roadside help from fchat | FerrariChat
Discussion in '308/328' started by Sledge4.2, Jul 24, 2010.
  1. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
    Here on the side of the road, tow truck on its way
    78 308, Pertronix
    Was stuck in traffic for one hour
    Both slow down light cam on, flap in airbox snapped shut, car kept running
    Both slow down lights came back on, airbox flap opened
    Did that once more, could hear the airbox flap snap shut
    Then she died, won't start
    When ignition key turn on I can hear fuel pump, but no dash gauges active
    Popped the airbox cover, manually goose carbs and gas is squirting from pump jets
    Thoughts?
    When you turn key to third position (fuel pump on) do the gauges activate (can't remember)
  2. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
    F'ing tow truck is one hour away
  3. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
    With key on fan blower motor works but windows dont
  4. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,919
    Atlanta
    John!
    Well, I can guess why the slow down lights came on. They airbox flap shut causing a rich condition overheating the cats. First thing I would check are the hoses to the airbox flap
  5. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
    No cats, slow down system not hooked up
    Seems to be electrical
  6. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
    Slow down lights and airbox flap closed at exact same time
  7. eurogt4
    eurogt4 Karting
    Apr 15, 2006
    243
    Sacramento, CA
    check fuses and relays for tightness, blown out, corroded, etc.
  8. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
    It took two hours for the two truck, apparenty someone jumped from the golden gate tonight, so traffic was bad.
    The fusebox: The upper connections of 1 and 2 are brown and melted. Not bad, but definately not good. Everything on those circuits are dead, which includes the electrovalve, instruments, and high temp control system, which explains the warning lights and the airbox flap behavior.
    While they are brown and melted, it still looks like there should be a good positive connection. Is a little brown and melting enough to shut that circuit down? Obviously it is.
    Also, what component on the 1 and 2 circuit is preventing the car from starting? the electrovalve? Ie, if you pull the 1 and 2 fuse will the car not start, or do i have another issue?
  9. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,393
    E ' ' '/ F
    Enzo Gorlomi
  10. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
  11. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
    Well the birdman fuseblocks arrived today. My sequence of events
    1) remove old burnt fuseblock
    2) install new birdman fuseblock
    3) go for a nice drive in the northern california sunshine
    4) recieve visit from CHIPS for noise pollution
    Still, all in all a great day!!
  12. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
  13. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,256
    Snohomish, WA
    Eric L
    Glad you got things working again Geno. These words from Birdman should ring in the ears of all 308 owners:
    "There are only two kinds of Ferrari OEM 308 fuseboxes: those that have left you stranded and those that will. "
  14. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    The relays should all be changed too, they're 25+ years old, cheap and easy to do. You can replace all for about $100.
    Between Birdman's fuse blocks and the relays , you can eliminate 95% of electrical problems in 308's.
  15. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
    The strange thing is, the car seems to run better, fire stronger. I'm sure there is nothing to it, but just like when i change my oil, the car seems to run better. Whats up with that?
