RIM HELP!!?? | FerrariChat
RIM HELP!!??
Discussion in 'California (Southern)' started by AJUFC, Jul 11, 2007.
  1. AJUFC
    AJUFC Formula Junior
    Sep 11, 2005
    263
    Brea OC, Cali
    Just got my car washed at a local car wash across from my office and they used some sort of acid or something on my wheels and totally Fu*cked my RAD wheels up... chrome is peeling and is totally dull all over.... is this fixable guys???
    of course the car wash says it came in like that.... Idiots!
  2. Razzer92
    Razzer92 F1 Rookie
    Aug 4, 2006
    4,496
    sounds like your pissed off.
  3. Speedracer38
    Speedracer38 F1 Veteran
    Oct 11, 2004
    5,187
    Connecticut
    Jason Thorgalsen
    I would be to if that just happened.
    I hope you can get everything worked out ASAP.
  4. Modenafan
    Modenafan F1 World Champ
    Dec 19, 2004
    12,069
    Moorpark
    Jon
    Call Son Tran and see what he thinks. He's in Anaheim at 714-742-6856.
    Onsite Wheel Conditioning
  5. HRCVF750
    HRCVF750 Karting
    Jul 13, 2006
    233
    La Canada, Ca.
    M. Lyle
    Does he do curb rash as well on-site?
  6. luv2detail
    luv2detail Formula 3
    2,289
    North Carolina & SoCal
    Jason
    Are the wheels actually chrome or polished aluminum?
    Sometimes (lazy) people use hydrochloric acid to clean chrome wheels because it works great and cleans quickly. It's likely they used this. But you have to do it quickly and use lots of water, otherwise I believe it'll stain. And no matter how quickly you rinse, it's just plain bad for the brakes. I haven't heard of the chrome peeling unless it's a poor quality chrome wheel.
    If the wheels are uncoated polished aluminum, then they don't even have to use the acid for the wheels to stain. Many wheel cleaners will stain this type of metal. However it's fairly easy to bring them back to life with a good metal polish. If they're really bad, you may want to use the Mother's Mini PowerBall or Flitzz Ball or even a sisal wheel.
  7. AJUFC
    Sep 11, 2005
    263
    Brea OC, Cali
    Yes, you are correct.. .they are not chrome... they are polished... you described exactly what happened... where can I buy the powerball or Flitzz ball...? Auto Zone??
  8. 2mff
    2mff Rookie
    Sep 3, 2005
    16
    I just had my wheels refinished at Wheel Repair Specialists in Santa Ana http://www.wheel-repairs.com/
    My wheels have black centers with a 4 inch polished lip. After 29k miles they needed some help. WRS repainted the centers, polished the lips, and clear coated the entire wheel.
  9. Modenafan
    Dec 19, 2004
    12,069
    Moorpark
    Jon
    Yes. We have him come to our work to do the bosses wheels frequently. :)
  10. RoWis
    RoWis F1 Rookie
    Apr 19, 2006
    4,845
    Vancouver, B.C.
    How did you figure that out?
  11. Racer98
    Racer98 F1 Rookie
    4,766
    Encino.
    K-Fence.
    Post a Pic of the rim !
  12. rtking
    rtking Formula Junior
    Mar 5, 2006
    703
    Huntington Beach, CA
    Bob King
    First - make sure you're wheels don't have a clearcoat. If it does, you DO NOT want to use Power Metal to polish it. Using the Mother's Powerball Mini is fine - but you'll want to treat the rim just like paint since that's what the clearcoat is. Mothers has a couple of products for random orbital polishers called Power Polish and Power Wax. You could probably use both of those on the clearcoat. I use both productions and my Porter Cable random orbital polisher to polish/wax all my cars.
    If your wheel does not have a clearcoat, you can use Mother's Power Metal. It is very effective, but use it very sparingly or, better yet, practice on an aluminum sheet so you can get the feel of how to use the Power Metal with the Powerball Mini.
    Secondly - the Powerball Mini should be available from Pep Boys, Kragen or even Walmart. It attaches to your electric drill. Works VERY well - on aluminum bits and for polishing stainless steel sinks (when used in conjunction with Power Metal.)
    Bob
  13. Darryl
    Darryl Formula Junior
    Jan 4, 2006
    410
    Southern California
    Darryl
    He did and excellent job on my Ferrari and Carrera wheels.
    Daryl
  14. riozilla
    riozilla Formula Junior
    Jan 25, 2006
    596
    Austin, TX
    Son Tran is the best. He fixed my DB9 wheel and my Range Rover wheels in an hour and they look brand new. A real pro.
  15. OC Speed Junkie
    OC Speed Junkie Formula 3
    Aug 6, 2005
    2,473
    Southern California
    Joseph
    I know exactly what you are talking about. I have seen it happen many times in the past with polished multi piece wheels. I would discourage your from trying to fix it yourself and take it to a pro. I highly recommend Wheel Repair Specialists in Santa Anna.
