Rollover Valve or Fuel Pump | FerrariChat
Discussion in '360/430' started by coldwd, May 28, 2014.
  1. coldwd
    coldwd Rookie
    Dec 22, 2011
    14
    Halifax, NS Canada
    Dave
    #1 coldwd, May 28, 2014
    I am experiencing an issue which involves a bad fuel smell which is occurring..especially on the passenger side. With the top in the 1/2 way position, I was able to remove the access panel. This only allowed for access to the fuel pump. However, there is approx. 1 - 1 1/2 TBSPs of fuel sitting on top the the fuel pump (pic attached). I originally thought from previous threads, this was directly related to the "rollover valve" issue, but now am not sure as the fuel leak was/is visible on the fuel pump on one side of the car / RH pump only. Was contemplating tackling this one myself & ordering either the valves or a new pump from Ricambi, but unsure if its just the valves....or the pump...or both. Any advice would be appreciated as shipping to a Ferrari certified service garage is over $1,000 one-way.
  2. coldwd
    coldwd Rookie
    Dec 22, 2011
    14
    Halifax, NS Canada
    Dave
    Sorry ... Should have included this is for my 2004 360 Modena Spider. Thanks.
  3. Rifledriver
    37,099
    I can't see how it is being caused by the roll over valves.
    Dry it up and run it to see where it is leaking.
  4. vrsurgeon
    vrsurgeon F1 World Champ
    16,528
    Charleston, SC
    Curt
    As above... if there is fuel on top of your fuel pump...
    its a bad fuel pump. Replace it.
    Roll over valves will crack and smell of fuel but no we gasoline. They're just associated with venting of the tank.
    Fuel on top of pump = Replace it.
  5. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,949
    The Cold North
    Tom
    Looks it could be from the fuel line connection.
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    It might be from the fuel line.
  7. vrsurgeon
    16,528
    Charleston, SC
    Curt
    I thought that too.. and bought a test line when my passenger side pump went. turns out the plastic cracks by the nipple it connects to. That's where I'd put my $$$$
  8. up4speed
    up4speed F1 Rookie
    3,693
    Long Island, NY
    Chris
    Since the fuel is sitting on top, my bet is that it's either a leaking connection or a broken nipple at the connection.
    As others have said, clean it very well and run the engine while feeling around. It's most likely a VERY slow leak, so you may have to run it for several minutes before you get a shiny spot on your finger tip as you touch different areas.
    Good luck!
  9. coldwd
    coldwd Rookie
    Dec 22, 2011
    14
    Halifax, NS Canada
    Dave
    Thanks all who replied. Followed your combined advice & cleaned out the fuel after removing the access panel. The pressure regulator on the top of the fuel pump which is divided into 4 sections has one of the sections leaking. Fills up with fuel while running & ends up with the fuel running over the top of the pump as well.
    I ordered a new pump & gasket from Daniel & Ricambi which is expected to arrive on Monday. He mentioned during discussion this is unfortunately not an uncommon problem for this year / make.
    Looks to be a relatively simple replacement from other posts I have read. Will update following parts receipt & replacement attempt.
    Cheers,
    coldwd
  10. up4speed
    up4speed F1 Rookie
    3,693
    Long Island, NY
    Chris
    I'm glad you figured it out!
    Now you have an opportunity to do an instructional post on replacement of the pump ;)
    Don't forget to disconnect the power from the battery prior to replacing!!
  11. Motob
    Motob Formula 3
    Nov 11, 2003
    2,368
    Frederick, Maryland
    Brian Brown
    It is common for those pumps to leak there. The manufacturer changed the type of plastic that the pump cover/pressure regulator is made from. The new pump should have a amber/yellow plastic cover. If one pump is leaking, the other is probably not far behind. I would remove the other access cover and inspect it.
    Brian Brown
    Patrick Ottis Co.
  12. daveyator
    daveyator Formula Junior
    Jun 10, 2014
    292
    Yucaipa, CA
    Dave B
    #12 daveyator, Jun 28, 2014
    My new to me 2001 360 Spider had an inop fuel gauge right after I bought it. Apparently the fuel sender is combined in the fuel pump so you have to replace the whole thing. The dealer is fixing it for me (thanks CNC). The reason for my post is if you look at the 1st picture of this thread you notice the access panel in the 2004. 2002 and older apparently have no access panels. The tech says it makes a 4hr job into a 12 hr job. I was wondering if at some point you could get a newer panel and replace the old one? How common are problems with the fuel pumps on these things and wondering if it'd be worth doing in the first place? This feels a little frustrating as I did do some research before buying but something like this always seems to come up.
  13. GaryR
    GaryR Formula 3
    Dec 11, 2006
    1,006
    Valencia, Spain
    Gary R.
    Did you create a DIY post showing your process?
  14. Rifledriver
    37,099
    It requires a complete new, redesigned convertible top assembly. It would be less money to sell your car and buy a later one.
  15. vrsurgeon
    16,528
    Charleston, SC
    Curt
    +1.
    Once you replace it, you should be good for a very long time. Can't predict it... just happens.
