Roof Fault | FerrariChat
Roof Fault
Discussion in 'California(Portofino)/Roma(Amalfi)' started by Bobby328, Aug 9, 2021.
  1. Bobby328
    Bobby328 Rookie
    Oct 30, 2005
    19
    Hi Guys,
    California 30 parked up in the garage, came to it next day and the roof had put itself down.
    Took it to the local dealer and not faults found, 4 weeks have now passed.
    Yesterday went out, all’s fine with the car, parked up and locked the car and when I came back the roof was down again.
    Any ideas please
  2. Redneck Slim
    Redneck Slim Formula 3
    Mar 10, 2011
    1,652
    Palo Alto,CA,USA
    Walt Kimball
    Does your car have the mods4cars module installed,perhaps by a previous owner?
    tomc likes this.
  3. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    Maybe someone in your household is messing with you?
    Faulty switch perhaps?
  4. 695
    695 Formula Junior
    Mar 19, 2021
    359
    Denmark
    Chris
    Sounds like an aftermarked comfort open module like Redneck Slim says
    Check if you can do this with your remote
  5. Bobby328
    Bobby328 Rookie
    Oct 30, 2005
    19
    Not that I know of, it only works if you keep you finger on the switch.
  6. Bobby328
    Bobby328 Rookie
    Oct 30, 2005
    19
    As other systems have to be in place for the roof to work normally I guess that would rule out a faulty switch.
  7. Bobby328
    Bobby328 Rookie
    Oct 30, 2005
    19
    Good video, thanks. As I have to keep my finger on the switch I guess the car has not had this fitted.
  8. Bobby328
    Bobby328 Rookie
    Oct 30, 2005
    19
    opps been posting to the wrong replies, wish the roof was that easy to fix.
  9. vjd3
    vjd3 F1 Rookie
    2,750
    Massachusetts
    Vic
    Some people say that the top will operate if you turn and hold the key in the drivers' door -- I don't think that worked on my Cali 30 and have never tried it on my Cali T. However, if it does, then it could be some sort of malfunction with whatever ECU controls that feature.
    If someone did install one of those aftermarket modules, they should have given you the remote that goes along with it to one-touch operate the top. I suppose it's conceivable that someone nearby has one of their modules on their own convertible, and when they operate theirs it is operating yours because it happens to share the same frequency. That seems unlikely but you never know.
    alex likes this.
  10. Redneck Slim
    Mar 10, 2011
    1,652
    Palo Alto,CA,USA
    Walt Kimball
    Did you try to operate the roof using your Ferrari fob/key as shown on the video? Alternatively,you could see if the module has been installed by removing the cover in the trunk as shown in the installation manual.
  11. SLViper1
    SLViper1 Formula Junior
    Mar 25, 2014
    767
    Nashville/Destin
    Steve
    Key in the drivers door lock will open/close the roof on the Cali T
  12. 695
    695 Formula Junior
    Mar 19, 2021
    359
    Denmark
    Chris
    Can confirm that key in driver door lock will also open/close the roof on a 2011 Cali - why they have not implemented that to work via the keyfob remote I do not understand.
  13. alex
    alex Formula Junior
    Dec 19, 2003
    699
    Crystal Lake, Illinois
    Alex
    I didn't know this. Is it mentioned in the manual?
  14. alex
    alex Formula Junior
    Dec 19, 2003
    699
    Alex
    Bobby328, have you figured out the problem?
  15. 695
    695 Formula Junior
    Mar 19, 2021
    359
    Denmark
    Chris
    Don't know, just tried the key and it worked :)
  16. Bobby328
    Bobby328 Rookie
    Oct 30, 2005
    19
    No, the only thing I can think of is a fault in the control module.
  17. Alan Jones
    Alan Jones Rookie
    Jul 18, 2019
    4
    Alan jones
    Hi Guy’s,
    Any updates as, I’m having same problems on 2012 California 30 .
    Walk away with key in my hand and roof goes down. Lock car and walk away and roof goes down and alarm goes off.
    Then it seems fine for a while. Maybe a couple of months which seems to the way the fault comes back.
    Had car 4 years, 25 k miles no problems until last year and although it stopped when I fitted new battery it’s now come back.
    Car used regularly and otherwise a fantastic trouble free California.
    Going to remove and send away Boot module for testing but, any thoughts from other California owners please
  18. bb2thdr
    bb2thdr Formula Junior
    Dec 23, 2021
    336
    Scott Bialik
    Maybe it is the battery. Do you have one of the cardmod modules inside that lower the roof with the key fob? Perhaps that is acting a bit wanky with a sudden drop of battery voltage.
    LARRYH likes this.
  19. LARRYH
    LARRYH F1 Veteran
    9,675
    virginia usa
    with a California pretty much any crazy electric issue .. The first thing you should do is make sure the battery is FULLY charged then see how it goes.. IT could have a bad tender or if you do not keep it on a tender ... My bet is its the battery
    alex likes this.
  20. Alan Jones
    Alan Jones Rookie
    Jul 18, 2019
    4
    Alan jones
    Update guys.
    New battery was fitted and also plug Ferrari battery tender in but using car during winter and it seemed ok until I started driving it a lot more now.
    It also goes down when boot parcel shelf is up when car is locked.
    Any thoughts please
  21. Alan Jones
    Alan Jones Rookie
    Jul 18, 2019
    4
    Alan jones
    Hi, As you can see I’m having same problem any updates on how your getting on with your problem please thanks
  22. bb2thdr
    Dec 23, 2021
    336
    Scott Bialik
    Then there is a problem with the boot parcel position sensor. Did you follow the replacement battery start up procedure?
    tomc likes this.
  23. Alan Jones
    Alan Jones Rookie
    Jul 18, 2019
    4
    Alan jones
    What is the Start up procedure please.
    When shelf is up, roof will not operate so, sensors are working.
    The roof every now and again decides to operate. Car can be locked or unlocked, it makes no difference.
  24. bb2thdr
    Dec 23, 2021
    336
    Scott Bialik
    There is a procedure in the owners manual of how to reset all the systems after disconnecting the battery.Its called Battery Sensor Calibration.
