Roof hydraulic leak spider f360 | FerrariChat
Discussion in '360/430' started by De Janus, Apr 16, 2023.
  1. De Janus
    De Janus Rookie
    Sep 10, 2016
    1
    Hello, I have a problem with an hydraulic leak on the front side of my spider roof, the oil drips on the passenger seat. Does somebody know how I can repair it? The roof is closed, can I open it? Thanks for ansering.
  2. Michael_1982
    Michael_1982 Karting
    Mar 15, 2020
    93
    Perth
    Michael
    Probably best not to open it and you will likely have more fluid leak through.
    Suggest getting in contact with Claus from https://www.tophydraulics.com who will be able to guide you on the process on removing the leaking cylinder and getting it rebuilt.
    Mel Spillman likes this.
  3. priericky128
    priericky128 Formula Junior
    627
    St. Louis MO
    Rick
    There is a trim piece with will pull off. Realize it is probably full of oil that leaked out of the cylinder tho so be careful. If you just have one then probably better to send off but it’s the same as a merc cylinder so you can swap it with a new one too. Fishing the lines is a little bit of a pita but not terrible.
  4. netsec
    netsec Karting
    May 5, 2022
    101
    Henderson, NV
    My front latch cylinder has a nasty leak. Will be sending it off (along with the two secondary - minor leak on left) off for a rebuild/reseal this weekend.
    Plan is to use these guys:
    https://cabriolethydraulics.com/
    Hoping a detailer can get the top cleaned up without much drama.
  5. Alpintourer
    Alpintourer F1 Rookie
    Jul 20, 2013
    3,793
    The Low Country
    Dave Steven
    Had same problem. Also used Top Hydraulics. Shipped cylinders Monday, they were back in my hands rebuilt, Friday.
    netsec likes this.
  6. ksanjana
    ksanjana Karting
    Oct 28, 2014
    112
    Houston, TX
    Best people to tackle this issues hands down!
    netsec likes this.
