Rod Link Bushing (Silent Block) | FerrariChat
Discussion in '308/328' started by PhilB, Jan 24, 2010.
  1. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,315
    Southern New Jersey Shore
    Phil
    (I searched...)
    Has anyone replaced their rear "Silent Blocks" (the rear rod end link bushing) on a GTS? And if so, did you use an Energy Suspension or other manufacturer replacement part (in poly) or stock (rubber)?
    I have new OEM silent blocks, but everything else is (or ultimately will be) Energy Suspension poly bushings. Before I re-install the rear sway bar and related parts and hardware, figured I would ask if there was an alternate.
    I searched but did not find much chat on this particular part.
    Thanks,
    Phil
  2. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    If you're talking about the shift rod "silent block", "Verell" makes and sells them. They work fine.
  3. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,315
    Phil
    I think you're referring to the shift shaft bushings/seals. I'm looking for the suspension part.
    Thanks,
    Phil
  4. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Phil,
    Energy Suspension does not make these bushings (107335?) in Poly. However, I did a short run of these bushings through a custom manufacturer....and have a few sets left. Send me a PM with the details on your car and likely, I have what you need.
    Best,
    David
  5. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,251
    Indiana/North Carolina
    JIM
    #5 jimshadow, Jan 25, 2010
  6. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,315
    Phil
    #6 PhilB, Jan 25, 2010
  7. jimshadow
    Feb 19, 2006
    6,251
    JIM
    #7 jimshadow, Jan 25, 2010
  8. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,315
    Phil
    BINGO!
    I see you also got the grommets in poly - did you buy them to fit or have to buy something close and modify them?
    Thanks,
    Phil
  9. jimshadow
    Feb 19, 2006
    6,251
    JIM
    Nope, they were made to go there. They are slightly taller than stock rubber bushes, fyi. The more I think about it, the more I'm sure I got them from John Haller (JH355)
    JIM
  10. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    #10 Peter, Jan 25, 2010
