Riddle | FerrariChat
Riddle
Discussion in 'Other Off Topic Forum' started by Dan Ciezniewzky, Nov 21, 2005.
  1. Dan Ciezniewzky
    Dan Ciezniewzky Formula 3
    1,351
    Indianapolis
    You are stuck in a room with no windows or doors. a solid room. Only things in this room is a mirror and a table. how do you escape?
    anyone know???
  2. ^@#&
    ^@#& F1 World Champ
    12,091
    take a sledgehammer and smash through the wall
  3. bludevil12
    bludevil12 Formula 3
    May 12, 2004
    1,930
    Northern VA
    David L.
    Look in the mirror...see what you saw....take the saw cut the table in half...put the halves together and make a whole..:D
  4. ^@#&
    ^@#& F1 World Champ
    12,091
    what!?
  5. bludevil12
    May 12, 2004
    1,930
    Northern VA
    David L.
    escape through the hole....
  6. Dan Ciezniewzky
    1,351
    Indianapolis
    genious!!! :)
    actually i dont know the answer, but sounds good to me
  7. Alex_V
    Alex_V F1 Rookie
    3,611
    Boulder, CO
    Alex
    My exact thoughts!
  8. ylshih
    ylshih Shogun Assassin
    Honorary Owner
    Mar 21, 2004
    20,650
    Northern CA
    Yin
    A bit more morbid. Break the mirror, slit your wrists with a shard. Death is an escape.
    Problem is that this doesn't use the table. But you don't really need the table in the above "saw" solution either since the critical part is making a "whole". I.e. just break the mirror, put the pieces back together to make a "whole" and escape.
    How about this. The mirror is on the wall and is actually a big two-way mirror (like an interrogation room). Now take the table, use it to break the mirror and escape.
  9. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,520
    SFPD
    Dirty Harry
    Take mirror off wall
    Take nail which held mirror off wall
    Stand on table
    using nail, unscrew or pry *vent open
    climb up into, then through ventilation system
    *Hey, it didn't say nuttin' 'bout a lightbulb in the room so you could see, either!
  10. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    Is using C4 an option?
  11. wax
    Jul 20, 2003
    52,520
    SFPD
    Dirty Harry
  12. SRT Mike
    SRT Mike Two Time F1 World Champ
    Oct 31, 2003
    23,343
    Taxachusetts
    Raymond Luxury Yacht
    Smash table
    Take table leg
    Smash mirror
    Take shart of glass from mirror and use your shoelaces to lash it to one of the table legs
    Take another table leg and get/put a nail sticking out of it
    Use these two tools to beat yourself in the head until dead or skewer yourself in the temple. Since there are no doors or windows, it means you must have been born there, and what a craptastic life that would be having to stay there.
  13. Manettino
    Manettino Rookie
    Aug 9, 2005
    49
    Land of Oz
    How high are the walls? Without a ceiling and short walls, I'd just climb over.
  14. glennm19
    glennm19 Karting
    Nov 6, 2004
    204
    NJ
    Glenn
    If there are no windows or doors, how did you get in the room in the first place?
  15. glennm19
    glennm19 Karting
    Nov 6, 2004
    204
    NJ
    Glenn
    Actually, thats my answer...I'll get out of the room the same way I got into it
  16. CMY
    CMY F1 World Champ
    Oct 15, 2004
    10,142
    Redondo Beach, CA
    Chris
    Hmm.. go through the door frame?
  17. ylshih
    Honorary Owner
    Mar 21, 2004
    20,650
    Northern CA
    Yin
    Doesn't have to make sense, but they could have dropped you through a hole in a pre-built bunker then sealed the opening while you were drugged.
  18. CMY
    CMY F1 World Champ
    Oct 15, 2004
    10,142
    Redondo Beach, CA
    Chris
    There are no "doors" or "windows", but there are openings for doors and windows.
  19. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    It's a dream. You wake up.
  20. ylshih
    Honorary Owner
    Mar 21, 2004
    20,650
    Northern CA
    Yin
    OK, here's the definitive "non-tricky" answer for a fully sealed room :D!
    If it's a wood or wood/plaster room then break the table and mirrors and use the sticks/legs and shards as tools to make chinks, cut wedges, lever slats off or bust through plaster, making a hole any way you can.
    If it's a brick or concrete room, find the spot of uncured mortar or concrete that is the freshly sealed opening and use the tools as above on the weak spot in the room. (Caution: don't break the table until you're sure the weak spot isn't in the ceiling, if it is you can only break off one table leg.)
    If it's a steel room that's been welded/riveted closed then:
    - break the mirror into two large pieces
    - break the table into pieces
    - stick the two mirror pieces into two legs used as handles
    - use the other two legs to rub together and start a fire
    - put all the fuel together to build the hottest fire you can
    - blow as hard as you can on the fire to get it even hotter
    - hold the mirror pieces on either side of the fire
    - hope you can hold the mirrors exactly parallel
    - hope that the mirror surfaces are flat to within 1/4 wavelength or better
    - there is an infinitesimal (hah!) chance you have created a laser which can burn a hole through the steel
    - if not you're dead anyway because you just consumed all the oxygen in the room :(
  21. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    "Transporter Room..... Mr. Scott, Energize."
    "Aye, Captain"
  22. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Close your eyes, click your heels together three times, and say "There's no place like home, there's no place like home, there's no place like home."
  23. de993
    de993 Formula Junior
    Sep 10, 2004
    416
    Las Vegas, NV
    You said no doors or windows, but how about a skylight?
  24. REMIX
    REMIX Two Time F1 World Champ
    How many bricks does it take to complete a building made of brick?
    RMX
  25. Webby
    Webby F1 Veteran
    Sep 12, 2004
    6,821
    wow that's clever!
