Right rear window motor making noise Mondial t 89 | FerrariChat
Discussion in 'Technical Q&A' started by Lino, Nov 8, 2011.
  1. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    Hello,
    My car is in for service but enforce engine goes back in I told my mechanic to look at the rear right window motor. It always made a grinding noise and always needed help to go up.
    We are having a hell of a time trying to find are placement. We figured out its a Fiat part installed in a fiat Hugo can't find one. We at looking at having it rebuilt, has anyone eve tried it?
    Lino
  2. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    My mechanic has found a shop that may be able to repair/rebuild the motor. I will keep you all posted if it can be done.
  3. porphy
    porphy Formula 3
    1,210
    LouisvilleKY/Switzld
    Randall Gatz
    +1
  4. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    #4 Lino, Nov 11, 2011
    hello,
    I went to the shop where they rebuilt or shall I say fixed the motor and it worked much better. The shpo owner said that they replaced the front bearing and repositioned the shaft properly. he also said he was unable to change the bushing in the back because it would have been to difficult to reset. He also changed the brushes.
    We bench tested the unit at the garage and it sounded much better then before. So the motor for the window is going in and then the engine.
    I also included some pictures of ball bearings that have be put one by one. this does not look easy. It has Fiat stamped on the assembly and I think my mechanic says its the same as a Fiat Hugo. But its hard to locate apperently.
    Hopefully by Monday it should all be running.
