355 - Rollover valve | FerrariChat
355 Rollover valve
Discussion in '348/355' started by cactussed, Feb 21, 2023.
  1. cactussed
    cactussed Formula Junior
    Mar 12, 2008
    280
    Guys
    Has anyone sourced a replacement for the rollover valve on top of the charcoal canister?
    I've seen a little discussion in some threads but couldn't determine if anything had been found off the shelf?
    Ta muchly.
  2. Qavion
    Qavion F1 World Champ
    13,885
    Ian Riddell
    #2 Qavion, Feb 21, 2023
  3. cactussed
    Mar 12, 2008
    280
    This is the one I mean...
    Sits on top.
  4. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,154
    CT
    John Kreskovsky
  5. Rifledriver
    36,781
  6. Qavion
    13,885
    Ian Riddell
    That particular brand appears to be nil stock on Amazon and eBay.
    Note the barb on the downward connection of that aftermarket rollover valve is wider. If you find an aftermarket valve, you may have to smooth it out a little, or it will never be coming out again. The OEM rubber grommet is very hard.
    Why are you replacing it? I can’t imagine it gets much use :D
    308 GTB likes this.
  7. cactussed
    Mar 12, 2008
    280
    Mechanic told me mine was cracked, hence why I didn't have any pressure in the fuel tank.
    Its no biggie, just on the list of little jobs to sort out...
    Sadly we don't have Rockauto in the UK, so will have to dig around locally...
  8. Qavion
    13,885
    Ian Riddell
    Ah.. ok. I tried to find a suitable aftermarket one a few years ago, but they have a very odd shape and the clamp is designed to go in a specific spot. I didn't have much luck.
    See this thread:
    https://www.ferrarichat.com/forum/posts/146592908/
    It gives the dimensions and shows the valve sitting on 2 short legs (either side of the rubber grommet).
    The height is critical too, because it is close to the engine lid.
  9. johnk...
    Jun 11, 2004
    11,154
    CT
    John Kreskovsky
    But you do have auto parts stores? Take the old one to one and they should be able to find a replacement. Nothing exotic or "Ferrari" about it.
  10. Qavion
    13,885
    Ian Riddell
    I don’t know about the UK, but here in Australia, auto stores are relatively useless when it comes to staff knowledge of inventory. You have to come up with a part number or vehicle type or they look lost or hint that you are wasting their time…. despite the range of products here being far less than you have in the USA.
    All the hits on Google for rollover/slosh valves of that type point to the USA
    Here are my dimensions showing barb size and hose size.
    The only dimensions for rollover valves (on Google) I get are 3/8” (9.54mm) or 3/16” (4.7mm*)
    *barb size
  11. Qavion
    13,885
    Ian Riddell
  12. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I recall a mid 80s Nissan sentra and gtr works also. Worth checking. Find them on ebay.
    Sent from my SM-G990U using FerrariChat.com mobile app
  13. cactussed
    Mar 12, 2008
    280
    The UK is much the same. If you can't provide the registration number or part number, they aren't interested.
    People who Are able to look at a part and then find a similar match are few and far between...
    You get the odd nutter like me who's prepared to dig around and find alternatives... (mostly because I'm nearly always broke so have no alternative)...
  14. cactussed
    Mar 12, 2008
    280
    That EZ-Go valve is actually for a golf buggy, Be v interested to see if ti works.
  15. Qavion
    13,885
    Ian Riddell
    Yeah… Just realised after I got the receipt for it. Not hopeful. It’s probably half the size. Anyway, I’ll let the forum know.
  16. cactussed
    Mar 12, 2008
    280
    Sadly the 355 one is a different shape (turns through 90 rather than 180)
  17. Qavion
    13,885
    Ian Riddell
    Unfortunately, the rollover valve for the golf buggy turned out to be tiny. The pipes were 5 mm (top) and 6 mm (bottom). i.e. outside diameter. The top pipe inside diameter looked quite large, relatively speaking (3mm), but the bottom pipe ID was only 2mm.
    I know only vapours are supposed to go through there, but even so, that's quite small. It might get blocked relatively easily.
  18. cactussed
    Mar 12, 2008
    280
    Back to the drawing board....
    Qavion likes this.
