roadholding | FerrariChat
roadholding
Discussion in 'Technical Q&A' started by lotusk, Dec 18, 2008.
  1. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    going slowly around a mini roundabout in perfect dry conditions today in my 355 when I applied some throttle....maybe 25% and the back end of the car swerved a lot.....corrected it with the steering but it was unnerving.................normal for a high powered car or is there maybe a setup problem with my car????????................is it good policy to be very careful of throttle when going around roundabouts.............even with those big fat tyres at the back..
  2. EnzymaticRacer
    EnzymaticRacer F1 Veteran
    Feb 27, 2005
    5,367
    Any number of things could have caused the back-end to kick out unexpectedly... older (as in years) tires/too much pressure in the tires/too little pressure in the tires/cold tires/cold roadway/some grass or something on the road/ accidentally giving it more throttle then you thought/suspension settings may be incorrect, ie toe, rebound, stiffness/ etc. or any combination of those factors... hard to say really.
  3. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    As Rob says, check tire pressures/age and alignment, specifically rear toe (should be in, not zero or heaven forbid, OUT) first.
  4. Skidkid
    Skidkid F1 Veteran
    9,623
    Campbell, CA
    John Zornes
    I'm with the tire pressure on this one. I just barely kept my M on the road one time because a rear tire was low when I entered a clover leaf. The rear end stepped out and I couldn't get it to hook up again even though I had the slide under control.
  5. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    +1 on tire pressure/tire condition as a starting point. I've seen the rear step out from just a little oil or antifreeze on the road surface, a little morning dew, light rain, dust or dirt, wet leaves. If you were going anti-clockwise around the roundabout, the tranmission tends to transfer more power to the right rear wheel, even with limited slip, enough so that it could break the tire loose and start the rear slipping. Doesn't hurt to have someone check the suspension if the obvious things all seem to be okay (i.e., tire pressure is good, etc.)
  6. maranello71
    maranello71 Formula 3
    Jan 23, 2004
    1,221
    Chicagoland
    Andre
    1) Was it wet or even slightly damp (you know, early morning damp)?
    2) Were the tarmac and the tires very cold?
    3) How old are the tires, and are they partially worn out?
    Temperature/moisture/tires are the three probable causes IMO
  7. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    totally dry................warm..........tyres great condition............maybe i should not have applied too much gas at that moment
  8. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,298
    Colorado
    Dave
    Hard to say, but going easy on the throttle in a powerful car is always a good policy. I know a guy who completely turned around his Ford GT just starting out from a light! The other thing to remember when applying the juice is to do so smoothly. Even if you are only giving it a quarter, squeeze the pedal rather than jab it. If the car is new to you, an alignment check is always wise.
    Dave
  9. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
  10. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    Try to duplicate in a parking lot or somewhere there's nothing to hit. Good chance you found a slick patch of pavement, maybe even some anti freeze or oil. It's not all created equal. Even on the race track you can walk around and scuff your feet wearing tennis shoes and feel where there is good grip.
  11. 62 250 GTO
    62 250 GTO F1 Veteran
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    How far did you have the steering wheel turned?
  12. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    If the tire pressure is even close to being right and the car is behaving normally, you might have hit a bit of coolant or oil dropped fromanother car and you didn't see it.
    Road and track had a yelow warning sign, many years ago, that cautioned
    "Motor Gently through the grease mud.. For there lurks the skid deamon".
    best of luck,
    chris
