RobzWorkz #7: Improving the 328 Coolant System | Page 3 | FerrariChat
Discussion in '308/328' started by Robz328, May 28, 2011.
  1. Alfer
    Alfer Formula 3
    1,360
    NH/the Netherlands
    Menno
    Rob, you have no idea how much time i already spend reading your threads. Absolute great and valuable for amateur guys like me.
    I did not remove the fitting. Just cleaned it with a metal bruss and than it looked like above picture. I guess i was a bit lucky.
  2. Alfer
    Alfer Formula 3
    1,360
    NH/the Netherlands
    Menno
    Well, that is likely working for as well however i have no reason to take it out as it works o.k. I guess you removed yours because there was an issue of some kind with the sensor??
  3. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
    Hey,
    I'm currently performing the same procedure and have decoupled everything from the radiator: the fans, hoses, bolts at the bottom and top, but for some reason the radiator won't budge. Are there other bolts keeping it fixed? I can't see any other on the schematics and I'm afraid to damage the radiator if I give it a good hit to get it loose.
  4. stekkefun4
    2,232
    Belgium - Europe
    Got the radiator out. Damn! They should either give the designer death sentence, or the Novel price for physics; the things I had to do to get that thing out of there ...
