Rousch Racing Premier 1A crash at Oshkosh . . . | Page 3 | FerrariChat
Discussion in 'Aviation Chat' started by robbreid, Jul 27, 2010.
  1. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    14,560
    FL
    Gotcha, thanks. ;) What's the largest jet that has flown into that show? Seems like a famous event so I'd guess some important aluminum has come through there.
  2. DMC
    DMC Formula 3
    Nov 15, 2002
    2,385
    WI/IL
    Dean
    Airbus A380 was there last year. The Dreamlifter, Super Guppy and Beluga have also been there in the past.
  3. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    #53 solofast, Jul 29, 2010
    The Antonov 225 (biggest airplane in the world) has been there and the monster Airbus is there right now, but the big planes arrive on IFR flight plans and that isn't an issue.
    They have a procedure for GA arrivals that has worked out for years and years. You fly to a checkpoint and get in line and fly nose and tail and fly into the pattern. The controllers will ask you break out and go back in line if spacing isn't ok, but you basically enter the pattern and the first guy lands long, the second one lands in the middle of the runway, and the third lands short. Rinse, repeat as many times as necessary... As soon as you are down to taxi speed you get off the runway and they keep doing it. They handle an amazing amount of traffic and it all works well, but the spacing is a lot closer than you will ever find and if you aren't sharp you will be TOLD to go around. If you are not close to the guy ahead of you they will tell you to pick it up. The controllers there are the BEST in the world and it is a huge honor to be selected to work ATC at Oshkosh.
    Aviation, as with the sea, is an environment that is unforgiving of any carelessness, incapacity or neglect... Moreso when you have that much traffic around.
  4. donv
    donv Two Time F1 World Champ
    26,340
    Portland, Oregon
    Don
    In a jet, slow flight is certainly part of the initial and recurrent training curriculum (I spent quite a few years as an instructor and check airman in various business jets), as is maneuvering at minimum speeds, and even below those speeds. The average jet guy probably gets more stall and slow flight practice than a typical 172 weekend warrior, interestingly enough. That said, there are still jet stall-spin accidents (Learjet into Groton CT a few years back, for instance).
    In a jet, you will typically calculate a reference speed, usually 1.3 x stalling speed, and you must always want to stay at that speed or above. If you are using more than 15 degrees of bank, in many jets you would add 10 knots to that speed as a minimum. Many jets also have an angle of attack indicator, which will give you a visual indication when you are approximately at 1.3 Vso.
    I have no idea about the Premier's stall characteristics, but many swept wing jets will bite hard if you get into the stall regime (others are so docile that they will just mush ahead with full roll control), so it pays to keep away from it.
  5. Jeff Kennedy
    Jeff Kennedy F1 Veteran
    Oct 16, 2007
    6,888
    Edwardsville, IL
    Jeff Kennedy
    Don't know on the Premier's engines but some jet engines are known to have discernable spool up time. Means that one has to anticipate the need for more power as it is not instantaneous.
    Jeff
  6. Gatorrari
    Gatorrari F1 World Champ
    16,530
    Georgia
    Jim Pernikoff
    Don't forget, the Concorde used to appear there!
  7. tazandjan
    39,359
    #57 tazandjan, Jul 29, 2010
    Scott- You are correct. Only 60 times too high. Too many beers when I made that post. Cruise on twin engine turbofan fighters was about 6000 lbs per hour, low level at 480 knots was 12-14,000 lbs per hour. Mach 2+ at FL40-50 in max A/B with ram effect dropped substantially to 30-60,000 lbs per hour from low level in afterburner. Could not do it too long because the aluminum airframe heated up too much, even though theoretical fuel flow was pretty good.
    Taz
    Terry Phillips
  8. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,018
    Shoreline,Washington
    Robert Parks
    A friend of mine flew DC-8's for UAL. When they were near the end of an east to west flight the flight engineer said that they would ONLY have 13,000 pounds of fuel on board when they would arrive at SFO. My friend, the pilot in command, elected to go to an alternate because SFO was getting low weather. He told me that if he had to make a missed approach there wouldn't have been enough fuel to complete a go around. I can't recall how much fuel a JT4 burns at full throttle but I do remember that the fuel lines are about 3 1/2 inches in diameter and boost is high.. I think that I remember that a JT3 will process 450 pounds of air per minute at 100% .
  9. robbreid
    robbreid Karting
    Feb 25, 2007
    167
  10. donv
    26,340
    Portland, Oregon
    Don
    After UAL ran one out of gas in PDX, I bet they became pretty conservative on their fuel reserves for a while!
  11. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    The friend that I mentioned referred to this flight before the PDX incident. He was one of those professional pilots who was always ahead of his airplane and had everything figured out on the safe side. I flew with him many times in his personal aircraft and he taught me many things while saying little. While I was flying with him IMC one day and I had the airplane he started checking his head set and I asked what the problem was he said, " Well, you must have gotten a new clearance that I didn't hear because you are 300 feet above our assigned altitude." Many little innuendos like that was his style.
  12. Blue@Heart
    Blue@Heart F1 Rookie
    Jun 20, 2006
    3,889
    Yellowknife, NWT
    David
    Harsh, but hammers home the point effectivly... :)
  13. robbreid
    robbreid Karting
    Feb 25, 2007
    167
  14. BubblesQuah
    BubblesQuah F1 World Champ
    13,256
    Charlotte
    Oh wow. :eek:
    Those guys are getting the hell outta there. The look in that guys eyes in the second and third picture...
    Too bad those pictures don't have sound.
  15. garybobileff
    garybobileff Formula 3
    Sponsor
    Feb 5, 2004
    1,181
    San Diego CA
    Gary
    Looking at the Avweb 1st photo, I don't see the flaps configured in the landing position.
    Gary Bobileff
  16. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #66 snj5, Jul 31, 2010
  17. 4re Nut
    4re Nut F1 World Champ
    Mar 27, 2004
    16,343
    N of NOLA
    Steve
    #67 4re Nut, Jul 31, 2010
    That photog in the second pic must have been an amateur; a pro would have stuck it out, dug in his feet and "got the shot". :D
    I on the other hand would have run so fast I wouldn't have been in the frame.
    P.S.
    That is a great pic for "is it real or photoshop". I bet most folks would claim photoshop given the disappearing wingtip.
  18. solofast
    solofast Formula 3
    Oct 8, 2007
    1,773
    Indianapolis
    #68 solofast, Jul 31, 2010
    Here is a shot just before impact from a different angle, the flaps are down, but that airplane doesn't have a lot of flap, or maybe he wasn't at full flaps. What is down does look pretty much the same as the stock photo of the airplane, so maybe that's all you get.
    They are also fowler flaps so there is an area increase with flap extension, so some of the low speed lift comes from that too.
    http://www.tmz.com/2010/07/28/nascar-team-owner-jack-roush-plane-crash-photographs/
  19. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    I think you are right - that's all you get.
  20. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    The stock photo shows what looks like a good 40 deg. of flaps. If they are indeed fowler flaps they not only increase wing area but form a slot to maintain attached flow. Early fowlers didn't come down at as much of an angle as simple or split flaps so that may look like there wasn't much of an extension. Russ is correct, that looks like a really thin wing.
  21. robbreid
    robbreid Karting
    Feb 25, 2007
    167
    From Flyingmag.com
    'There are, as always, tradeoffs, and the small, slender wing does add complexity. Because wing loading-the amount of weight carried by each square foot of wing area-is fundamental to stalling speed, a small wing will stall at a higher speed than a larger one. To overcome that the Premier has large Fowler flaps that occupy most of the trailing edge of the wing. The wing is of the "cranked" design, meaning that the trailing edge is straight at the root and then sweeps back to mimic the sweep of the leading edge. With a cranked wing the flaps must be segmented into inboard and outboard sections. The Premier flaps are made from composites and are electrically actuated.
    Because the flaps take up so much of the trailing edge of the wing the aileron is quite small, not large enough to provide all necessary roll control on its own. The solution for the small aileron is to augment the roll authority with spoilers. After 10 degrees of aileron travel, the spoilers on the down-going wing start to rise to provide more roll authority. This system is common in virtually all larger jets, but is rare in a light jet, and is transparent to the pilot when flying.'
  22. tazandjan
    39,359
    #72 tazandjan, Jul 31, 2010
    In high wing loading aircraft a classic stall may not occur and the aircraft may simply depart controlled flight. This is often accompanied with a roll-off or yaw, or both, in an unpredictable direction, sometimes quite violent. The usual recovery procedure is to unload and roll wings level to regain control authority and flying speed. In this case, it appears the aircraft was departed through pilot error with insufficient altitude and control authority to recover. Bad judgement overflying the aircraft into a corner of its envelope from which recovery was not possible at the pilot's level of skill. Too much bank, too much rate of descent, and too late realization of what was happening. Both occupants are lucky to be alive.
    Hero approaches are not what you want when you are not flying an aircraft frequently enough to feel everything she is trying to tell you.
    Taz
    Terry Phillips
  23. Etcetera
    Etcetera Two Time F1 World Champ
    24,361
    C6H14O5
    That's a fancy way of saying rocks don't fly!
  24. tazandjan
    39,359
    Affirmative. Having flown one for 20 years, the scenario is all too familiar. You really want to learn what an aircraft will do at altitude so when you screw up, someone can place a pillow where the rock will land.
    Taz
    Terry Phillips
  25. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    If yaw is fed into a stalling swept wing at the low end of the speed range the retreating wing " disappears" as a lifting element and the advancing wing becomes a forceful rolling moment. If the angle of attack gets high enough and speed is low, the advancing wing quits and the airplane can roll the opposite way from when it started. It appears that that is what happened in this case. Swept wings don't act like straight wings when they stall and they can bite hard just as Terry said. This is why some big multi-engined jets have huge vertical fins and powered rudders because sometimes a fatal stall and snap roll can be stopped by controlling the yaw.
