Reusing Timing Belt | Page 3 | FerrariChat
Reusing Timing Belt
Discussion in '308/328' started by absostone, May 29, 2018.
  1. afterburner
    afterburner F1 Rookie
    3,499
    Switzerland
    Urs STEMMLER
    Doesn't that happen every time you hit the throttle? Check those belts move around during engine load changes....
  2. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,523
    Canada
    Newman
    yep
  3. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,277
    CT
    John Kreskovsky
    #53 johnk..., May 30, 2018
    As I pointed out in post 48, it happens with every rotation. Tension in the belt is far from constant.
    And as I noted in another thread, when these cars were new you took them to the dealer for a free 1.2k mile check up at which time the timing belts were to be inspected and tension adjusted if necessary. So it's hard to believe that you could reuse a belts after 450 miles.
  4. absostone
    absostone F1 World Champ
    10,169
    Did you mean Couldn't reuse? And BTW how does the belt frequency work?
  5. johnk...
    Jun 11, 2004
    11,277
    CT
    John Kreskovsky
    Right, "reuse", not that I would. Not sure I understand the question about frequency. There is a simple formula that can be derived for a wire under tension that relates frequency to tension, the length of the wire and the mass per unit length. That equation would be approximate for a timing belt, but the fundamental result would be the same. Belt tension is related to frequency squared. So my measuring the frequency when the belt is plucked you would know the tension, provided you know the relationship between the two. Obviously you don't need to know the relationship, just what the frequency should be.
  6. absostone
    10,169
    I guess im asking what is the frequency and how is it checked
  7. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,831
    Cerritos, CA.
    I think once the belt is removed, replace it otherwise I was told you can re adjust the tension, I believe that’s what that hole on the timing belt cover that shows the nut for the tensioner bearing is for.
  8. absostone
    10,169
    I stopped in at continental today to have a chat with a sales friend. I saw Scott. One of the service advisors and I asked him why? He said never never reuse. I said why? because they are cheap! He said. Lol.
  9. crmso
    crmso Karting
    Jul 12, 2006
    72
    Madrid, Spain
    Carlos
    I'm 100% sure that the belts can be reused without any problems, but I 'm 100% sure that I wouldn't reuse them in that case.
    Why?. Because if I reuse the belts and one of them breaks in any moment before the next belt change, I would be the rest of my life thinking that the belt was broken because of reusing it.......
    rjlloyd and absostone like this.
  10. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    You can re-use a condom as well, but I would do it for the same reason. The consequences of a failure are too high:)
    dinonz308, thorn and absostone like this.
  11. johnk...
    Jun 11, 2004
    11,277
    CT
    John Kreskovsky
    You can do it with a PC with a cheap microphone and spectrum analyzer software (free downloads available). Or maybe an app for a phone. Or frequency counter software https://audio-frequency-counter.soft112.com/ Just pluck the belt and it will tell you the frequency. But I don't know the correct frequency for the belt.
  12. absostone
    10,169
    cool yes I saw that thread with the iPhone app recently here
  13. Etcetera
    Etcetera Two Time F1 World Champ
    24,281
    C6H14O5
    People are using condoms in place of belts? This is the first I've heard of that.
  14. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    The builder could have replaced the o rings, and they would still leak if they didn't put a dolop of silicone at the head/valve cover/o ring junction. You can DIY that without removing the timing belts. Just make sure to clean all of the oil out of that area before applying the silicone. I like Ultra Black.
  15. absostone
    10,169
    That would be a good time with the ac in the way. But I can see what looks like grey gasket maker on the corners
  16. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    Another perspective; Harley Davidson have been using toothed belts for their final drives for decades and they are exposed to everything that nature can throw at them. Every time the rear wheel is taken out e.g. to fit a new tyre, the belt is "re-used" and HD don't recommend that you replace the belt every time the rear wheel is removed.
    I bought my HD in December 2000 and I have never once had to adjust the drive belt tension and the adjusters are exactly where they were when I picked it up from the dealer in 2000. HD belts use a Kevlar base and Kevlar doesn't stretch. Do Ferrari belts use Kevlar?
    Whilst the HD belts don't rotate as fast as Ferrari cam belts, I suspect they're put under much more load/torque.
    From what I've seen and read, it appears to me that the tensioners are the potential weak link, not the belts, so if both are in good condition, I think you can refit them without any undue concern.
    Just my unqualified opinion of course. :)
    Paul
  17. ferrariowner
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    Your reading comprehension appears to be poor. Is English your primary language?
  18. PDB
    PDB Formula Junior
    Feb 1, 2011
    602
    Leicestershire, UK
    Paul
    I think you’ll find he was joking.
    What were you saying about comprehension?
  19. 308 milano
    308 milano F1 Veteran
    5,350
    Montana
    Kim
    Almost 70 posts on the subject. Why are we even discussing this? LOL.
    If forking out $36 for new belts is going to cause missing a meal, I would opt for reusing the motor oil in your Ferrari and save 50 bucks!
  20. afterburner
    3,499
    Switzerland
    Urs STEMMLER
    As long as you change the filter...
    absostone likes this.
  21. 308 milano
    5,350
    Montana
    Kim
    As rifledriver would say ..
    “ please share your vin # so we may know which cars to avoid in the future.”
    afterburner and thorn like this.
  22. absostone
    10,169
    Well I never said I was gonna reuse it.
    I asked why couldn't it be reused. And it turns into this. The best answer is don't reuse because they are cheap.
    ///Mike and 308 milano like this.
  23. miketuason
    Feb 24, 2006
    15,831
    Cerritos, CA.
    Mike even if it’s not cheap, I still wouldn’t reuse it, just my advise.
  24. absostone
    10,169
    There are 73 posts. Everyone pay 50 cents and I won't scare everyone or myself for reusing them.
    WHiCH I NEVER SAID I WAS
    ///Mike and afterburner like this.
  25. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    I may still have the 2 belts I pulled off my car in December... they're yours for $18 + shipping. PM if interested. ;)
    afterburner, 308 milano and absostone like this.
