Reverse uphill F1 transmission | FerrariChat
Discussion in '348/355' started by SA Mike, May 25, 2019.
  1. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    Hi all. I have a question. Is it still bad on the clutch even if you start from a even plane then reverse uphill with the clutch engaged or is it just starting uphill from an incline that’s bad. I’m a new 355 owner and didn’t know this. My driveway slopes downward then of course evens out once in the garage. I have reversed once uphill since I’ve had the car and it seemed to do just fine going back up but I started on a even plane first. I didn’t smell any clutch burn or feel the clutch slipping.
  2. judd10
    judd10 Formula Junior
    479
    Seattle, WA
    I have a moderately steep driveway but have to back out/up slowly so that I don't run into any cross-traffic at the top. The slower backup speed seems to burn the clutch. I prefer to just back into the garage so I'm always driving forward up my driveway.
  3. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Yes it will.
    Clutch does not fully engauge in reverse, only in forword gears.
    Hence do not back up unless you have too it will wear clutch out faster. If you need to stab at the gas pedal a bit rather than just keep pressing slowly more and more. This seems to be the prefered method.
    Robb likes this.
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Ok just change the clutch sooner
  5. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Don't reverse, its a feature of the 355 F1? Wow you learn something every day.
  6. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
  7. SA Mike
    SA Mike Karting
    May 25, 2019
    52
    Texas
    Michael Martinez
    Thanks for the replies! I just started backing it up in the garage. It actually works better that way because there is a slight dip right before the garage and the front clears it better.
