Rim out of round | FerrariChat
Rim out of round
Discussion in '458 Italia/488/F8' started by TUTTSF, Jan 10, 2019.
  1. TUTTSF
    TUTTSF Karting
    Sep 21, 2018
    167
    So. Cal
    I had new Michelin PS4S put on the 458
    today and my driver side rim needed nearly 8oz to balance. The tire tech showed me the rim spinning and you could see the rim was out of round.
    Is this fixable or should I purchase a new rim from ebay. The tires I took off were original Pirelli tires that came with the car but were cracking and showing dry rot and dated 2012.
    If you think it is fixable are there any suggestions for orange county ca rim repair.
  2. dwhite
    dwhite F1 Rookie
    Out of round like an egg or out of round moving left to right when spinning from a headon view?
    Reason I ask is I recently put some AMG rims on my MB and when I had new tires put on the guy told me the same thing . He said he had to put a bunch of weights on and it still was not perfect, there was a bit of vibration.
    I was concerned about the cars ride (was driving it from NY to FL to leave it there permanently the following week) and decided bring the car to a rim repair shop to have them fixed and they put all on a snap-on balancing machine which determines the balance and it differentiates the tire and rim. The result: rims were fine they rebalanced them and it drives perfect. $20 later I was done. It was like hitting the jackpot.
    Right before we left
  3. TUTTSF
    TUTTSF Karting
    Sep 21, 2018
    167
    So. Cal
    Straight on view while it was on the balance machine
  4. TUTTSF
    TUTTSF Karting
    Sep 21, 2018
    167
    So. Cal
  5. Newjoint
    Newjoint Formula 3
    Jan 17, 2016
    1,463
    Out of round rims can be balanced to minimize vibration but not eliminate it completely
    Safe to drive at normal highway speeds but at 9/10ths or more it adversely affects the car dynamics
    If the wheels can be corrected great but personally for such high performance cars I usually replace them for peace of mind
    Caeruleus11 likes this.
  6. Streetsurfer
    Streetsurfer Formula Junior
    Dec 16, 2015
    934
    near Chicago
    Ron
    Out of round is the first instance, out of true is what the second is called.
    boobernackle likes this.
  7. I’d be more concerned you were driving around in nearly 7 year old tires.
    You need to drive more.
    tekaefixe and peteficarra like this.
  8. TUTTSF
    TUTTSF Karting
    Sep 21, 2018
    167
    So. Cal
    I bought the '13 458 in Nov '18 with 4k on the clock put 500 miles on the old tires before changing them out. When I find a new rim and I get finished working on the house in a couple weeks I will be putting a lot of miles on this formally garage queen stallion =) one of the last perks of living in the peoples republic of Kalifornia is driving in the winter with the top down.
  9. Right on!
    Drive baby, drive. :D
    TUTTSF likes this.
  10. Caeruleus11
    Caeruleus11 F1 World Champ
    11,606
    You can have the wheel fixed so its round. I would also go to a place that has a road force balancing machine. I don't think the one in your video is road force.
  11. Solid State
    Solid State F1 World Champ
    10,577
    Maximus Decimus Meridius
    I wasn't aware you could make an oval rim round again. I have sent new tires back (TireRack) when my installer said they were out of round on a DD. In that case only shaving would get them round again and why bother just send them back. For the rim though, is there a machine that trims them or forges (squeezes) them round again? At high speeds the vibration of out of round is unsafe IMO. Also not good for suspension and steering components.
  12. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Looks out of round. I’d just get another wheel.
  13. Caeruleus11
    11,606
    Agreed all - uh- around lol
    I do believe there are wheel shops that can get the wheel back into round. I think it depends on what part is out of round- is it just the edge/ lip? Or is it across the entire wheel? But its probably better to simply get a new wheel. It really depends on the degree. I've had wheels fixed several times with no issues.
    No wheel nor tire is perfectly round. Unfortunately as you drive on metal wheels, they are always getting slightly out of round. Its a question of degrees. Thats why you want a road force balance. It will match the low point on the wheel with the high point on the tire. I once had a Pirelli tire with over 140lbs of road force- that is extreme! Pirelli took it back.
  14. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    Ferrari forbids straightening of bent wheels. That said, it doesn't look like the wheel has a simple flat spot on a rim lip from a small impact like a pot-hole, which can be straightened fairly easily. Looking at the video of the wheel, it looks like the entire outside drum of the wheel is not concentric with the inner mounting surface. It almost looks like the wheel was not mounted on the balancer correctly, but I am sure that it was.
    This means that the defect in the wheel is in the actual spokes of the wheel, causing the mounting surface of the wheel to not be concentric with the tire mounting surfaces. I would not have this rim repaired and would recommend replacement of the rim with a good used or new wheel.
    Road force balancing is a good idea. I am not too fond of Pirelli tires, as they always seem to need a large amount of weight to balance correctly. I have found that Michelins take very little weight to balance, sometimes none at all.
  15. dwhite
    dwhite F1 Rookie
    Thanks. Right, like the bicycle wheels I would attempt to true as a kid on my old 10 speeds(road bike).
  16. TUTTSF
    TUTTSF Karting
    Sep 21, 2018
    167
    So. Cal
    Looks to be the same case with my problem the rim was put on the balancer wrong. He did the 3 others before this last rim so did not think to take it off and remount it to the balancer.
    I had Novitec springs and spacers installed and needed an alignment so had them recheck the balance on that rim and tire. The result was 1oz to balance the wheel so dodged a bullet.
    I want to say thanks to all that chimed in to help me with this, I am new to Fcars so luckily the learning curve is not so steep with fchatters like you guys to help.
  17. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,889
    That is a severe imbalance.
