Rough running Testarossa | FerrariChat
Discussion in 'Boxers/TR/M' started by Andy T, Nov 11, 2004.
  1. Andy T
    Andy T Karting
    May 31, 2004
    56
    Sheffield - England
    Andy
    My '91 21k mile Testarossa runs roughly on a light throttle opening up to 2,500 rpm. It seems 'snatchy' and there is a lot of shunt in the transmission. It runs ok when the throttle is opened wide, and at higher revs. I thought this may be a manifold airleak perhaps, but has anyone else experienced it and what are the other possibilities?
    TIA
    Andy
  2. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    I just changed and Flushed my coolant system and have these exact symtoms. Everything was perfect before. What can it be?
    Please help !
  3. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    It could be many things....
    But first you need to check/set the butterfly gaps to be correct (.003"), and perfectly synchronise the throttle linkages to have balanced vacuum at idle and at small throttle.
    Then the mixtures need to be checked. A UK car is adjustable but US spec is different, so you need to consult your manuals.
    If the engine is balanced and tuned correctly (0.7-1.2 %CO at idle of 1000rpm), then it should be pretty smooth. The K Jet (very early) cars can surge/hunt a bit while warming up as the control pressure reg's get out of synch with each other, but the KE cars are much better.
  4. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Ferrarifixer, I've noted the same problems with my BB512i since I got back from the FFQC...what do you suppose it is?
  5. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Dear Andy,
    I posted this in the Tech section
    Shamile Shams Kassam II
    As y'all know, I'm chasing down some problems on my TR ever since I did a coolant change.
    If your TR has a jerky uneven push-pull feel when driving, it may feel like the transmission but (in my case ) was an engine miss. Most of us are used to what a miss feels like in a V 8. A flat 12 exhibits a very different feel.
    OK, the TIP of the day!
    If you are chasing a miss, check the cables going into the distributor cap. I know what you're thinking....it screws in, that's probably the best connection there. The way the cable is held is by a screw which is really a pin that pierces the wire and clamps the wire in the cap. ( screw is in each contact point of the distributor contact ) This connection is succeptible to burns in the wire at the pin and can create great resistance or complete loss of connection. I spoke to Magnicor when ordering a new set of wires and they said that the Ferrari Cap was an inferior design as it leads to burns and lack of connection. They said that even their wires were not immune to this problem.
    What I have found, leave a little excess wire so you can snip and reinstall if you find the resistance has gone up.
    I had a complete loss of contact on #6 and resistance in the M ohm range for #12 and #1. After snipping and reinstalling (the old wires ) I was able to get a fairly even resistance range for all my wires. My " OLD " wires were newly installed during a major service only 3 years & 10,000 miles ago. CHECK YOUR CONTACTS !
    Shamile
    Freeze...Miami Vice !
  6. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    It turned out to be a vacuum leak causing my Boxer to surg while driving at a constant speed. It was a hose that had came lose on the intake plenum. I put the hose back on and no more surg.
  7. Testarossa1
    Testarossa1 Karting
    Jun 15, 2007
    229
    Clive
    Hi Shamile
    After getting my car running again with help from this great forum:)
    I have had this exact issue you describe here-and want to get it sorted (my local indy has tried to diagnose it several times without success) they are now histiry after several sloppy incidents. Could you possibly post any photos of the dizzy work mentioned as I am a novice ( although gaining experince quickly-and lovin it!)
    Thankyou
    Best regards from across the pond :)
    Clive
    tr boy
  8. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,292
    Mel
    Clive, did you also work on the coolant system ?
    Did you check the (blue) temp sensors ? Just unplug one by one and see if anything happens...
  9. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,877
    Bologna
    I had the bucking bronco 91 TR syndrome too. An easyish fix. One oxygen sensor was giving bad signal. Where the coolant drains from the right side head it can splash on the o2 sensor connections. Clean, dry and reattach. It clears out at higher rpm because the sensor signal goes off so far that the KE eventually disregards it and the car runs better. Mine cleared out at 3000 rpm with a sudden jolt. If you want to check if this is the issue:
    Get the car warm and drive it.
    Unplug both o2 sensors
    Repeat. Note any difference.
    On mine that cured the main shuddering issue, but it only was completely cured when I replaced the sensors.
  10. Testarossa1
    Testarossa1 Karting
    Jun 15, 2007
    229
    Clive
    #10 Testarossa1, Mar 21, 2011
    Hi Mel and John
    Thankyou for the fast replies
    Ok here goes!! Remember the most hands on up until last week was changing a fuse (shameful i know)
    Also my car is late euro KE jet Without lambda and CATS engine # F113B
    Forgot to mention sometimes it is worse when engine is hot
    1. No coolant work
    2. What and where are the blue sensors
    3. Where are the O2 sensors
    4. Approx cost of new O2 sensors
    Thankyou again fellas
    Clive
    tr boy
  11. Melvok
    Jul 25, 2008
    14,292
    Mel
    #11 Melvok, Mar 21, 2011
    ?? Lambda = O 2 !
    So if you write: no lambdas, there should be no O2 sensors, am I right ?
    They vary in cost but right ones (count the cables) cost around $ 70 each imho .
    You can see the two O2 sensors here in the straight pipes.....
  12. Testarossa1
    Testarossa1 Karting
    Jun 15, 2007
    229
    Clive
    Hi Mel
    Thankyou for the info-yold ya I was a novice!!
    So no O2 sensors to check how about the blue connectors you mentioned?
    Cheers buddy
    tr boy
