Reverse Block | FerrariChat
Reverse Block
Discussion in '308/328' started by LE06, Sep 9, 2024.
  1. LE06
    LE06 Karting
    232
    Lee
    My Oldest sone is getting married Saturday. Last night he asked if he could borrow one of my cars to drive away from the church. He said I could choose the car but not my truck. LOL he knew that was what I would say.
    I know he really does not want my X1/9 and the Exige is out because I don't see the bride getting in that thing with her wedding dress. So what he is really asking is for the 308.
    There two problems with that, first is third gear synchro is not great. You have to be real gental shifting into third. It has gotten much better since I have been driving the car, last owner let it sit. It's been 26 years since the transaxle oil has been chanced so today I am changing it. Hopefully this will help.
    Second problem is I am really worried he will down shift into revers. He has only driven it once and he started to do it then, but I stoped him.
    So my question, is there a block someone sales that will fit in to the gate to stop that from happening?
  2. MaranelloMark
    MaranelloMark Formula Junior
    438
    Bay Area, CA
    LOL. So the metaphor is "There is no turning back." Hill Engineering has some things, but not quite what you need. But you can use their gate lock as an example and make your own I'm sure. A couple thick plastic washers to cover the reverse slot, a bolt and a nut to hold them in place. And hope he doesn't need to go back to church to change his "I do"
    LE06 likes this.
  3. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    742
    Omaha, NE area, US
    Steve
    Isn't their gate lock designed to hold it in reverse?
    66MK, LE06 and MaranelloMark like this.
  4. MaranelloMark
    438
    Bay Area, CA
    #4 MaranelloMark, Sep 9, 2024
    I think so. But the same principle applies is what I was saying. All you need to do is block the R slot. And I doubt he needs it locking. Just some plastic shims to avoid marring and a bolt and nut to hold them in place.
    I've think I've seen somewhere else a gate with a slide or something to prevent Reverse once the lever exits the slot. But seems too complicated.
    Just tell your son he's buying if he grinds the gears. :)
    LE06 likes this.
  5. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    Seems like it would be hard to downshift into reverse with a 308 gated shifter?
  6. F1blood
    F1blood Rookie
    Jul 17, 2024
    44
    Brad Dinardo
    26 years between gear oil changes cant be that good for the gearbox Im imagining .
    Rifledriver, Cameron Henlin and LE06 like this.
  7. Anthony Rapuano
    Anthony Rapuano Karting
    Aug 16, 2022
    211
    CT
    Anthony V Rapuano, Jr.
    I assume you know that Ferrari built in a reverse lockout feature into these transmissions. You have to press down on the shift lever to engage reverse. If your son does not push down on the shift lever he should not be able to engage reverse by accident. It is wonderful that you are letting him use the car on this most special of days. Just review the particulars of shifting this transmission with him. I'm sure he will be fine with it.
  8. LE06
    LE06 Karting
    232
    Lee
    To damn funny! no turning back, no reversing! I did not think of the metaphor. I like your idea of the washers.
    MaranelloMark likes this.
  9. LE06
    LE06 Karting
    232
    Lee
    No I did not know that. On my 308 you don’t have to push down, it will go right into revers. I have a 78 with a Euro motor and transmission. I don’t have a record of when it was installed but it was probably around 80-82. Maybe I should pull the gate off and see what is up
    Thanks for the info
  10. LE06
    LE06 Karting
    232
    Lee
    I found a tread about the lock out. I went and look at the gate. It looks like the block and the shifter are missing each other. Perhaps my shifter is stuck down. I will look at it more tomorrow
    Thanks guys.
  11. speedcat
    speedcat Karting
    Jul 26, 2011
    158
    Calgary, Canada
    ragtop1, NYC Fred, LE06 and 2 others like this.
  12. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,811
    Cerritos, CA.
    LE06, speedcat and MaranelloMark like this.
  13. MaranelloMark
    438
    Bay Area, CA
  14. cbmcdona
    cbmcdona Karting
    150
    North Carolina
    Caleb McDonald
    There should be a little tab on the bottom of the gate that will block reverse. Sometimes these get worn. The other thing is your shifter may be stuck pushed down. Mine was at it had sat for 30 years. Trying gently pushing up and down on it to see if you can free it up.
    LE06 likes this.
  15. LE06
    LE06 Karting
    232
    Lee
    I took the gate off today and got the shifter to go down and up easer but it still miss the block even fully up. I will have to figure a way to fix it.
  16. MaranelloMark
    438
    Bay Area, CA
    LE06 likes this.
  17. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,246
    Snohomish, WA
    Eric L
    Do you have this "fin" on the underside of the shift gate? Mine had been ground down by the previous owner not pressing down enough on the shifter to engage reverse. It was at the point where it was not doing it's job as a reverse lockout. I built up some material with a welder and re-shaped the fin with a file and now it works as intended
      File size:
      71.5 KB
      128
    Sergio Tavares and LE06 like this.
  18. LE06
    LE06 Karting
    232
    Lee
    Yes I have it but it is worn down to the point of just touching the shifter. I will need to have it built back up. In the mean time I am going to make a spacer for the shifter. I will take the knob off and slide it down on the rod. This should make it where it wont go into revers till you push down on the shifter.
  19. sltillim
    sltillim Formula 3
    1,696
    San Diego
    I understand wanting to make your son's big day very special. It sounds like you shouldn't be investing in parts - you would be better off using time training him how to properly use the car and how be responsible with it. OR, don't let him use the car because he clearly doesn't know how to drive it....
    I mean if he doesn't know how to dance, his bride to be is making him take lessons for their big moment at the reception, right?
    ALSO check what kind of dress the bride is wearing - if the bottom is very poofy, she's not going to want to get in/out of the 308, too. Or maybe he drives the car there, they take a limo to the reception and you take it from there. This is one of those "you should check with her too" moments. Can you imagine if it messed up her dress or broke down? Wedding days are a whirlwind filled with stress. Unless your car is bulletproof going to work, don't create unknown scenarios.
    tomberlin and mike996 like this.
  20. LE06
    LE06 Karting
    232
    Lee
    He learned on a manual and his car in high school was a manual BMW. I was more worried about him forgetting that the 308 has a different shift pattern, I know I have, LOL!
    I Talked to him last night about the use of the car. Seems I miss understood. They are only driving it for pictures. He is not going anywhere with it. The big day is Saturday morning so I just did not have much time this week. but all is good.
    I still want to fix the block, it is there for a reason.
  21. MaranelloMark
    438
    Bay Area, CA
    PS. Congratulations!
    LE06 and sltillim like this.
  22. sltillim
    sltillim Formula 3
    1,696
    San Diego
    I second!
    LE06 likes this.
  23. LE06
    LE06 Karting
    232
    Lee
    Thanks guys!
  24. 66MK
    66MK Karting
    Nov 1, 2020
    203
    Mark
    Yep. Its an anti theft device. I have two and they do what they say they do.
    LE06 likes this.
