Rods! | FerrariChat
Rods!
Discussion in '308/328' started by ferrariowner, Sep 18, 2023.
  1. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    Well my new rods finally arrived. Just another step to getting everything back together.
    There are two pistons rods below. Which one is stock Ferrari and which is Carrillo?
    Ferraripilot likes this.
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,849
    Cerritos, CA.
    Left rod is original.
    ferrariowner likes this.
  3. Dr Tommy Cosgrove
    36,666
    Birmingham, AL
    Tommy
    How is the Carrillo better?
  4. miketuason
    Feb 24, 2006
    15,849
    Cerritos, CA.
    I would say better as in stronger as it has more material across the entire body of the rod.
  5. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,302
    Gold Coast, Aust.
    Patrick
    The H beam rod is stronger in torsion and lighter - just a few decades of engineering knowledge and modern production techniques.
    RodC328gts and ferrariowner like this.
  6. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,968
    Atlanta
    John!
    It's very common that a set of H beam forged rods weight 300 grams or so lighter PER cylinder. Combine that with a lighter forged piston and you're subtracting a pound or so of rotating mass from the crankshaft, which then can itself have more weight removed as it does not need as much weight to balance a heavy rod and piston. This stuff adds up and makes a measurable difference in power output.
    A 360 crankshaft and 308 crankshaft are pretty much the same size, but the 360 crank weighs a solid 10lbs less (31lbs vs 41lbs for 308).
    RodC328gts, waymar and ferrariowner like this.
  7. Rifledriver
    37,335
    Tommy, the weak link in any Ferrari engine is the connecting rods. In a stock engine they are pretty good but any Ferrari engine run real hard if it breaks is usually the rods. Very few who rebuild Ferrari engines professionally either for performance or just lawns at Pebble Beach use Ferrari rods. It is such a common modification Carillo has 2 catalog part numbers for rods for Ferrari. I just ordered a set of 12 yesterday.
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,852
    The twilight zone
    rods I think are
    Stock= 570g, depending on set
    Carrillo= 395g
    Ferrari Ti = 338g (at least mine are)
    Carrillo says only 103g is rotating which is about 1/3...I think that is about the for all, 2/3 reciprocating, 1/3 rotating
    My forged pistons are 300g....I think stock cast pistons themselves are lighter but way more fragile and the savings is in the wrist pistons but I can't find a numbers easily.
    While googling I saw aliexpress has h beam 308 rods for $1200, those are probably wonderful
    ferrariowner and Ferraripilot like this.
  9. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    I did drawings and got quotes under £100 each but decided to stick with original and just use ARP bolts and better pin bushes. If there’s interest I could get a few sets made.
  10. KTinCHS
    KTinCHS Rookie
    16
    Charleston SC
    Kent Tucker
    Would you mind sharing those part#s?
  11. Rifledriver
    37,335
    Its not the bolts that break. The people who know these motors best replace the rods. I have a low mile 330 here that already broke one rod.
  12. Rifledriver
    37,335
    The catalog is online and Ferrari is in the table of contents.
  13. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,679
    Toronto / SoCal
    Rob C.
  14. ferrariowner
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
  15. Dockboy
    Dockboy Formula Junior
    650
    Maryland
    Carrillo makes some great rods. About 15 yrs ago I had them make me some Cummins 5.9l rods for an 1,800 hp diesel drag motor that I was bending/breaking the stock rods in about every 10 or so passes! They held up great!
    Saabguy, NYC Fred and miketuason like this.
  16. Rifledriver
    37,335
    My machine shop does a lot of hotrod Cummins work. I see those rods at his shop all the time.
    1800 HP. Have any idea how much manifold pressure you were running? And max RPM?
  17. Dockboy
    650
    Maryland
    JL350 likes this.
  18. GSJFerrari
    GSJFerrari Formula Junior
    388
    Stuart, FL
    Greg Jones
    Just as an aside, we have a set of lightly used and in excellent condition set of Carrillo rods for a 308 as well as a standard/standard 308 crank. We'd let the lot go to good home for $1500. They were spares that came with a race engine of our's and we don't see us ever using them.
    -Prescott @ GSJFerrari
  19. Dr Tommy Cosgrove
    36,666
    Birmingham, AL
    Tommy
    What does a Carrillo rod for the 308 cost ?
  20. ferrariowner
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    About $2600 retail. USD
  21. ferrariowner
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    They were so expensive I just bought 1
    chrisrpi02 and Saabguy like this.
  22. Dr Tommy Cosgrove
    36,666
    Birmingham, AL
    Tommy
    Seriously?
    Because I can see that being ******** just as easily as it isn't ********.
  23. Rifledriver
    37,335
    I had heard 100lbs before but had no idea they were going 5000 RPM.
  24. Rifledriver
    37,335
    For a whole set. About the same as a new rod from Ferrari.
  25. Dockboy
    650
    Maryland
    Can't do 5k with a stock ECU and the rotating assembly needs to be balanced perfectly.
    They have come along way since I was involved in it.
    Check out Ryan Milliken's X275 car. 3,100 hp and it turns 6,300 rpm!
