right hand drive | FerrariChat
right hand drive
Discussion in 'Technical Q&A' started by fatbillybob, Mar 23, 2007.
  1. fatbillybob
    Aug 10, 2002
    28,978
    socal
    Hey Guys,
    For those of you who drive on the left side but have driven cars with the stick shift on the right as in the U.K., how long did it take to get used to that? Or did you even prefer it?
  2. OC Speed Junkie
    OC Speed Junkie Formula 3
    Aug 6, 2005
    2,473
    Southern California
    Joseph
    Not completely sure what you are asking, but I have driven on the right hand side of the road (USA) with the stick shift to my right (US car) as well as with the stick on my left (Asian car). I have driven on the left hand side of the road (England) with the stick shift on my left (right hand drive BMW). Took me awhile to get used to the fact that low gear was not close to me, but other than that it's easy. As long as you are comfortable with stick, not a big deal at all.
  3. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    The awkward part is always going to the passenger side door first from habbit
  4. Zertec
    Zertec Formula 3
    Oct 5, 2004
    1,335
    Singapore
    Clive Reed
    I believe you mean swapping from driving LHD to RHD cars or vice versa. It takes me about 10 minutes of absolute concentration and an hour or so of heightened attention before I properly drop into the groove. Considerably longer before I can be confident of not screwing up in "autopilot".
  5. Zertec
    Zertec Formula 3
    Oct 5, 2004
    1,335
    Singapore
    Clive Reed
    To a certain extent, learning to drive a RHD car shifting gears with your left hand may be an advantage when it comes to swapping cars (at least for a righthanded person like me) as it sort of makes you ambidextrous.
  6. TK 328
    TK 328 Karting
    Dec 24, 2006
    167
    Perth West Australia
    Tony
    Over here we are right hand drive, to be honest I could not see me changing to left hand drive with out a lot of practice, not to mention the roads etc. Not really a answer to your question, but some feed back. Tony
  7. waz356
    waz356 F1 Rookie
    Dec 5, 2005
    3,710
    Adelaide
    warren
    i have 2 356's one of which is a LHD import. no issues driving on the left, but it takes more concentration (and preferably a passenger to say when it's clear) to overtake. gearshift with the right hand is easy enough. have done quite a few miles in the LHD car now and can swap between them without much thought.
  8. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    I learned to drive in the UK came to the States then proceeded to go back and forth on business so I have experienced it both ways I think that Zertec ( Clive) got it about right initial concentration period of a few moments and keep alert that you dont go to the wrong Autopilot mode there are times in the States when I am making a left turn that I have the flash of OOPS! but then realize I am on the correct side of the road.
    Martin
  9. ZINGARA 250GTL
    ZINGARA 250GTL F1 World Champ
    Jun 21, 2002
    17,499
    PA
    Ken
    That's funny because it happened to me. I visited the UK on business. It took me a while to get used to going to the opposite side when someone else drove. Finally, I did. When I came home to the US? You guessed it. I had to reorient all over again.
  10. paul 308
    paul 308 Karting
    Jan 13, 2004
    110
    Guildford, Surrey UK
    Paul Deslandes
    Why a large part of the World (but by no means all) drives on the right amazes me. The rationale for driving on the left (the correct side) is that when riding your horse, your sword hand (usually right hand) can be used to smite your enemy coming in the opposite direction. You also always mount a horse on the left side. I wonder why the choice was made one way or the other when the automobile was introduced. Anyone know?
    Us Brits go back and forth across the English Channel to France and readily switch between driving on the left and right, although mostly with a right hand drive car. I usually find that I have to say "drive on the right" to myself a couple of times when I get off the ferry or train and I'm ok, except for some reason if my passenger says "take a right", I want to take a left. I guess the brain mirror images itself to cope in some way. The same thing happens when I go to the States and drive a left hand drive car.
  11. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Hi,
    Another ex-pat from the UK - Spent a *lot* of time going back and forth between the two and can honestly say that the location of the stick was never an issue - At least in my case it's like something deep in the brain clicks in and its automatic.
    Only time I nearly screwed up was leaving the pub (!) after just getting in to town and taking off on the RHS - Wondered why the lunatic coming the other way was on my side of the road..... Got a quick shot of adrenaline and straightened right up in a hurry....
    As usual, ymmv,
    Cheers,
    Ian
  12. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    Ian where are you from?
  13. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Born in Taunton, Somerset, moved around a lot (Dad worked for GCHQ) and consider South London 'home'.
    Cheers,
    Ian
  14. Challenge64
    Challenge64 F1 Veteran
    6,365
    Ron
    everyone else is pretty much right on w/ their suggestions..but here is my .02
    Ive driven in the UK w/ rental cars a few times. The only time it was a problem was when I did something by habit. Ie. walking to the "driver" side door on the left.
    Driving in London wasnt really a big deal as you just kinda follow the cars in front of you. The only time I completely blew it was in Scottland pulling on to an empty road from a parking lot and realising after 100 yards or so that I was on the right side..
    On yea...and the rental car reversed the wipers <-> turn signals on the steering column...so everytime I made a turn, the wipers would flap about.
  15. ZINGARA 250GTL
    Jun 21, 2002
    17,499
    PA
    Ken
    Hmm. You know; the way we drive here in the States, you just might need that sword in your right hand.
  16. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    Then there are all the funny descriptions of car parts like wings, bonnet windscreen etc.
  17. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    You forgot "boot" :) ['etc' just doesn't get it for "stick it in the boot" IMHO ]
    [Trunk over here, save anyone asking :) ]
    Cheers,
    Ian
  18. vteqe
    vteqe Formula Junior
    Mar 5, 2005
    664
    long Island, NY
    Sandy
    I have a right hand drive Lotus 7. The stick was easy to get use to. The rearview mirror takes a while to become comfortable with. It does not come naturally. I also tend to hug the right side of the lane.
  19. Rifledriver
    37,089
    Drive RHD cars here occasionally and no problem. In one that I am involved with now it has a crash box and that takes some getting used to.
    If you ride a motorcycle and drive a car, that is really the same. Controls are in different places. Brain just goes to a different directory.
  20. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    Right Hand Drive.....how did the Britts ever pull it off, to get the auto mgrs to stop the line and flip flop the steering just for a tiny island, albeit, a great one?
  21. Rifledriver
    37,089
    Hardly the only place ever to have RHD.
  22. mgtr1990
    mgtr1990 Formula 3
    Mar 30, 2005
    1,580
    Naples Florida
    Martin Graham
    Dont forget they made a couple of cars themselves Jaguar, RR. Aston Martin, Triumph, Humber, Hillman, Sunbeam, Rover, Austin, Morris, MG, to name a few so for them it was Gee change the line over to LHD Yawn!!!!
  23. matkat
    matkat Formula 3
    Mar 18, 2003
    1,840
    Scotland
    Dave McGuire
    Drive both sides fairly regularly no problem at all.
  24. ZINGARA 250GTL
    Jun 21, 2002
    17,499
    PA
    Ken
    My guess is that the RHD market is large enough to have its own line.
  25. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    The first time I was over in England I drove a manual. It's a bit weird at first, because your use to changing gears with your right hand, but once you get use to it it's no big deal. The biggest thing you have to get use to is looking to the right before you proceed through an intersection. But as for changing gears, nothing big deal. Plus the peddals are in the same position so that helps too.
