertainment for hours will be yours.
  3. staatsof
    95,947
    Fuggetaboutitland
    Bob
    I think you should build your own wind tunnel ...
  4. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Now that is funny :D
    I do not have a solution for you then, other than to leave alone and just display with the bonnet open.
    Best
    Pete
  5. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    I do not have a solution for you then, other than to leave alone and just display with the bonnet open. You cannot really see the engine through the flat glass window anyway, add the cooling and fire issues ...
    Best
    Pete
  6. xs10shl
    xs10shl Formula 3
    Dec 17, 2003
    2,037
    San Francisco
    Some louvers I've seen are already stamped in order of position. Can't say who did the stampings, but they appeared to be the same type as the Bertone stamp. For example, car 600 would be stamped "600 1", "600 2", "600 3", etc.
  7. alberto
    alberto Formula 3
    Aug 25, 2001
    2,404
    San Diego
    Alberto
    Not sure why you would think that you can't see the engine through flat glass window. I think the prototype pictures show the engine fantastically.
    In any case, I'm too stubborn to give up that easily. :)
  8. alberto
    alberto Formula 3
    Aug 25, 2001
    2,404
    San Diego
    Alberto
    #286 alberto, Feb 3, 2013
    And here are the "after" pictures of the hardware and the carbs. They came out flawless. All of these were taken by Jeff Stephan, who did the work. The mechanism now works silky smooth. He had to replace 3 or 4 floats which had been damaged apparently as a result of blowing pressurized air into the carbs. Note the overstamp of the L on the carb serial number. That's an indicator that it is original to this very early Miura as they almost certainly took Porsche carbs and re-stamped them with the L for Lamborghini. Later carbs were actual stamped from new with the L.
    Alberto
  9. NürScud
    NürScud F1 Veteran
    Nov 3, 2012
    7,308
  10. unojung
    unojung Karting
    May 18, 2006
    112
    Copenhagen, Denmark
    Uno Junghans
    Do you know what was used to make the carburator housing look nice.
    I would guess some kind of "alodine" treatment?
  11. alberto
    alberto Formula 3
    Aug 25, 2001
    2,404
    San Diego
    Alberto
    I don't know what all is used to get the finish. There seems to be a lot of "art" to it to get it just right.
  12. Jota 5084
    Jota 5084 Formula 3
    May 18, 2006
    1,922
    Sweden
    Eric Andersson
    The last three carburator pics are really sexy looking :)
  13. vaholtorf
    vaholtorf Formula 3
    1,077
    Colorado
    Victor Holtorf
    Yes, it is so time consuming and expensive to get that look. Then, after a few hundred miles of driving and the associated heat cycles, that look is gone forever. Sadly, that is why cars restored to such a nice standard often don't get driven and rest in collections or museums.
  14. staatsof
    95,947
    Fuggetaboutitland
    Bob
    I restored my DCOEs like that just not that brown and it's held up just fine. I have had to re-plate the round jet covers though but the body finish is still perfect.
  15. Speedy2
    Speedy2 Karting
    Mar 4, 2007
    63
    Jeff has rebuilt my carbs twice in the past 10 years (once for the "color" treatment). Now after 3+ years of service since the second rebuild and color treatment , including several hundred miles and multiple heat cycles, they still look and perform perfect! Jeff does top notch work on Miuras. Although I don't know Alberto so I can't speak for him; I'm sure he would agree.
  16. unojung
    unojung Karting
    May 18, 2006
    112
    Copenhagen, Denmark
    Uno Junghans
    What did you use for making the body's look nice? Cleaner, nut shell or plastic blasting, ultrasonic cleaning?
    I know the DCOE's will always look different from the IDL/IDA's..
    They are supposedly not made of the same alloy.
  17. staatsof
    95,947
    Fuggetaboutitland
    Bob
    Mine had corrosion and in order to achieve a uniform look with something like Alodine (which I used) you need to bead blast them. I used glass beads and they were sealed up at any intrusion points so that no beads could get into the carbs themselves. The ultrasonic would be great for the interiors ahead of time. Mine just got the very old fashioned carb cleaner that still works. I don't think you can find now though.
  18. alberto
    alberto Formula 3
    Aug 25, 2001
    2,404
    San Diego
    Alberto
    Time will tell on how long the finish lasts, but I have every expectation that it will last for many years. Jeff does great work and he knows what he's doing. I don't have a "collection" or a museum. The level of finish on the car will have nothing to do with how much it will get driven, and after showing it in Monterey (or such), I intend to drive the hell out of it if I can.
  19. alberto
    alberto Formula 3
    Aug 25, 2001
    2,404
    San Diego
    Alberto
    To quote the Rain Man: "Definitely"
  20. thedoc
    thedoc Formula 3
    May 27, 2009
    2,159
    The sickest and most demented thing about your comments is that the car guys reading it understand exactly what you mean! LOL
    Gary
    Espada
    8394
  21. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    Jeff has refurbished carbs for me too, and I think you'll find that (unlike some restorers) his work & finished product has benefited with time & practice. Plus, he is a pleasure to deal with, and a serious Miura enthusiast.
  22. unojung
    unojung Karting
    May 18, 2006
    112
    Copenhagen, Denmark
    Uno Junghans
    Do you remember what type of Alodine you used? I seem to remember that it exist in different color tones.
    I'm getting ready to redo my Espada carbs as well.
