Robb's F355 Challenge Car History and Restoration | Page 3 | FerrariChat
Discussion in 'Challenge/GT Cars/Track' started by Robb, Feb 20, 2015.
  1. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,212
    Robb
    #51 Robb, Feb 25, 2015
  2. Robb
    Robb Moderator
    Feb 28, 2004
    14,212
    Robb
    #52 Robb, Feb 25, 2015
  3. KMR968Turbo
    KMR968Turbo Formula 3
    Nov 11, 2007
    1,001
    Calgary, Alberta
    Erik
    What do you intend to do with the exhaust? Leave as is? My car has 360 Challenge headers and a custom built muffler set up. Sounds OK but still not as mean as I like. My Challenge stuff is safely tucked away. Was considering a Capristo muffler but not sure of the cost/benefit analysis. I do love the F1 wail though. I'm thinking my headers might affect the power and sound but not sure how.
  4. Robb
    Robb Moderator
    Feb 28, 2004
    14,212
    Robb
    I love the capristo the best on a 355! I've inly heard them on street cars though so it might be even better with the lack of cats on the track car.
    My Berlinetta has a Tubi and it is great also.
    I'll let you know how it goes. I think it's hard to go wrong with any variant of 355 with any exhaust. The limit on db might dictate for us based on the track and their regulations.
    Robb
  5. dantm
    dantm Formula 3
    Nov 1, 2003
    1,103
    YYZ, BOS, SFO
    Dan B.
  6. Robb
    Robb Moderator
    Feb 28, 2004
    14,212
    Robb
    #56 Robb, Feb 25, 2015
    Drendel v Earle.
    Gooooo FCI... Although I like Houston too! :)
    Robb
  7. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    63,466
    Southlake, TX
    Rob Lay
    nice!
    FYI Steve Earle is user on FChat.
  8. Robb
    Robb Moderator
    Feb 28, 2004
    14,212
    Robb
  9. Robb
    Robb Moderator
    Feb 28, 2004
    14,212
    Robb
    Yes. I pm'd him a couple. Love his stories.
    Robb
  10. 308 GTB
    308 GTB F1 World Champ
    11,661
    New Jersey
    Barry Wolinsky
    #60 308 GTB, Feb 25, 2015
  11. Robb
    Robb Moderator
    Feb 28, 2004
    14,212
    Robb
    We have photos of its track history - and the bumps and bruises... :)
    So we're up for a spring cleaning.
    Robb
  12. Rothbauer_Racing
    Rothbauer_Racing Formula Junior
    Jan 11, 2007
    442
    Röthbauer GmbH
    #62 Rothbauer_Racing, Feb 26, 2015
    Robb,
    Does your 355 Challenge have the front support modification to allow the dual spring setup? The 99 Manual shows the required mod, I think it's due to the spring spacer (Item #32) to allow fitment when the car is ultra low with loads of camber.
    A picture of your front shock support area would be nice if possible?
  13. 360gtracer
    360gtracer Formula 3
    May 18, 2004
    1,022
    Steve Earle is one of my all-time favorite Challenge drivers - fast, successful, but more importantly, all-around super nice guy. Always jovial, never a bad word (that I heard) about anyone. Great fun to talk with.
    And you can tell him I said so! :)
    gp
    (p.s. - I have a few Steve Earle stories of my own! ;) )
  14. 308 GTB
    11,661
    New Jersey
    Barry Wolinsky
    Stanislaus,
    Robb should not have to make any modifications to his front shock mounts as his is a M.Y. 1998 car. The 1994 and 1995 F355s had thin 1.5 mm shock mounts which were prone to cracking with upgraded springs. This was corrected in M.Y. 1996.
    See my previous post and the two threads I referred to: http://www.ferrarichat.com/forum/143555425-post34.html
    Barry
  15. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Bumps my butt
    I just ordered all new steel for the front of mine. wheel houses, HL panel etc. Going to correct much of the "patina" I would call it nerfing LOL So the entire nose will be new under the carbon fibre. Going to measure it out on a frame machine to be on the money here
  16. KMR968Turbo
    Nov 11, 2007
    1,001
    Calgary, Alberta
    Erik
    Cool picture. Looks like a fighter plane waiting for it's engine.
  17. Rothbauer_Racing
    Jan 11, 2007
    442
    Röthbauer GmbH
    Barry,
    Thanks! I was not referring to structural modification. Yes, I have read and seen your previous post for the 95 cars.
    I was referring to the 99 Spec that requires the removal of bracing to allow for the CH helper spring perch/spacer (item #32 & #29) to fit. The Challenge Lower Springs are larger diameter and the fitment is tight, more so when it compresses in the turns.
    SRR
  18. 308 GTB
    11,661
    New Jersey
    Barry Wolinsky
    #68 308 GTB, Feb 27, 2015
    Stanislaus,
    I see what you mean now. When my front shock mounts were fabricated, the technician shaped and contoured the bracing so there would be no interference with the spring/shock absorber assembly. I can see how the stock mount would require cutting at "the dotted lines" to provide the necessary clearance.
    My original thin shock mount appears to have originally been cut and bent to provide that clearance. I have the 2200/900 lb springs.
    Barry
  19. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,833
    Richmond
    Pete
    Wow Barry, I don't remember seeing the before picture, yours were really bad compared to mine!
  20. 308 GTB
    11,661
    New Jersey
    Barry Wolinsky
    #70 308 GTB, Feb 27, 2015
  21. Rothbauer_Racing
    Jan 11, 2007
    442
    Röthbauer GmbH
    Thanks! Yep, it's a tight fit in there.
  22. 308 GTB
    11,661
    New Jersey
    Barry Wolinsky
    #72 308 GTB, Feb 27, 2015
    It sure is. I'd also like to see pictures of the M.Y. 1996-1999 upgraded mounts and Challenge modifications.
    My tech took careful measurements of the spring/shock components when he fabricated the mounts...
  23. 308 GTB
    11,661
    New Jersey
    Barry Wolinsky
    #73 308 GTB, Feb 27, 2015
  24. Robb
    Robb Moderator
    Feb 28, 2004
    14,212
    Robb
    #74 Robb, Mar 2, 2015
    OK. Back on topic.
    It has been a good week with more vintage photos arriving and paperwork to boot.
    We have assembled the historical logos on our car from the 1998 season. Here is a snapshot of how things are lining up. Obviously there will be some fine-tuning. It will be fun to see in full color. Being into photoshop has it's perks I guess...
    Robb
  25. Robb
    Robb Moderator
    Feb 28, 2004
    14,212
    Robb
    #75 Robb, Mar 2, 2015
