Right fan not coming on | Page 2 | FerrariChat
Discussion in '348/355' started by drbob101, May 30, 2016.
  1. Challenge
    Challenge Formula 3
    Sep 27, 2002
    2,027
    PA
    Kevin
    Yes, water not oil temp. B69 shows the sensor.
  2. DaisyCutter
    DaisyCutter Formula Junior
    Jul 15, 2014
    255
    Sweden
    Dayan
    Hi Bob,
    I found this thread when trying to diagnose my own car's current state. Previously the water and oil gauges never rose beyond 190 and 210 respectively, however now my car has inexplicably replicated the exact temperature increases yours did. I have noticed it is only when in stop start traffic and not whilst out on the open road in clear air.
    I saw that you replaced both of the temperature switches/sensors and cleaned the contacts. I will shortly be doing the same.
    Did you ever come to a conclusion about what caused your increase in water and oil temperatures?
    Cheers,
    Daisy.
  3. DaisyCutter
    Jul 15, 2014
    255
    Sweden
    Dayan
    Update:
    Replaced both the temperature switches and it looks like we may have sorted the issue. Stop start driving didn't produce water temp readings higher than 95 degrees celsius (203f), oil 95-100c (203-212f). Both fans functioning correctly.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,705
    San Carlos, CA
    Mitchell Le
    There is only 1 temperature switch, the one attached to the top of the left hand side radiator? Which sensors did you replace?
  5. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    #30 drbob101, Sep 22, 2016
    Hi I am sorry I didnt see your prior question.
    I only replaced the coolant temp sensor on the right side . I did not replace the switch on the left side.
    Everything seems fine now.
  6. yelcab
    Nov 29, 2001
    13,705
    San Carlos, CA
    Mitchell Le
    Makes sense. That is the temp sensor for the ECU and it is the ECU that decides to turn the right fan on, or not, using that temperature information.
  7. DaisyCutter
    Jul 15, 2014
    255
    Sweden
    Dayan
    My feeling was that it was the (right side) temp switch for the ecu, but thought I would replace them both while I was there. If it has indeed remedied the issue, I would consider it a very inexpensive fix.
  8. Beetle
    Beetle Formula Junior
    Apr 10, 2013
    776
    Guys
    Is the Bosch 0280130026 temp sender unit compatible with all 355 models in 96 5.2 cars?
  9. DaisyCutter
    Jul 15, 2014
    255
    Sweden
    Dayan
    I believe it is the same part for both 2.7 and 5.2 cars.
  10. Robbe
    Robbe Formula Junior
    623
    The Netherlands
    I know that there is a lot of info on this subject, but I did not find the exact symptoms I have with my fans:
    My RHS fan comes in first, at 1 o clock on the temp gauge. (idling , started from cold)
    Then occasionally my LHS fan kicks in for a few seconds, and then stops again, to kick in say 30 seconds later for just a few seconds again. It comes up to speed, but then stops.
    So I think something is not completely right with the LHS fan system.
    conclusions:
    - the fan/motor itself works, double checked it with 12V directly, no funny sounds, easy operation/rotation.
    - the switch / sensor (?) in the LHS radiator works, as the fan does work for a few seconds. But shouldn't it start before the RHS fan starts? Switch/sensor on its way out?
    - fuses are fine, and I switched the relays to no effect.
    Anybody any idea what could cause this?
  11. yelcab
    Nov 29, 2001
    13,705
    San Carlos, CA
    Mitchell Le
    It could be possible that the thermo switch is coming on to late. But, as long as both fans do come on, I frankly would not worry too much...
  12. Robbe
    623
    The Netherlands
    I jumped the radiator switch to see if the fan would start right away, which it did.
    And started the car again with the connector reconnected. (hoping that the reconnecting-connecting would have helped, naieve of course)
    Same story, the right fan kept on turning, while the left in the end also started and of course immediately stopped again, and started and stopped and started etc.
    So I better replace that switch as suggested if I am going to do something about it (which indeed is not that necessary)
    Is there a Bosch number for it , like with the sensor on the other side?
    I do not care if it would start 1 degree earlier or later, so a close alternative would be welcome. I know that even the Ferrari part is not expensive, but It will take at least 10 days to reach me, and I prefer to have it sooner (assuming the bosch part is available easily)
  13. yelcab
    Nov 29, 2001
    13,705
    San Carlos, CA
    Mitchell Le
    This one is not that expensive.
  14. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    This is the way the WSM states and the way mine and some others here on fchat works.
  15. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    I wonder if this is differant for rhd cars??
    Anyone know?
  16. DaisyCutter
    Jul 15, 2014
    255
    Sweden
    Dayan
    I picked this one up on eBay €18 delivered.
    0280130026 BOSCH TEMPERATURE SENSOR [SENSORS]
  17. Robbe
    623
    The Netherlands
    Thanks, but that looks like the rhs sensor, not the lhs switch. Any ideas about the switch?
    I can buy the original part for like 20 or 30 usd, but shipping and customs make it a 100 usd part that takes 2 weeks minimum to arrive with me here in the Netherlands...
  18. DaisyCutter
    Jul 15, 2014
    255
    Sweden
    Dayan
    If you are referring to the LHS radiator switch mounted at the top, I ordered one from Autoropa here in Sweden. Part no. 158655.
  19. V8ray
    V8ray Formula Junior
    Jun 18, 2013
    251
    Ray
    When you guys refer to right size do you mean drivers or passenger side? I have the same problem and order the part just want to know where that part is located.
  20. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    Rhs is when the car is pointed forword looking from the rear to front
  21. yelcab
    Nov 29, 2001
    13,705
    San Carlos, CA
    Mitchell Le
    If you sit in the car, your left is the car's left, and your right is the car's right. That way it is the same whether your car is American or UK.
  22. V8ray
    Jun 18, 2013
    251
    Ray
    Got it. Thanks
