Rev Counter problem | FerrariChat
Rev Counter problem
Discussion in '308/328' started by Harry, May 16, 2024.
  1. Harry
    Harry Karting
    Nov 1, 2003
    101
    Germany
    After servicing my distributors (new points, condensers), my rev counter works only intermittently. Half of the time it shows 0, half of the time it works as it should. Engine runs fine.
    Never seen this problem before. Can the problem be related to some cable not being properly re-connected at the distributor?
    ('74 GT4, dual distributors with points, single point setup)
  2. Dockboy
    Dockboy Formula Junior
    610
    Maryland
    Tach is electronic, no cable. It gets it's signal from the "-"(negative) side of one of the coils. It's a brown wire if I remember correctly. Either it is not connected or has a bad connection at the coil.
    kiwiokie likes this.
  3. Harry
    Harry Karting
    Nov 1, 2003
    101
    Germany
    Thank you, I will have a look at the coils!
