Right turn signal won't work | FerrariChat
Discussion in '360/430' started by Fearless Shifter, Sep 14, 2017.
  1. Fearless Shifter
    Mar 1, 2009
    98
    Laurens, S.C.
    "Brother" McDaniel
    A couple of times lately my right turn signal won't work. At other times it works. I have checked the bulb and the fuses in the trunk. Do I have a ground problem and would appreciate any ideas. its a 2003 F-1 Spyder
  2. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,734
    Just East of Weird
    Bob
    Does the left rear tail light work? They are tied together
  3. Dewinator
    Dewinator F1 Veteran
    7,623
    WA
    Shouldn't be a problem, you're just not an ambi-turner anymore. Just go left.
  4. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    It will very likely be the flasher relay. Its in the footwell area and relatively inexpensive and easy to replace. Its part number 213326.
    Hazard Flasher Pins
    |..[3]....[|]......[1].|
    |.........[2]..........|
    |.[6]...[--5--]....[4].|
    |.......[--8--]........|
    [7C] Relay Plug
    Wired Workshop On Power Input/
    Pin Manuals Relay Description Output State Notes
    2. Black (S40C - N ) : 31 -12v [Input] -12V from Battery (-ve) - Main Power Source
    4. Red (R - S70C) : 30 +12v [Input] +12V from Battery (+ve) - Main Power Source
    8. White/Black (12E - BN ) : 15L +12v Left Indicator Switch [Switched Input] (On/Off) Trigged by +12v (+ve) from Left Indicator Stalk being switched 'on', 0v applied when off
    3. White (15E - B ) : 15R +12v Right Indicator Switch [Switched Input] (On/Off) Trigged by +12v (+ve) from Right Indicator Stalk being switched 'on', 0v applied when off
    1. Violet/Black (ZN - 11D ) : HW -12v Hazard Warning Switch [Switched Input] (On/Off) Shorted to ground from Hazard Switch to ground (-ve) {actually to Pin 8 in 11D which goes to Harzards switch via connector}
    6. Blue/Black (S71C - LN ) : L +12v output Left Bulbs [Output] (On/Off) {Timed/Pulsed output @ +12vdc or 0vdc output for Left Hand Indicator bulbs +ve power}
    5. Blue (L - S47C) : R +12v output Right Bulbs [Output] (On/Off) {Timed/Pulsed output @ +12vdc or 0vdc output for Right Hand Indicator bulbs +ve power}
    Here is my pinout describing what the pins do. You could check the eletrical connections on the pins using a multimeter before ordering a new one...
    It was produced by SDC and I found it was actually shared with an Alfa Romeo of a similar vintage/year.
  5. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    And here is what it looks like..
  6. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    If your feeling like your insulted to pay upto $200 for a $20 Alfa Romeo relay I can fully understand it... Thankfully if open up the unit the relay itself can easily be desoldered and replaced for less $10, even by someone inexperienced with a soldering iron. This isn't state of the art electronics here and the solder joints are the size of dinner plates (looks like a kids school project !)
  7. Fearless Shifter
    Mar 1, 2009
    98
    Laurens, S.C.
    "Brother" McDaniel
    Thanks for your suggestions, the left signal works all the time. Exactly where do I find this relay ?? They don't call me Mr. Goodwrench !!!!
  8. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
