Restoration Question ..... | FerrariChat
Discussion in '206/246' started by ajmarton, Jan 19, 2007.
  1. ajmarton
    ajmarton Formula Junior
    May 3, 2004
    305
    Los Angeles
    #1 ajmarton, Jan 19, 2007
    This is somewhat off subject as it concerns my 81 928, but I know of no other forum with so many experienced restorers so I figured I would post my Q here. I have the dash and center out of the car and want to bring the ignition lock back to its original glory - which is a black finish. I tried spray painting it (with etching primer) and that did not seem like a durable finish as the key chips the edge of the ignition key slot when you insert it into mechanism. I don't want to remove the ignition assembly - so with that limitation in mind - does anyone have suggestions on how best to re-finish it? I attached a picture. Thx, Andrew
  2. Argento839
    Argento839 F1 Veteran
    Oct 21, 2005
    9,103
    Without wanting to remove it, you are limted to painting it really... I am sure there is some really durable paint you could find out there... If you want to go through the trouble to remove it, you could have it powdercoated and that would really hold up well. Good luck.
  3. ROLOcr
    ROLOcr Formula Junior
    Oct 25, 2005
    619
    Costa Rica
    ROLO
    i know this is not the rigth way but i sometimes use black muffler paint or even engine enamel which has turned out to be a quick fix, you can even try one of those not-so-thick roll on bed liner paints, it will dry to be a very hard finish and maybe it will work,
  4. John Corbani
    John Corbani Formula 3
    Honorary Owner
    May 5, 2005
    1,153
    Santa Barbara, CA
    John Corbani
    Try epoxy appliance touch-up paint. Stuff is very hard after a couple of days of cure. Sticks to bare metal pretty good. Just clean and rough up a little. Scotch Brite works well.
  5. CliffDonnon
    CliffDonnon Karting
    Jan 28, 2006
    71
    I use POR15 very , very tough,
    Cliff Donnon,
    Australia
  6. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,067
    Seattle, WA
    Keith Mitchell Wintraub
    Try Sherwin Williams Polane. 2 part epoxy paint - amazing stuff.
  7. ajmarton
    May 3, 2004
    305
    Los Angeles
    Thanks guys. I will give the epoxy paint a try.
  8. dinogts
    dinogts Formula 3
    Keith -
    What have you used the Polane on?
    Mark
