Hi, I have a LH threaded ring nut , size M32x1.5, on the layshaft of a M series transmission But the only available are RH threaded nuts. Anyone with a similar issue? Greetings, Charles
153059 I recently completed some internal work on an early 400GT differential that used (as I recall) that same sized LH thread/pitch nut. You could check with the folks at Ricambi to verify. Best, David
