Rough idle after headers installed | FerrariChat
Discussion in '360/430' started by Tom brewer, Sep 10, 2022.
  1. Tom brewer
    Tom brewer Rookie
    Oct 4, 2018
    15
    Tualatin Oregon
    Thomas Brewer
    Yesterday I had replaced my cracked manifolds with a set of Fabspeed headers on my 05 F430. I drove the car about 20 miles when I noticed a very rough idle. When I pressed the throttle, there was hesitation, but it smoothed out at about 2k. I am taking the car back to the shop on Tuesday, but until then, any ideas on what may be going on?
  2. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,111
    Josh @jtcarprojects
    Exhaust leak making a lean condition
  3. LorenzoR
    LorenzoR F1 Rookie
    Yes double check for leaks and did you get your ecus tuned?
    RANDY6005, Tom brewer and Marcoboxer like this.
  4. Tom brewer
    Tom brewer Rookie
    Oct 4, 2018
    15
    Tualatin Oregon
    Thomas Brewer
    I will be doing the ECUs in about a month. I am waiting for my exhaust to show up.
  5. BlacktopRacing
    BlacktopRacing Formula 3
    1,002
    Pittsburgh
    Dale
    When you say you replaced your cracked manifolds, do you mean you personally ir this shop you mentioned? Either way, sometimes the stud nuts need retightened after the first drive or two. Also, recheck the 4 O2 sensors. Finally, was antiseeze compound used?
  6. Tom brewer
    Tom brewer Rookie
    Oct 4, 2018
    15
    Tualatin Oregon
    Thomas Brewer
    Could you please elaborate on what you mean “you personally ir this shop you mentioned”? I am not sure if they used antiseeze. I will be asking the shop these questions when I return it.
  7. Kent Adams
    Kent Adams F1 Rookie
    3,279
    Did you drive it just that once?
  8. one4torque
    one4torque F1 Veteran
    5,723
    Houston
    One4torque
    See if they installed new donut ex gaskets between the headers and cat pipes.
    I tried to reuse mine and they were too compressed and cracking so I had an ex leak in this position.
    If you can scan you car… you can better diagnose the issue. Was it caused by install? Or something failed at same time?
    if shop does not have a scanner then they might have trouble.
    I use obd facile, it scans both banks
    Check for codes and lt and st fuel trims.
    Gl
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,961
    Isle of man- uk
    First off did you check the flatness of the new manifolds with a straight edge before they were fitted, if so then try a thin feeler gauge between the head and the manifold to see it is compressing the gasket. Fitting this sort of thing you need to be checking with feeler gauges as you nip it up. After that gas tightness of sensors and donut joints into the cats are next
    RANDY6005 likes this.
