Retro fit of Heated seats on a F430 | FerrariChat
Discussion in '360/430' started by J3 GME, Jun 11, 2019.
  1. J3 GME
    J3 GME Rookie
    Jan 9, 2018
    18
    U.K. Yorkshire
    Chris
    As the title says, had a go at fitting heated seats to the F430, trying to keep it looking like factory fit.
    This was difficult as the side seat trim which houses the heated seat switch/wheel was an impossible trim to find. However I found some standard trim( not wanting to butcher my original ones) which I had a go at altering to house the switches
    Side trims
    Image Unavailable, Please Login 3 Image Unavailable, Please Login
    found some leather from a local car trimmers the same colour (lucky!)
    Pleased with the result easy to wire into the fuse box behind the seats .
  2. ScudMarks
    ScudMarks Formula Junior
    Jan 22, 2018
    330
    Bay Area, CA
    Matthew Mauer
  3. JoeTSI
    JoeTSI Formula 3
    1,433
    Huntsville, AL
    Joe K.
    Wow, that's amazing and some serious skill on your part!
  4. MJGinTX
    MJGinTX Karting
    Mar 30, 2019
    161
    Indianapolis, IN
    Beautifully done!! Love the attention to detail. :)
    pilotoCS likes this.
  5. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Wow, great job!
    Thanks for sharing!
    Dan
    Sent from my SM-G950U using Tapatalk
  6. vv23
    vv23 Formula Junior
    Jan 8, 2009
    259
    Edmonton, Alberta
    V V
    Nice.
    How did you separate the seat pads? My passenger one rattles on the back rest
  7. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Can you kindly share how to properly remove the leather seat covers?
    Which seat heating kit did you use?
    Where did you tap power from?
    Thanks in advance.
    Dan
  8. I'm 360 Canuck
    I'm 360 Canuck Formula 3
    Nov 21, 2015
    1,911
    Ontario, The Real One in Canada
    Lars!
    Looks nice, but heat in the cockpit has never been an issue for me driving from May to November. Your next project should be seat coolers. ;)
  9. J3 GME
    J3 GME Rookie
    Jan 9, 2018
    18
    U.K. Yorkshire
    Chris
    The back pad is attached to the top of the seat frame ( shoulder high) with metal rings or cable ties, and the bottom part clips to the rear back of the seat
    The picture below shows the front pad .....it shows a long black strip which is the same as the back pad, the long black strip folds in to another one "like a male and female joint" one over lapping the other
    The base pad is Velcroed to the base of the seat so a good pull and it will come off its, then just attached at the front with a long black clip (see the pic above)
    The leather itself is stapled to the foam.
    whatheheck likes this.
  10. J3 GME
    J3 GME Rookie
    Jan 9, 2018
    18
    U.K. Yorkshire
    Chris
    Flyingbrick242 and whatheheck like this.
