Rons 348 Dyno | Page 2 | FerrariChat
Rons 348 Dyno
Discussion in '348/355' started by INTMD8, Aug 12, 2015.
  1. Kaivball
    Kaivball Three Time F1 World Champ
    Jan 11, 2007
    35,997
    Kalifornia
    I must put my car on a dyno...
    Kai
  2. Fast mustang
    Fast mustang Karting
    Nov 15, 2014
    173
    Island lake Il
    Ron
    I sure glad where getting some feed back to see where these cars dyno at
  3. KevZep
    KevZep Formula Junior
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    This is deliberate, you have to remember the car is not moving so there is no ram-air effect, if you were to look at the AFR on the road at actual speed, the AFR would be perfect.
    This is something we have seen tuners often screw up, they set the top end too lean, when the race car is pulling on the track in the high speed sections, they run dangerously lean and we have seen engine failures.
    Any decent tuner knows this.
  4. Mark HT
    Mark HT Rookie
    39
    Mark HT
    Any half decent engine management system has no problem at all compensating for a miniscule increase in air density due to "ram-air effect". Any decent tuner knows this. :rolleyes:
  5. ChoonHound
    ChoonHound Formula 3
    2,271
    Saint Michaels, MD
    Lucas
    Yeah, the ram air thing is baloney. I’m sure it’s been disproven a million times.
  6. KevZep
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    Not when these cars were made, nowadays yes, back then no.
    I'll connect the gear up and do some runs on the road to prove it, happy to do that.
  7. KevZep
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    I'd suggest keeping an open mind, it is a real thing, I have seen it with my own eyes on gear I trust.
    What you are suggesting is the air pressure through the intake system, and in the case of the 348, one which is part of the car's aerodynamics at speed is no different than the car standing still with a fan in front of it?
    I just hope I dont get caught speeding and lose my license...lol....
  8. ChoonHound
    2,271
    Saint Michaels, MD
    Lucas
    This is a silly video and perhaps not perfectly scientific, but if you watch it you’ll see that it takes A LOT of forced air to effect the performance of an engine. What you get at 80mph is inconsequential.
  9. KevZep
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    It is a known thing, I don't think thats a good example, you need to actually drive the car on the road.
    For example, why do you supposed during the evolution of F1 cars, there have been occasions where the governing body changes the rules to reduce the area and height of the air intakes, which have always been around reducing the ram air affect?
    Its happened numerous times....in the interest of reducing horsepower, forcing more air in, means you can put more fuel in.....more power.
    But at the end of the day, you can believe what you choose, and all good, we dont having to get into a pissing contest, but in my case after being around a guy most of my adult life who tunes race/rally cars, I have seen how this can affect things at speed, on the track/road.
    You can lean the car out in the top end if you want, but I wouldn't.....
    We can agree to disagree and we can be okay with that.
  10. ChoonHound
    2,271
    Saint Michaels, MD
    Lucas
    No animosity, just a good discussion.
  11. KevZep
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    Absolutely, its good to have discussions, I always like your contributions.
  12. Mark HT
    Mark HT Rookie
    39
    Mark HT
    They use a MAF sensor the same as most new cars sold these days.
    The situation you're talking about could arise in a setup that used Throttle Position vs RPM for load sensing without any pressure compensation. This is very bad practice as it wouldn't even compensate for changes in altitude.
  13. KevZep
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    [Q
    MAF is not in use on WOT, its using the fuel map. If you did a dyno run using light to medium throttle then yes, the MAF's in conjunction with readings from the O2 sensors in closed loop will compensate and you'll see a leaner AFR for economy and keeping the greenies happy, since we are doing the runs with WOT, then this is a different story...
    Newer cars are now using wide band O2 sensors with far more advanced control over the fuel system than what the dirty old 80's Motronics were capable of with the narrow band O2 sensors the 348 is using.
    But the old Motronics still do a pretty good job, and I was pleased to see it running 12-12.5:1...Last thing you want to see is the engine running lean...
    Ferrarium likes this.
  14. Mark HT
    Mark HT Rookie
    39
    Mark HT
    What are the axes of this fuel map?
  15. KevZep
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    Not sure what you mean by "axes".
    All ecu's have ignition timing and fuel maps. Which is a table consisting pre determined values for the injector pulse cycles at different RPM vs Throttle position and possibly map sensor, and the same for the ignition table. They would have developed this on their engine dyno. The reason the engine is not using this below WOT is simply for fuel economy and to meet emission standards....this is the "max power" function, "screw the emissions" type thing.
    You can look up how the ECU works in the workshop manual, I haven't gone into it in much detail, I'm recalling from years of fitting and tuning engines with aftermarket ECU's...
  16. ChoonHound
    2,271
    Saint Michaels, MD
    Lucas
    I think he means axis.
  17. Mark HT
    Mark HT Rookie
    39
    Mark HT
    Axes is the plural of axis
    ChoonHound likes this.
  18. Mark HT
    Mark HT Rookie
    39
    Mark HT
    To save you the effort of looking it up, here is a couple of quotes taken directly from the F355 2.7 manual. I assume 348 is the same:
    Hot wire air flow sensor
    • Engine load, and hence the volume of air intake, is detected through the signal generated by the air flow sensor (necessary to meter the quantity of fuel).
    • In other words, the ECU completely ignores the potentiometer signal and it is not used for any regulation.
    Note: if the air flow meter malfunctions and provides information which is incorrect or recognized by the E.C.U. as implausible, the "recovery" procedure is activated. Under this, the signal from the potentiometers on the throttles is analyzed to establish when the throttles open and thus the amount of air taken in by the engine. In this case the regulation is less precise than that obtained using the flow meter, but it is however sufficient to keep the car running efficiently and prevent it stopping.
  19. KevZep
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    MAF is inactive at WOT. It uses the Fuel and ignition map.
  20. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,756
    Because teh F1 guys can run enough tests to get it right, and the average car guy cannot.
    Ram air enters the system fast, fast air has low pressure (Bernoulli) so you need a large box into which this air can flow so it can slow down before it reaches the engine intake. most cars do not have a big enough volume to put this box, so most car add-ons fail to deliver any power improvements at all. Cooler air is often achieved, but converting ram intakes to power takes considerable effort.
    While this is true in theory (when theory is properly applied), if fails in practice most of the time. You have to get the fast moving air to slow to nearly no movement at all to achieve a pressure increase--which is what puts more air into the cylinders.
    I agree that the theory works, but is more difficult in practice than in theory.
  21. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    So your saying all those 60's muscle cars with "ram air" didn't add 50 whp due to that. I know a bunch of former hippies who swear the ram air makes a ton of power. Especially if it's got a hemi in it!
    [emoji14]
    Sent from my SM-G990U using FerrariChat.com mobile app
  22. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,823
    Lake Villa IL
    I plan to add "ram air" (well, through the firewall/cowl) on my 60's hemi musclecar but more so for the purpose of cold air.
    I've read a good system is around .2psi at 100mph so not much but better than nothing :)
