Hello All I have an annoying clunk i my RH rear suspension. When you go over a bump you get a loud !Bang Clunk! Any ideas??. P.s 96 355 GTS down under cheers in advance for any help. ( visually everything looks fine)
Check your front motor mounts to be sure they are not shot. When they go bad, the brackets coming off the side of the engine can easily bounce on the frame when going over bumps and rough streets. Solution: replace the mounts.
