Ricambi headers installed, opinion with pics | Page 3 | FerrariChat
Discussion in '348/355' started by Shootfighter65, May 20, 2015.
  1. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,993
    Northeast U.S.
    Jim
    Oz, that is what I was concerned with also. How well or how long will it last?
    If it starts flaking off could it clog the cats, or end up back in the cylinders. I didn't want to take the chance.
  2. Eric C
    Eric C F1 World Champ
    11,136
    St. Louis, MO
    Eric
    That's some talent you got there.
  3. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Talent my big fat butt, from all the cocaine I did in the 80's leaving my body :)
  4. ShineKen
    ShineKen Two Time F1 World Champ
    20,036
    Southern California
    Nostradamus
    How about coating just the outside? White Lightening from Swaintech is very reputable. A certain thickness needs to be applied to maintain durability and effectiveness.
    The whole coating of the inside idea is up for debate. Some say coating a header on the outsude without coating the inside is ineffective. I don't know if that is true or not. It's also very difficult to coat the inside of a complicated header properly.
  5. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    I'm not so sure I would be concerned about the coating inside of the headers....in my case....after 6 years there is no evidence of the coating de-laminating and the intake of my cats are unclogged and clean of any debris. Of course the original inner coating in the header is now coated in carbon from the exhaust. I've thermally scanned my header routinely and the header pipe temps have never increased since they were new.
  6. ShineKen
    20,036
    Southern California
    Nostradamus
    I have a 321 Stainless Steel header in my exige (4 cylinder NA). I am running without any coating or shields. From DRS Lotus' extensive racing experience with these headers and customer feedback, they felt it wasn't necessary. I know... Different setup, different power, but they felt 321 SS was effective enough in reducing radiant heat even compared to OEM with shields.
  7. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    +1 ...... limited access to prepare and roughen the inside of manifold tubing will affect how well a coating will adhere .... most mandrel tubes have some residual lubricant from the bending process, which may be difficult to remove to an acceptable level ..... so a coating that has a good track record of adhering well on the outside of manifolds, may not have the same success on the inside ..... but if there is a process or brand available that works on the inside .... I would like some info on it ... :)
  8. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    if you thermally scan your header pipes you will know if the coating is failing.
  9. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    But if your really concerned either fabricate a full metal heat shield (I did) or install one of the available header blankets that capristo or fabspeed sell.
  10. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Good point ...... I guess one would need an uncoated reference point ..... assuming the internal coating creates a measurable temp difference, when measured from the outside .... :eek:
  11. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    So you fabbed a metallic sheild for your manifolds? .......... now I want to see some pics or a thread link .... :)
  12. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,993
    Northeast U.S.
    Jim
    I am not sure about that. If the coating on the outside of the header is still intact, the inside coating could be deteriorating but not show any difference until enough of the coating is missing before outside temps increase. No one has ever posted any boroscoped pictures of headers after being ceramic coated prior to installation and then rechecked during their engine out service. This would give you a better idea how well the coating is actually holding up.
  13. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    I hear ya.....this is not perfect.....but if the thermal temps are the same year after year the coating in some form must still be there. In my case,its been 6 years and the temps have not changed.
    Even with a boroscope though (have one) all you can see inside the headers is black....consistent black coating though :).
  14. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,993
    Northeast U.S.
    Jim
    During my project I considered ceramic coating the headers. Chris and I discussed this and he was concerned that coating the outside could compromise the integrity of the header by trapping the heat in the metal. He thought it would be best to coat the inside and the outside for header survival. Now we are talking about just the headers surviving, not taking into account cylinders or other components that could be compromised if the coating does not hold up or stick well. It is all about risk.
    Tubi has been the gold standard for F355 headers. They use 2mm thick 304s/s and has a heat shield similar to the OEM product not ceramic coated.
