Restoring 308 Bumpers | Page 2 | FerrariChat
Discussion in '308/328' started by scuderiatc, Jun 7, 2006.
  1. BigTex
    Dec 6, 2002
    79,268
    Houston, Texas
    Bubba
    It'll have missing sections of the top bar, and IIRC the vertical bars offset as well.....not pretty...
  2. tvine
    tvine Formula Junior
    Jul 19, 2006
    270
    Cadillac, Michigan
    Tom Vine
    Reply to US Grill with Euro bumper.
    It was awful. I didn't bother taking pictures. Overall there is a gap at the top and there are two larger gaps where the US bumper bulges down. Two of the vertical bars also take a weird bend. You might be able to make it look good by adding driving lights in the gaps, but that seems a bit gosh for a Ferrari.
  3. BigTex
    Dec 6, 2002
    79,268
    Houston, Texas
    Bubba
    The front US bumper is a different profile part......the sections that "drop down" were an attempt to avoid "override" in a collision IMO......so the lower grill shape is to avoid that feature......
    You'd want a euro grill, to look proper......
  4. ClydeM
    ClydeM F1 World Champ
    11,257
    Wayne, NJ
    Clyde E. McMurdy
    Me three.
    Viva la bumper Americana!
    If you want, I have two bumper shocks that have been compressed via parking lot taps that are yours for the cost of shipping...about $20.
  5. dave80gtsi
    dave80gtsi Formula 3
    1,845
    Ohio
    Dave Meredith
    I've posted this link here in the past, but a whack of pictures showing the Euro bumper and front grille conversion of a USA spec car are on my website at:
    http://groups.msn.com/ferrari308gtsi
    And, while you are at it, install a Euro spoiler, too.
    Cheers - DM
  6. tvine
    Jul 19, 2006
    270
    Cadillac, Michigan
    Tom Vine
    Dave80GTSi,
    Did you do the Euro rear bumper? If yes, what did you do about the heat?
    79 and 80 must be different. The Euro front bumper had nowhere near the same bolt spacing as my US bumper. I needed to fabricate new brackets. Additionally, the mounting shocks weigh almost as much as the bumper. They are overkill to mount a piece of plastic that can barely stop bugs.
    IMHO the Euro bumpers are integrated into the design much better that the US versions. Also, getting rid of all of that weight at the ends of the car had a significant impact on handling near its limits, especially in how the car responds to changes in throttle position in the center of a turn.
  7. johnb@macarbon
    johnb@macarbon Formula Junior
    Feb 24, 2004
    809
    SF Bay Area
    John Borchelt
    #32 johnb@macarbon, Sep 12, 2006
    Hi Guys,
    We, MAcarbon, are the company that sells the brackets to pull in the front bumper. They are high strength aluminum tube that we then powder coat satin black. It's actually easier to replace the struts than to drill them. Plus, you'll have your OEM stock struts if you sell the car. As for protection in an accident, these are rigid brackets so as we say in the aftermarket industry "for off road use only". (But how much are 25 year old struts really going to help in an accident?) They pull the bumper in the maximum amount without actually modifying the bumper or your car - it is fully reversible. They'll fit all years of 308. Attached is a photo comparing the "before" and "after". (On different cars of course.)
    Although you won't save much weight, you'll get the Euro look for 1/10 the total cost of going the full Euro route. Cost is $125/set. PM me or give us a call or email if you'd like a set.
    John Borchelt
    MAcarbon
  8. gil308
    gil308 Formula 3
    Jun 22, 2004
    1,975
    Charleston, SC
    Gil
    I guess there are 3 of us...the first 308 I ever saw was the US version around 1980...I much prefer the US bumpers to the Euro. I also like the exhaust grate on the back...anyway, I know this has nothing to do with the thread, but Doc and Bird...I'd like to join the P3B club ;)
  9. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    I bought those brackets. Have not installed them yet, waiting on my Euro Spoiler and will put them both on in the winter.
  10. YellowbirdRS
    YellowbirdRS Formula 3
    Nov 9, 2005
    1,765
    DFW/RGV/MX
    Xavier
    ok wher can I get one plug & play euro bumper for an american 308?
  11. dave80gtsi
    1,845
    Ohio
    Dave Meredith
    Butch Hooper in Arizona has the bolt-on fiberglass front bumper which I used (see my post with picture link about 6 spaces up). Direct fit onto the OEM front bumper shocks, see web link for pictures for all of the mounting details.
    I still have my OEM USA rear bumper, as I wanted the 'bump' protection back there.
    If I hit someone with the fiberglass front bumper ... shame on me, I had it coming.
    If I am hit on my OEM rear bumper .. shame on them!
    Cheers - DM
  12. RJay
    RJay Formula Junior
    Jun 26, 2004
    261
    Colorado
    Bob
    #37 RJay, Sep 12, 2006
    I think this qualifies based on the original posting. I’m taking a chance here so go easy on me. I know it is not show quality but I didn’t want to lay down the 2K for a new bumper and I wanted to see if I could make this passable. I have a U.S. spec bumper but the right turn signal had lots of corrosion due to a leak of sorts. This caused the bubbling seen in the “before” picture. It was causing the rubber to deform and sag by over ½” and generally, looked pretty bad. The bumper is overmolded rubber on steel. The steel frame is hollow (I had to drill it). I don’t think that glue of any type will help because the material wants to deform and would be under tension after gluing it and nothing will stick to it very well. Anyway, the bumper was removed and the lights too. It was then hung up where I took a rubber mallet and beat on it to get all the loose corrosion out (This took a while – making sure not to cause damage – that rubber is pretty tough). Naval Jelly was injected onto the exposed frame to remove the rest. The Naval Jelly was rinsed out and a rust protector was sprayed on the bare metal. This gets all the loose pieces that are causing the rubber to deform, out of the way. The bumper was then secured and strips of duct tape were used to secure the rubber into position. 5 holes were drilled from the rear, through the steel, to the front. 5 rustproof long (3”) deck screws were put into the rear of the bumper. The screws penetrated through the steel (providing the support) and then into the front rubber lip just below the light (this is the part that was sagging) but not enough to poke through (real important here). When the clamps were removed, the rubber no longer sagged. Basically, the lower lip was now “hanging” (quite securely) from the five screws retained in the steel. The light and bumper were reinstalled. From a few feet, it is hardly noticeable and worlds better than it was. This may not work for everyone, but it worked o.k. in this case. I am sorry that I don't have a broader shot of the before and after but it really did make a nice difference.
    -Rjay
  13. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    No offense, but that's just not true. Without debating the idea of saving the original bumper shocks, it only takes about 5 minutes to drill the two front shocks and use a rubber mallet to push in the bumper. No way you are going to do a remove-and-replace more easily or more quickly than that, and it's zero cost.
  14. CurtEgerer
    CurtEgerer Rookie
    Aug 7, 2005
    47
    Michigan
    The MAcarbon solution looks very good!
  15. Jdubbya
    Jdubbya The $10 Trillion Man
    39,288
    PNW
    I agree! It took me longer to set up the drill and pound the bumpers in than to actually drill them. Also not true is that the 25 year old shocks wouldn't provide much protection. All four of mine were still very full of gas!
    Sorry to the US bumper fan contingency but I like the look with it pushed in. Like someone said, beauty is in the eye of the beerholder....uh I mean beholder.
  16. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    #41 rolindsay, Sep 13, 2006
    '79 308GTB fully Standard Specification
  17. YellowbirdRS
    Nov 9, 2005
    1,765
    DFW/RGV/MX
    Xavier
    thanks!
    do you know his email, web site or maybe his phone??
  18. JTranfield
    JTranfield Formula Junior
    Dec 29, 2003
    665
    NYC, London
    J Tranfield
    #43 JTranfield, Sep 13, 2006
  19. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    VERY NICE! The bumpers look just like the ones on my standard spec. '79 gtb (see photo earlier in this thread). I love the blue color.
  20. tvine
    Jul 19, 2006
    270
    Cadillac, Michigan
    Tom Vine
    Jtranfield,
    Where did you get the Euro style lower rear valance? Do you have any heat issues on the rear bumper?
  21. tvine
    Jul 19, 2006
    270
    Cadillac, Michigan
    Tom Vine
    #46 tvine, Sep 14, 2006
  22. JTranfield
    Dec 29, 2003
    665
    NYC, London
    J Tranfield
    No heat issues at all and I have a Tubi exhaust.
    I think its the original 1977 rear valance on this US spec car. Didn't they change in 78?
  23. tvine
    Jul 19, 2006
    270
    Cadillac, Michigan
    Tom Vine
    Sorry, I am not that familiar with the 77 308. Does your valance just go across under the bumper or does it go up behind it?
  24. thecarreaper
    thecarreaper F1 World Champ
    17,679
    Savannah
    #49 thecarreaper, Sep 14, 2006
    yes, that is the correct rear valance for a 77 .... me thinks i need a euro front bumper....
  25. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Hey Guys,
    I figured i bring this thread up again.
    I read all 3 pages but it seems it drifted away from the subject. :)
    Can the bumper be repainted to give it that fresh shiny look and if yes what color do you think it is.
    Or do i put good ol Armor all on it?
    The bumber is in good shape, smooth, no rust or bubbles.
