Rotor Thickness | FerrariChat
Rotor Thickness
Discussion in '360/430' started by English Rebel, Dec 27, 2013.
  1. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    My front and rear rotors measure 1.125" thick with no deep grooves. Is it safe to say that they can be resurfaced?
    Alan
  2. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,447
    whats the minum of the rotors?
  3. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    I was told some time ago it is not a good idea to re-surface drilled rotors, not sure why ...
  4. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    That's what I was asking (well implying).
    Alan
    I've no idea why either.
    Alan
  5. Chiaroman
    Chiaroman Formula 3
    1,687
    New Jersey
    I had my rotors turned at a Ferrari Dealer.
    They did not do it in house...Simply farmed it out.
    Good luck.
    P. S.
    Maybe while everything is apart you can have the brakes striped and repainted???
    Check the brake pads also...The list on these cars never ends?!?!?! LOL!!!
  6. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    Rotors that have been turned will be more prone to overheating and warping. On the advice of people smarter than me, I've just replaced pads until the rotors were shot. They will bed into existing grooves.
    Dave
  7. blkdiablo33
    Jul 12, 2004
    4,447
    Inside the rotor there's a minum thickness can not go below that but they can be resurfaced
  8. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    In Europe these are popular particularly for corroded discs or where run out is causing issues. I'm not sure if there is anything similar in the US.
    Pro-Cut : On-car brake lathes, quickly resurface the brake disks
    The minimum disc thickness is in the WSM also.
    I bought new Brembo rotors for the front of mine for £65 (approximately $100) each. It generally isn't cost effective to do anything but replace them here. The only difference was the centres needed painting in zinc primer.
    Edit. US website....
    http://www.procutusa.com/index.aspx
  9. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Okay so what is the minimum thickness?
    Alan
  10. tazandjan
    39,159
    #10 tazandjan, Dec 28, 2013
    Alan- You can download a 360 Spider WSM at ferraridatabase.com. Wear limit is 26 mm or 1.024", so you can turn your rotors if they need it. Here are guidelines on whether your rotors are useable.
  11. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Thanks Terry. So if the wear limit is 1.024 then it looks as if I have about 0.10" (0.05" each side) of metal that can be removed (as long as there are no cracks per the WSM).
    Alan
  12. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    #12 Need4Spd, Dec 31, 2013
    I tried that, but ended up with incurable brake squeal. The fixed caliper design of the Brembos (as contrasted with the floating caliper design of many cars, such as BMWs) aren't very forgiving in terms of brake noise. The only way to achieve quiet is to make sure the rotors are true (either have them resurfaced or get new ones). Last time around, I got these StopTech rotors.
  13. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    I seems as if you are being contradictory -- rotors need turning to make them run true but when you turned them you got incurable brake squeal. I'm confused.
    Alan
  14. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    Re-read his post. He said that if he didn't turn the rotors but let pads bed into existing wear pattern on rotors he got squeal.
  15. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Correct.
  16. hardtop
    Jan 31, 2002
    11,294
    Colorado
    Dave
    I never had that problem.
    Dave
  17. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Ah now I see -- he was referring to another post -- sorry my bad.
    Alan
