Resurecting a '75 308GT4 - won't start | FerrariChat
Discussion in '308/328' started by sltillim, Nov 22, 2009.
  1. sltillim
    sltillim Formula 3
    1,696
    San Diego
    Hello FChat,
    I just pulled a GT4 out of the woods yesterday. Belongs to my dad he handed me the keys since it has been sitting covered for nearly 4 years at his house in the redwoods - I'm lucky but have my work cut out for me. He has owned it since 1977. Mouse feces is everywhere and there were a couple of nests built up next to the ignition and in the glove. I even heard something scurrying about in pasenger door rocker panel - I hope it escaped on its own. Paint is OK with a couple of cracks. Had it towed down to my place.
    We attempted to jump the car to get it up my very short driveway into the garage but it did not not even light up the interior so there is a major wire loose. I got a couple of day workers to help push it in.
    The car worked and ran for many years. I am planning on doing the work on my own and with a friend who owns a shop. I have the service manual.
    Step 1. Clean out the interior
    Step 2. find the electrical problem preventing the lights from coming on. then look to see if it brings power to the ignition.
    It started before but who knows what rodents have been up to (aside for crapping all over the place)?
    Any suggestions ?
    Thanks,
    Spencer
  2. tommott77
    tommott77 Formula Junior
    Feb 1, 2009
    652
    NC
    Tom
    If it were my car the first thing I would do is go through the fuel lines. These things have a propensity to go ablaze. And then I would change all the belts/filters for piece of mind. Unfortunately and then could go on for a real long time ;-)
  3. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    Starting this thing should be a long way down the priority list.
    Take the plugs out & rotate the motor by hand. If it's all moving OK then don't even think about starting it till you've changed the belts & bearings. It entirely possible that a cambelt could break just from starting it & then the motor is "lunched"
    As above, also change the fuel lines before you start it.
    If it has any gas in it you need to drain it & get rid of it - it will be stale. Change the oil too.
    But before everything you obviously need to find out if the car can be salvaged & what damage those "Meeces" have done to it.
  4. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    ah, come on, live a little....hook er up to the battery charger, squirt some starting fluid in there and see what happens!
  5. DGS
    DGS Seven Time F1 World Champ
    71,892
    MidTN
    DGS
    He said 308GT4, not "Celica GT4". ;)
  6. TheMayor
    106,137
    Vegas baby
    One of my biggest concerns is if the mice ate the wiring. If they did, it could be a nightmare to sort out under the dash.
    http://www.macroevolution.net/what-do-rats-eat.html
    "Rats eat huge quantities of food stored for humans and livestock and they contaminate far more than they eat. They also gnaw the insulation of electrical wiring, which can cause fires. In the U.S. alone damage and losses attributed to rats total approximately $ 1 billion a year."
  7. sltillim
    sltillim Formula 3
    1,696
    San Diego
    Does anybody make wiring harnesses for these. I could start fresh or I could be looking forever! Maybe it is better off to save all the looking time, rip and replace?
    Thank you for the advice everybody1!
  8. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    Congratulations on your GT4. How about some pictures!
    You might want to read this thread about a Barn Find 348. Very fun reading but it might give you some cause for concern (although obviously two completely different cars).
    http://www.ferrarichat.com/forum/showthread.php?t=250500
    Dave
  9. samba-lee
    samba-lee Formula Junior
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
    Yeah, did you take some pictures of the extraction from the woods! they would be interesting - not many dusty barn finds left I imagine.
    As much as it's tempting to start a dormant car (and I've done it on cheap ones) consider the rebuild cost/time if a belt gives. Don't break the motor - you'll really regret it, although I like Cliffbeers enthusiasm :)
    I'd pull the belt covers and check the belts out first then as suggested consider turning over by hand. You can get all kinds of stuff collect on the bottom drive pulley between the belt and the pulley - if you suck that stuff round the pulley it can easily jump/snap a belt. New belts are less less than $30 for a pair - it'll take you a few hours to swap them, and you'll be happy that it's all good in there.
    Lee
  10. Ak Jim
    Ak Jim F1 Veteran
    9,621
    North Pole AK
    Since you are essentially getting the car for "free" I would pull the engine and take it apart. As mentioned all belts, fluids, and hoses need to be changed. Most likely the carbs will need a rebuild also. Spend the money now and get the car up to 100%. Just my opinion. When if you spend 15-20k on it now that is cheap since you had no initial purchas price.
  11. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,025
    I would vote for giving it some love before proceeding. All fluids, some dissassembly to service belts and hoses, inspect wiring at a minimum, clean-clean-clean. You'll get much farther down the road and be much happier.
    Make sure fuel lines are safe!!! I know of a beautiful GT4 that was stored in a nice garage to have a fire after awaking from a long nap. Also, my GT4 was stored for a while, and kept very clean. Upon starting, I checked the running engine and noticed a pinhole stream of gas coming from one of the carb connector lines. The stupid fuelline wasn't that old! It just had a defect that showed up after sitting. I didn't see any mouse activity.
    It will be great to see your car return to its former glory.
  12. 208 GT4
    208 GT4 Formula 3
    Dec 27, 2003
    1,769
    Brighton (UK)
    Dan
    A lot depends on how long it's been sat unused? I'd first find out if there was an existing problem that caused it to be taken off the road.
    If you've got time and money to spare, then a major check of the engine is in order. If it was me (no spare time or money!) then I would at least check the oil, fuel lines and the state of the belts. The electrical problem could be anything from a single loose/corroded connection to a complete loom replacement needed. It's worth pointing out that the electrical system is pretty basic compared to a modern car, so it shouldn't be too difficult to get going if you can get the fuel pump running, the engine turning over and the plugs sparking.
  13. sltillim
    sltillim Formula 3
    1,696
    San Diego
    You guys all kick but! Thank you! I will get some pics up right away. As much as I would love to turn the key and go you are all right. I have to do the belts and fluids first and give it a good tuning. I know we replaced the starter a few years ago before letting it go.
    I want to hear it so badly! It really is the favorite sound of my youth! We had a number of cool rides:
    275GTB/4A
    1966 206SP SN#002 Car number 196
    512 Boxer
    Daytona
    400i
    borrowed 250 California SWB for '94 National meet
    amongst other Lotus's, classics and vintage race cars.
    This one was there while others came and went. I love this car so much! I grew up in the FOC and the FCA knowing I would always be a part of these cars and I want to drive it! I think eventually I would like to modernize it a bit with new ignition, coil overs and maybe some engine tuning but I have a lot of time to get it right.
    Pics are on the way before I clean it up.
    Spencer
  14. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,025
    I've owned my GT4 for over 23 years. It runs great. Handles fantastic. The only non-original thing I deal with is tires. The rest works very well as is. When I first got it, new distrib caps were 40 - 65$ each. My car buddies thought that was a fortune and I should investigate retrofits of american caps etc. I freshened it all up with a thorough service when I got it and maintained it in stock form and it has all lasted quite nicely. The performance is still magical to me. I agree the newer stuff is "better". Distributorless ignition, sophisticated fuel injection etc, but just my opinion based on long term ownership is try it in its pure form and see what you think.
    Best of luck & Post some pix! :)
    PS: You really have owned some wayyyy cool rides! :)
  15. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I just want to add my .02 to the fuel lines. My GT4 was dormant for many years before the PO sold it to me. I drove it home on the ancient belts and I had to get gas for the drive home but I couldn't get the pump to stay on. Screw it, I only filled it half way. Twice. That probably saved my bacon. When I got it home I actually filled the tank(s). It scared the crap out of me. There was an old cloth covered fuel hose connected to the tops of the tanks soaked with gasoline right over the front header.
    (I would offer help since I am also in the Bay Area, but I am already behind. I promised another GT4 owner I would help with brakes months ago and I have not. Where are you?)
  16. andy2175m4@yahoo.com
    [email protected] Formula Junior
    Dec 7, 2008
    473
    Los Angeles, CA
    Andy Rein
    #16 [email protected], Nov 24, 2009
    I have been working on engines for almost 40 years, and found that the 308 is one of the most challenging projects I have ever taken on.
    Do not take it lightly. It is a most unusual animal, in that it is an "interference" engine, if the cams are not timed perfectly, the pistons will hit the valves and you will wreck the engine. If you are not familiar with this type of engine (it's rare among common american and japanese cars) do your homework or you will ruin it.
    The rest of the car is pretty normal, but the engine is definitely different.
    The learning curve on a 308 is steep. Study the manual (available free on line) and take your time.
  17. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,565
    San Carlos, CA
    Mitchell Le
    I am in the Bay Area. I have a decent amount of Ferrari tools and used to work on my GT4 all the time (maybe that is not so good!). I may be able to help you if you need something specific. My Gt4 is now gone, but there are things about it I still miss. Not enough to spring for another one, but ... they are still fun.
  18. BigTex
    79,380
    Houston, Texas
    Bubba
    The mice living in one of mine preferred the fuel lines, to the electrical wiring..
    Which was a GOOD thing actually....
    Post of some pics of your find, and get the inner fenders out to start inspecting the fuel system..
  19. sltillim
    sltillim Formula 3
    1,696
    San Diego
    I'm in the Redwood City Hills / Emerald Hills neighborhood and it looks like you are probably just next door. I might have to take you up on that offer!
    I spent the night charging the battery..... NOTHING! I have never hated rodents more. Now I have to dive into the electrical. I will start with the battery and work my way back. to the fuse box.
    Picutres on the way! I just haven't had time to upload any yet.
  20. Mike Florio
    Mike Florio Formula Junior
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    Check for Private Message.
  21. BigTex
    79,380
    Houston, Texas
    Bubba
    Probably Step 1 would be a new battery...
    But you have a lot of folks here warning you not to 'crank it' without checking a few things over....
    coolant and all oils should be drained and renewd, most likely the carbs are trashed with varnish.
  22. dinogt4guy
    dinogt4guy F1 Rookie
    Oct 31, 2004
    3,411
    Hewitt, Tx.
    Kurtis Fordice
    I allways thought it was a good idea to pull the plugs and give a squirt of marvel mystery oil in the hole and slowly crank it over a few times to make sure things are free'd up. Is this still a good idea? Congrats on the car, we will be anxously waiting for reports on your progress.
    Cheers!
  23. Jay GT4
    Jay GT4 F1 Rookie
    Oct 16, 2001
    4,995
    La mamma dei fessi
    e sempre incinta
  24. BigTex
    79,380
    Houston, Texas
    Bubba
    Absolutely, I believe in that stuff too!!
    Then dump in some Royal Purple! LOL!
  25. Mike Florio
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    I've known Spencer for 25 years, since he was a little kid. Back then his Dad, a neurosurgeon had a beautiful 275. Spencer, his Mom and Sister were very much a part of the Ferrari Club back in the 80's and 90's. Really nice folks.
    I sent him a PM with all my advice, then realized there may be others who could benefit from my thoughts, so here goes:
    I still have my GT/4. My son and I just completed a belt change/valve adjust and I'm now in the process of replacing the fuse blocks and some electrical upgrades. Andy lives in San Francisco and is a professional mechanic working for PG&E. He went to school and got his FAA Airframe and Powerplant certifications (probably the best mechanic training there is). I've been training him to work on the Ferrari, and he'll get it in great shape, not out of the woods. I'll be seeing him on Thursday and will ask him if he can help you. He's very knowledgeable and could survey the amount of work you will need to do.
    I'll go through my receipts and send you another email with sources for all the parts you will need. You should be able to do this for around $2000 including new tires.
    Be very careful with the mechanics you let work on the car. An old hand once told me "more Ferraris have been worked over than worked on." This forum is a good source of information, learn to use the search facility - it will be your best friend.
    First of all, don't even think about turning over the motor yet.
    Split the project into systems - use the shop manual as a guide.
    1) First remove the seats and carpets, then the front center console section. Clean the seats with saddle soap and then treat them with Leatherique Rejuvinator - several applications. Let them sit while you do the other work, which will improve your access to the electricals.
    2) Electrical. Get a new battery and charger. The fuses are in the glovebox. The relays are under the footwell in the passenger compartment. You should probably consider changing the fuse holders, those old fashion Italian fuses are extremely unreliable. There is a guy on this board selling replacement fuseboxes using AGC (glass tube) for $140. I used modern spade fuses and got the fuseblocks for under $20. Contact me if you want that info.
    Go through each circuit and fix it if it doesn't work.
    3) Brakes. You will have to bleed the brakes to get the old fluid out. Think about blowing them out with nitrogen. Remove each caliper and dump out the old fluid. Make sure the piston moves in each caliper. You may have to rebuild one or more. Reassemble, refill and check for leaks. Especially check the rubber hoses connecting the steel lines to the calipers. Any sign of rot- replace them.
    Repack the front wheel bearings.
    4) Cooling system. drain, flush and check for leaks. You should consider replacing the 13 rubber connectors - Use Gates Green Stripe hose and new Stainless Steel clamps.
    Replace the thermostat and gaskets. Remove and clean the crud out of the overflow tank. I have a source for a new Stant radiator cap for under $10. Replace the hoses.
    Consider getting the radiator "rodded" out. Don't even think of using a chemical flush or, God Forbid! a Stop Leak.
    5) Fuel system. Remove the fuel pump and fuel filter, take the bottom off the pump and clean it out. Clean the filter housing and replace the filter. Bench test the pump.
    You really should replace all the fuel lines. There are two sizes. I prefer BMW fuel line. You can get it at the BMW dealer in the correct mm sizes. It is the best fuel line available.
    The carbs will probably need to be rebuilt. Kits are available - watch out for the ball bearings. There are lots of postings on this site regarding the procedure.
    6) Now the engine. Blow out the holes before you remove the sparkplugs. Put a rag in each hole.
    Drain the oil and refill with some autoparts-store brand 10W30 synthetic oil (its cheaper than name brands and you will be discarding it soon). Remove the valve covers and replace the rags into the plug holes in the head.
    Fill up a Catsup squeeze bottle (Clean out the catsup first) with your el-cheapo oil. Squirt about 2cc into each cylinder hole. Liberally squirt some fresh oil on the cam lobes and bucket tappets. Manually turn the engine to TDC as indicated on the flywheel as PM. (Turn the engine clockwise when viewed from the passenger side wheel well). Make sure the cam lobes are pointing away from the tappet on cylinder 1, if not rotate the engine one more time. You will need a 32mm socket on the front of the crankshaft for this. I can lend you mine.
    Replace the cam belts and tensioner bearings. YOU MUST DO THIS, or risk a $10,000 engine rebuild. Lots of postings on this Andy or I can help you with this.
    Replace the cam covers and install new sparkplugs.
    7) Distributors. These are complex, and will need to be rebuilt. I have become an expert on the way these things work, and I even bought and rebuilt a distributor machine, which is the only way to set them up. After my car sat for a couple of years (long story) and Andy and I pretty much did all the stuff listed above) the car started on the first rotation. Even Andy was amazed. Box up your distributors and send them up to me. I will rebuild them and set them up for you.
    8) Put everything back together and have a good drive. Change out the cheapo oil and put in some good 20W40 Synthetic (I use Castrol Syntex). I would recommend some ZDDP Plus, which is the modern version of the Molykote the shop manual mentions.
    9)Fix all the rest of the stuff you missed the first time through.
    You will probably be working on this car for a year or more, and will continue to find problems for some time, but that is part of the fun.
    Call me if you need any help or a shoulder to cry on. Say Hi to your family for me.
