Rotor wear | FerrariChat
Rotor wear
Discussion in 'Technical Q&A' started by fga4, Jul 6, 2018.
  1. fga4
    fga4 Karting
    Jan 2, 2017
    119
    SF Bay Area
    Jerry Cellilo
    I'm looking at the rotors on my F430 with 20k miles and note a lot of scoring. Is this normal? The pads are at about 50%. The pre-purchase car inspection mechanic did not raise it as an issue.
  2. fga4
    fga4 Karting
    Jan 2, 2017
    119
    SF Bay Area
    Jerry Cellilo
    Forgot to add that this is a 2008 so I assume I am looking at carbon fiber. Very expensive to replace.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,947
    Central NJ
    Dominick
    Hard to tell from pic .. but I do not see flaking or pits from pics .. are they fairly smooth ?
    Sent from my Moto G (4) using Tapatalk
  4. fga4
    fga4 Karting
    Jan 2, 2017
    119
    SF Bay Area
    Jerry Cellilo
    I compared to other cars with similar mileage and the 430's are rough. Others are smooth. But they are steel not carbon ceramic. Thinking it has to do with the carbon. Might need to know the typical life of carbon ceramic rotors.
    Sent from my Z1 PRO using FerrariChat.com mobile app
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,947
    Central NJ
    Dominick
    With normal driving ..life time of car .. track ..maybe 10 days at track
  6. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,732
    I still see the original machine marks on the carbon ceramic surfaces.
    A) they are just fine
    B) they will continue to last a long time.
    I was getting 25-30 track days on my F355 brakes with one trip to the lathe about 1/2 way through.
    I only got 5 track days on a set of pads, though.
  7. fga4
    fga4 Karting
    Jan 2, 2017
    119
    SF Bay Area
    Jerry Cellilo
    Thanks. Not sure if the car was ever tracked but I don’t plan to. So with 50% of pads driving maybe 3-4K a year I’m good for a while.
  8. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    What do the pad surfaces look like?
  9. Motob
    Motob Formula 3
    Nov 11, 2003
    2,370
    Frederick, Maryland
    Brian Brown
    Those rotors look fine for CCM brakes. If they were tracked or used very hard, they will develop holes or pits in the surface (which yours do not have). The percentage of life remaining of the rotors is calculated by the instrument cluster and should be looked at during a normal maintenance service using a Ferrari specific diagnostic computer. They typically do not show wear on the friction surface, but lose mass over time. Rotor replacement is determined by looking at the calculated wear in stored in the instrument cluster memory and weighing the rotor to see if it is below the replacement weight.
