Reverse light switch | FerrariChat
Discussion in '308/328' started by Kent Dellenbusch, Feb 11, 2022.
  1. Kent Dellenbusch
    Kent Dellenbusch Formula Junior
    664
    Upland, CA
    Kent Dellenbusch
    #1 Kent Dellenbusch, Feb 11, 2022
    Hello F-Chat guys.
    My 89 328 is not turning on the two reverse lights when going into reverse. Does anyone know what the part number for that switch? Any source for the said switch would be helpful as well?
    I believe all I need to do is unscrew the gate plate and access the switch. Up for suggestions if I'm incorrect.
    Thank you in advance.
  2. Rifledriver
    37,089
    Console needs to be removed. Any Ferrari parts vendor knows the number.
    Kent Dellenbusch likes this.
  3. Kent Dellenbusch
    664
    Upland, CA
    Kent Dellenbusch
    #3 Kent Dellenbusch, Feb 11, 2022
    Thanks for the note. I'll get ahold of schematics to remove the console. I appreciate your time.
  4. Rifledriver
    37,089
    Remove the carpets, the shift gate and the ashtray. The rest is pretty self explanatory.
  5. Rifledriver
    37,089
    If you are careful you can just get the front of it up about 8 or 10 inches and support it there somehow. The switch screws into the front of the shift box.
  6. Kent Dellenbusch
    664
    Upland, CA
    Kent Dellenbusch
    I'll attempt this when I get the new switch. A good time to clean under as well, I guess.
