Retracting brake pistons on 308 | FerrariChat
Discussion in 'Technical Q&A' started by chris marsh, May 13, 2006.
  1. chris marsh
    chris marsh F1 Veteran
    5,758
    Detroit
    Chris Marsh
    I did a number of searches and was suprised I couldn't find anything.
    What is the procedure to retarct caliper pistons on 308 ('83 euro GTS)?
  2. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
  3. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,808
    Cerritos, CA.
    For the Front, 1st: lossen the cap of the brk.fluid reservoir, then 2nd. after you pull out the caliper remove only one pad leaving the one thats on the piston side on, 3rd: using a brake piston retractor or a medium size C-clamp, turn the retractor or the C-clamp in (clockwise) untill it stop, as doing this the piston will retract back in and pushes the fluid back up to the reservoir.
  4. jaydens1
    jaydens1 Rookie
    May 17, 2006
    33
    new zealand
    tony j downes
    try this /use a brake clamp,clamp caliper line.fit correct size SIX sided spanner over bleeder. connect bleeder hose /crack bleeder.remove 1x pad .retract pistons as above .go slowly as air can be trapped under boots and detach.fit one pad at a time.check new pads for sharp burrs on the metal backing.deburr if necessary.clean residue or dust out of caliper area where the pads slide in(brakekleen /toothbrush).this method stops residue in the lines or calipers finding there way into master cylinders .abs systems definitely do not compress old fluid through the lines .while your at it bleed the brakes they will thank you for it.suck the old fluid out with a hydrometer($2.00).add fresh fluid and bleed as you go round.(FAR WHEEL/CLAMP /RETRACT/1X PAD AT A TIME/ASSEMBLE/BLEED BY HAND /SMALL REGULAR MOVEMENTS LIKE BRAKING TRAVEL NO MORE THAN 2 INCHES. GOOD LUCK Tony
  5. chris marsh
    5,758
    Detroit
    Chris Marsh
    As it turned out...rear pads are retracted with the adjusting screws. (I assume the reason for these adjusting screws is to set clearance for the parking brake.) Front pistons pushed right in with a screwdriver.
    I've replaced the fluid in the entire system. Have bedded in the pads and now I will re-adjust the parking brake.
  6. jaydens1
    jaydens1 Rookie
    May 17, 2006
    33
    new zealand
    tony j downes
    Good work .You did clamp the lines anyway A. Tony
  7. chris marsh
    5,758
    Detroit
    Chris Marsh
    no I did not clamp caliper line????
    first I've heard of this. some other posts suggested loosening or removing master cylinder cap to release fluid and to be careful it did not damage paint...
