Roma “White Noise” sound from rear speakers | FerrariChat
Discussion in 'California/Portofino/Roma' started by timothymunro, Nov 15, 2022.
  1. timothymunro
    timothymunro Karting
    Jun 20, 2013
    74
    My Roma has a white noise sound coming out from both rear speakers when I get into it and it stays on after I turn off the engine.
    Also, it’s battery died after its first year.
    Dealer doesn’t know what the issue is.
    Has anyone experienced anything similar?
  2. SVCalifornia
    SVCalifornia F1 Rookie
    2,552
    Silicon Valley
    Keith
    Post up video of this?
    SV
  3. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,805
    San Jose, California
    White noise coming out of the speakers is indicative of a ground fault in one of the audio components.
    cenanesirtgen and ryalex like this.
  4. SVCalifornia
    2,552
    Silicon Valley
    Keith
    Possibly. But if the amplifier has a flaky ground I’d expect all the channels to be affected.
    Plus, I’d like to see if the rear channels work at all.
    And powered down, I’d expect the channels to quiesce. Unless he hasn’t opened the door yet or allowed the radio to time out.
    SV
  5. timothymunro
    Jun 20, 2013
    74
    Read speakers have loud white noise. Fronts don’t. It stays on even after I open the door to get out. It seems to start when I open the door and the electronics on the dash turn on.
  6. SVCalifornia
    2,552
    Silicon Valley
    Keith
    What is the source you’re connected on? AM, FM, XM, Bluetooth, other?
    SV
  7. timothymunro
    Jun 20, 2013
    74
    Nothing is connected when the static white noise is playing.
  8. SVCalifornia
    2,552
    Silicon Valley
    Keith
    Did the rear speakers ever work?
    From your description it’s likely the amplifier is toast. I assume volume control does not matter? You don’t have the rear channels gain set too high?
    SV
  9. timothymunro
    Jun 20, 2013
    74
    Volume control up or down doesn’t change the white noise and it’s volume - it’s constant.
    All speakers sound good when I play music.
  10. SVCalifornia
    2,552
    Silicon Valley
    Keith
    Noise is post preamplifier.
    I guess what I find interesting is the noise continues even after the door is opened. Which normally shuts down the power rail for the audio once you do a shut down on the steering wheel.
    Could be a noisy power rail but I wouldn’t expect front and rear channels to be different in that regard. Nor the grounding to be different within the amp.
    Only other consideration would be an induced noise from a cable running along side the speakers or to the amplifier from the preamp.
    No changes to the car? Bone stock? Has it always done this or did something happen to start it?
    SV
    Carbon Bits likes this.
  11. Sm25913
    Sm25913 Rookie
    Mar 6, 2022
    10
    Concord MA
    Simon Martin
    Can’t help re: white noise, but my battery was replaced after 6 months and having had software update at time of battery replacement, the infortainment system cuts out completely intermittently (every 20 mins or so for a couple of minutes) when connected to Apple CarPlay. Allows me to listen to the engine, but a little annoying when using Waze.
  12. timothymunro
    Jun 20, 2013
    74
    No changes to the car. 100% stock. Received Roma in late June 2021. It started around 6 months after I received it. Local dealer doesn’t know what to do,
  13. SVCalifornia
    2,552
    Silicon Valley
    Keith
    If it is source invariant noise and does not change with engine revs or motion you are pretty much down to a bad entertainment module.
    It is likely an all-in-one system so they gotta replace it.
    SV
  14. timothymunro
    Jun 20, 2013
    74
    Ferrari worked out what was wrong. My Roma’s amplifier is faulty, so a new one has been ordered from Italy. Hopefully fixed in January 2023!
    SVCalifornia likes this.
