Rim and Tire Suggestion? | FerrariChat
Discussion in 'LamborghiniChat.com' started by 6spdHorse, Oct 5, 2010.
  1. 6spdHorse
    6spdHorse Formula Junior
    Mar 30, 2006
    483
    #1 6spdHorse, Oct 5, 2010
    HI,
    I recently purchased a 2008 Gallardo Spider and have the factory rims/tires on it,can anyone recommend the proper rim and tire size going to a 20 inch,in possible staggered off set,without it rubbing in the wheel wells and affecting any traction control?
  2. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,947
    The Cold North
    Tom
    John, leave the thing as it is. Change the look of the rim while maintaining the stock tire height and wheel size. If you have already put the 20's on the car and they are rubbing the wheel well--THEY ARE NOT THE CORRECT WHEELS AND TIRES FOR THE CAR!!
    The traction control/ABS systems are VERY sensitive in ANY modern car no matter who makes it. Once you start playing with rim and tire combinations you must make sure the ROLLING diameters are EXCATLY the same as factory. Else your wheel speeds vs. speedometer speeds will not match.
