reverse light | FerrariChat
reverse light
Discussion in '206/246' started by yakxx21, Mar 11, 2015.
  1. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
    Bought the new bracket from Superformance but wonder if anybody has a pic of just how this is fitted...?
    My Dino has only two holes drilled but bracket has four ?
    If I line up two holes and drill two more it hanges a long way under car ??
    The wire comes out in front rather than behind the lamp so will have to be fed back ..?
    Its in Stainless steel...was it painted ?/
    A pic would be nice
  2. racerboy9
    racerboy9 F1 Rookie
    2,651
    There is a good pic of the reverse light installed on the last page of omgjon's special Dinos thread.
  3. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Mine mount with two rivets - it sure would be helpful if you added photos for all to see exactly what you're describing when you start posts like these
  4. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
    Right...two very dumb questions---
    How do I actually find Omgjons pic....and secondly...how do I upload a pic....
    Ok OK.....I was born in the 40´s and still catching up....
  5. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,203
    Norfolk - UK
    Tony
    http://www.ferrarichat.com/forum/206-246/466790-08510-08514-special-dinos-7.html
    click on the above link
    Go to post 125 (found on top right hand corner of the header bar on each post..this post is no5 near the warning triangle)
    6th picture down.
    I believe the top of the reverse light should be level with the black line.
    The cover should be satin black.
    Ever thought about buying the dino compendium by M Bartz (germnandino)
  6. HMB-Dino
    HMB-Dino Formula 3
    2,292
    Pebble Beach, CA
    RonG
    Think you meant "GermanDino"....not "germnandino"
  7. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,203
    Norfolk - UK
    Tony
    yes that guy as well :)
