Restringing Ferrari 308GTB 1979 Window Cable | FerrariChat
Discussion in 'Technical Q&A' started by Floradora, Jun 17, 2019.
  1. Floradora
    Floradora Rookie
    Jun 17, 2019
    1
    Rome, Italy
    Ruth Duncan
    I am restoring a 308GTB, nearly finished, but I cannot figure out the stringing of the cable around the window motor gear wheel. Does one part of the cable go in a clockwise direction with the other part going counter clockwise? (As the gear wheel has '6 grooves' do I feed one part of the cable clockwise in 3 grooves and the other part counter clockwise in the remaining 3 grooves?).
    Would appreciate any feedback.
  2. dflett
    dflett Formula 3
    1,632
    NY
    David
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    You can skip the window accelerators if you replace the grease.
    waymar likes this.
  4. DonB
    DonB Formula Junior
    626
    Florida
    Don Bartz
    The diagram is in the parts manual. Also, I found on my '79 GTB that there was NO dedicated ground wire from the door to the chassis. The door hinges were the only ground connections and they.re not designed to be a ground!
    As 2NA posted, replace the grease in the window motor (mine was concrete) with normal white grease, install grounding wires to the chassis, and you'll find your windows work pretty darned good!
