roll cage for my 308 arrived | FerrariChat
Discussion in 'Technical Q&A' started by st@ven, Mar 13, 2011.
  1. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,318
    Germany
    Steven
    #1 st@ven, Mar 13, 2011
  2. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Looks excellent
  3. mustardfj40
    mustardfj40 Formula 3
    Jun 17, 2004
    1,142
    Northen California
    Ken
    What kind of tubing is it? I've installed a roll cage for my 4x4 and bolted it to the frame, I wonder on can you bolt/weld the cage down the frame on a 308.
  4. fatbillybob
    Aug 10, 2002
    29,275
    socal
  5. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    the front top bar will give you trouble, you should move it closer to the front glass.
  6. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    you might consider adding a horizontal bar at the corners near shoulder height. it will triangulate the main hoop and provide a mount for the shoulder harness. should be able to pick up considerable stiffness with this adder.
    rgds,
    Vincenzo
  7. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,318
    Germany
    Steven
    Just for the record. i did not make it myself but it was made and is certified by Sparco in Italy. For the seatbelts i will ad an additional bar behind the cage using the original mouting points.
  8. Champboat/Champcar
    Champboat/Champcar Formula Junior
    Jan 29, 2007
    885
    Freeport NY
    Eric T
    Looks good Steven , safety first, all cars should have a roll bar or roll cage IMO.
  9. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    luv it all! ... that dash looks really nice!
  10. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,833
    Cerritos, CA.
    Steven, you know the judges are going to deduct serious point from the cage right :D
    Anyway, are you planning to do some serious racing?
  11. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    That and I suggest he float the seat mounts to the roll cage for the same reason. Too easy for the seat to pull that floor apart and get strangled or injured by the belts. Keep the body and the belts tied to the same/strongest part of the compartment.
    Rick
  12. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    This is required by everybody now, as far as I know. It's just good practice.
  13. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,789
    Marin
    Geno
    Might be good for a mounting point but would do nothing for stiffness
