Revised debate re 308 aluminum cooling hose | FerrariChat
Discussion in 'Technical Q&A' started by Irishman, Oct 30, 2006.
  1. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    #1 Irishman, Oct 30, 2006
    Any new sources for replacement? Better yet, pictures showing where it goes? I am referring to #26 in the attached diagram. I am fairly certain mine was tied in a bracket that directed its mostly crumpled output in the general direction of the cats. Now I see recent postings claiming it is supposed to be directed *down* on the CV boot? Last 308 I looked at other than my own had it pointed at the rear headers (car had no cats).
    Thanks,
    Seamus
  2. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    i am sure you can use any heat riser hose that usually goes from a duct on the exhaust manifold to somewhere on the air cleaner that will open up or close a flap for cold weather driving. car quest has these in all different diameters, i just bought some for an intake mod for my 308.
  3. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    I't's purpose seems to be to get cooler into the general area between the engine/differential & the headers.
    It is generally pointed towards the inner half-shaft boot which does seem to get baked w/o it.
    To the best of my knowledge, no one has come up with a proper exact replacement. There was a long search in the old Fchat about the time I discovered mine was missing several years back. I even tried to find out how to contact the company that seems to make most of the after-market heat riser hose. Unfortunately, couldn't track them down from the brand name & info on the packages. Might be easier now tho.
    I ended up using some plastic heater/ac vent tube (similar to the vinyl on coiled wire clothesdryer hose) that was the correct size. It was made by the same company that makes the heat riser hose. Got it from AutoZone.
    It's been doing the job for about 4 hears.
  4. Dr Tommy Cosgrove
    36,427
    Birmingham, AL
    Tommy
    I didn't realize until just now that mine is missing too.
  5. NYCFERRARIS
    NYCFERRARIS Formula 3
    Mar 2, 2004
    1,011
    Who knew?
    Mine's gone also...another thing to source and stuff down in there, wondering if a small electrical round cooling fan inserted in the tube might help cool that area or is this crazy over kill? I saw somewhere else on fchat a great mod with a small electrical fan to cool the oil cooler
  6. 4Webers
    4Webers Formula Junior
    Nov 12, 2003
    276
    Texas
    Darrell
    Cool air duct to right side CV joint, FPN 60439700:
    Porsche PN 901-211-195-00, ~$9. Color and finish may be different than original, but size is exact.
  7. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    FYI This outfit is doing a run of 10 sets of aluminum cooling tubes for Europa guys. He'll do a one off for like $550, and $125 each for the run of 10.
    Ken
    John Maniaci
    Troy Tube & Mfg. Co.
    50100 East Russell Schmidt Blvd.
    Chesterfield, MI 48051
    586-949-8700 ext 111
    Fax: 586-949-9915
  8. dave80gtsi
    dave80gtsi Formula 3
    1,918
    Ohio
    Dave Meredith
  9. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
  10. NYCFERRARIS
    Mar 2, 2004
    1,011
    this guy claims to have a better replacement @ $249.
    [email protected] 417-831-6065 know nothing else about it since I think it may be too pricey for a non OEM hose, he says it is NOT simply dryer hose and is much better. If anyone follows up or has more to add please post.
  11. 355
    355 F1 Rookie
    3,643
    Toronto
    Frank
    This is the same type of hose used in vw beetles back in the 70s. I dont remember the size though.
  12. Steve Magnusson
    26,790
    I don't even know what "original" would be, but I can 2nd that a VW (bug) shop had a perfectly usuable piece IMO. IIRC, it's part of the VW air heater ducting from the engine shrouding to the passenger cabin -- a fine-pitch aluminum foil over cardbord tube with corregated pleats -- that is it's bendable (but not much need for that in the 308 application).
  13. 4Webers
    Nov 12, 2003
    276
    Texas
    Darrell
    #14 4Webers, Nov 4, 2006
  14. Steve Magnusson
    26,790
    That's the "VW" type too (at least I thought it was VW -- maybe was Porsche -- or both).
  15. 4Webers
    Nov 12, 2003
    276
    Texas
    Darrell
    Yep, there is probably a VW site somwhere that sells these for $3.
    Both the length and diameter of this one are EXACTLY the same as my original F-part.
  16. NYCFERRARIS
    Mar 2, 2004
    1,011
    thanks Darrell! nice work, my cv joint thnaks you too!
  17. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Hey, my 1977 308 USA has no duct extension or hose. is that normal for a pre-cat USA car?
    Greg
  18. 330gt
    330gt Formula 3
    Nov 12, 2004
    2,096
    Seattle, WA
    Kerry Chesbro
    Yes. The extra duct and hose are not shown in the 75-77 US parts book.
  19. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Thanks Kerry.
    I used to own a 1983 308 GTS QV and I can say that car ran much hotter than my non-cat car. The engine bay would get piping hot, whereas my current 1977 308 does not, even after a long high-speed run.
    That's why I vowed to only own a non-cat 308 if I ever got another one!
    Greg
  20. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Amen :)
  21. NYCFERRARIS
    Mar 2, 2004
    1,011
    I may be off on this but I think I remember reading in Forza that the pre cat 308's had a "thermo-reactor" or something like that ( sort a of a pre cat - era emmissions device) that is by this time old and problematic and a major cause of the 308 car fires.
  22. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
  23. Jdubbya
    Jdubbya The $10 Trillion Man
    43,181
    PNW
    I ordered one too. Looks like it'll fit just fine! Pretty rare to find such a cheap part!
  24. 4Webers
    Nov 12, 2003
    276
    Texas
    Darrell
    glad to help out - now we just need to find that $3 VW part ;)
