Reving the throttle right before shutting of the car?? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Jsuit, Aug 14, 2007.
  1. DGS
    DGS Seven Time F1 World Champ
    73,995
    MidTN
    DGS
    Habit? Blip the throttle when "down-shifting" from "neutral" to "off". ;)
  2. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Dubai had it right.
    On heavily camed engines the valve overlap is such that at idle the engine "lopes" and does not effectively burn the fuel off the plugs. Bringing the RPM up to a point where the engine "comes on cam" and smooths out will then burn the fuel off the plugs when they are still hot allowing for an easier restart. On the obsurdly camed engines we have to shut off the fuel supply with the engine running, bring the RPM up to 2500 and wait for it to start missing then shut down the ignition. Start up is the reverse, get it cranking with no ignition and once the oil pressure is showing, throw on the ignition.
    Another occation where it is of a little benifit is just before checking the oil on a dry sump car after a prolonged idle time. Bring the RPM up to 2K for a few moments will run the scavage pump faster and make sure the engine sump is emptied completely into the tank. That said, there is usually far more scavage pump volumn than pressure pump volumn so the effects are questionable.
    Dave
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,857
    The twilight zone
    Dave, Isnt' the Lobe on engine with hot cams from the carb losing signal and messing up the mixture? EFI engine, like the Indy car that started the thread shouldn't have a lopping idle or the loading up that goes with it....at least in theory.
    In the motorcycle world, when the race bikes still had carbs, the racing carb often didn't even have idle circuits in them, so if you wanted it to stay running, you blipped the throttle....but I don't think that applies to car carbs.
  4. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    +1 This is what I also heard years ago when we all had carbs and dinosaurs walked the earth
  5. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Quotation from a Len Deighton spy novel:
    "he revved up his engine before shutting down, in the manner that racing drivers are reputed to do"
    It was master spy Harry Palmer's disparaging view of his American boss.
  6. BigTex
    79,418
    Houston, Texas
    Bubba
    LOL!
    Must have had fresh plugs.......
  7. ZINGARA 250GTL
    ZINGARA 250GTL F1 World Champ
    Jun 21, 2002
    17,499
    PA
    Ken
    No.
  8. BigTex
    79,418
    Houston, Texas
    Bubba
    No water vapor in a hot Ferrari exhaust, unless you've blown the heads.......;)
    That's only on cold start, from leaving it in New Orleans overnight....you should drive down for FFQC dinodan!
  9. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    +1 You hit the nail on the head Dave....rev it up for burn off...flip the EMS switch off which stops the injectors(on FI engines) and exit the car for a 2gal swig of Gatorade..more if you're not wearing a cool suit in a closed cockpit endurance car.
    All the race cars I've built had EMS disconnect switches..for start up....EMS off....crank till oil pressure was up.....flip the ole switch to on, fire it up, and hang on for the adrenaline rush..lol
    I can remember back in the good ole days when we were running mechanical FI....even the ignition cut-offs sometimes didn't save you. The Porsche 917's in particular....if you waited to build full oil pressure before switch-on, the plugs had already fouled. If you timed it just right you had to keep the revs above 2000rpms or they would be soaking wet with fuel, and not a d@mn one of them would be firing. I can't tell you how many drivers I've cursed, while replacing 12 spark plugs on the starting grid...lol
  10. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,214
    Atlanta
    Tom Spiro
    From my experience with racing... when racing cars rev up and shut off the engines its to burn unwanted fuel/ oil from the plugs. make it easier to get the car running when starting. especially back in the carb days.
    Today it may to ensure you have a clean stoichometric measure on the O2 sensors, and knock sensors. "clear out the carbon" prior to shutting it off.
  11. mont
    mont Formula 3
    Sep 16, 2004
    1,551
    Portugal
    Correct! That's the reason.
  12. BigTex
    79,418
    Houston, Texas
    Bubba
    No our cars are fed by an electric fuel pump, turning it 'on' puts fuel into them...........;)
  13. tuttebenne
    tuttebenne F1 Rookie
    Mar 26, 2003
    3,218
    Bay Shore, NY
    Andy
    No fair; you cheated Big Tex. You didn't read the whole thread ;) The comment about carb cars was in the context of old carb cars. I agree with the three gents who state that throttle reving prior to shut down originated to fill fuel bowls in preparation for the next start.
    But the thread originated with a question about fuel injected race cars. The response related to being "on cam" prior to shutting down a heavy overlap motor is the most plausible.
  14. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    If one was able to design a purpose built engine from scratch this might be true about the idle.
    The last 348 race engine (EFI injected) we built used cams with a duration on the intake in excess of 340 degrees and intake valve opening before 70 BTDC. At idle there is near as much air being pushed out the intake as is going in. This engine doesnt come on cam until 5000 RPM and will not idle below 2200. Lopes enough at idle we considered putting limit cables on the engine mounts. If we shut it off with wet plugs there is no chance for a restart.
    I will, to avoid confusion, change my above reply to..... This is why "I" bring the RPM up before shutting the race engines down. There is no reason to do it on a street car.
    Dave
  15. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Bingo. Old Lotus' do that too until you change the jets.
    Ken
  16. BigTex
    79,418
    Houston, Texas
    Bubba
    My cars sit so long between drives you are only insuring a new supply of varnish in the fuel float bowls!!! LOL!
  17. Air_Cooled_Nut
    Air_Cooled_Nut Formula Junior
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    :confused:
    -If the fuel is transported by an electric pump then there's no need to fill the bowls because they'll always be filled. Revving the engine just uses MORE fuel, thus insuring they'll have LESS fuel in them, if bliping does anything.
    -If the fuel is transported by a mechanical pump (like my air-cooled VW) then as long as the engine is running, fuel is being pumped into the bowls. At the end of a drive, those bowls are still filled with fuel. Revving the engine will, again, just use more fuel. The fuel pump will pump faster, of course, in keeping with the engine so it fills the bowl in time just as it would if the engine was idling.
    So this theory is hog-wash.
