Royal Purple Oil | FerrariChat
Royal Purple Oil
Discussion in 'Technical Q&A' started by pks41805, Jan 18, 2008.
  1. pks41805
    pks41805 Formula 3
    Aug 4, 2007
    1,152
    Colorado Springs, Co
    Paul Sloan
    Is anyone familiar with the product?
  2. dm_n_stuff
    Use their oil in some of my cars, I have used it in the Dino and the Boxster. Both are gone now, so it's back to mobil 1 in the new to me 360.
  3. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    I've been using it in my BB gearbox for 7-8 years...love it.
    Also, use it in my BMW M3 gearbox...as well as my Subaru gearbox and differential.
    The BB and the BMW now shift great cold....
    The "whine" in the Suby gearbox is gone.
    Still running Mobil 1 or Castrol TWS in the engines..
    Regards,
    David
  4. texasmr2
    texasmr2 Two Time F1 World Champ
    22,232
    Houston
    Gregg
    Royal Purple is CRAP! I used it twice in my fully race-built 3SGTE and after only 2k mile's it was broken down, I was pissed especially after spending $5K on the rebuild. My friend/mechanic at the dealership confirmed my suspicion's as he said 'Dude that shi!t will ruin your engine"!!!
    When it come's to hi-po oil I either stick with old reliable Mobil1 full synthetic or Amsoil synthetic.
  5. Chicane
    Chicane F1 Rookie
    2,884
    Funkytown
    Dirk Diggler
    Which oil? I use Synchromax in the gearbox and max gear in my diff and love both, but I have to use a special racing oil in my crankcase.
  6. wetpet
    wetpet F1 World Champ
    10,210
    used it in my 328 and loved it. use motul now
  7. Llenroc
    Llenroc F1 Veteran
    5,434
    Colorado
    Vern
    If you are interested in oil performace of just about any oil made go to Bobistheoilguy.com and check out the UOA forum. It should answer all your questions on a paticular brand of oil with real world facts not personal opinions. Since I brought up personal opinions I have used Redline products for years and have always been satisfied. Haha
  8. mwr4440
    57,852
    Bavaria, The 'Other' Germany
    Mark W.R.
    I replaced the crankcase oil in my 308 GTSi toward the end of the summer I bought it. Have no idea what was in it before. It had some intermittant and minor shifting issues before the change, but after putting in Royal Purple, but now shifts like butter, even into second, when cold.
    It still has an occasional issue getting into reverse, but I am getting some new delrin shifter bushings from a fellow F-Chatter and I hope that will put the "reverse thing" to bed.
    Good Luck
  9. R33
    R33 Formula Junior
    May 7, 2005
    982
    Kent,UK
    Paul Creed
    One of our "Club" members did some extensive testing for Purple Oils some time ago. A nasty engine rebuild after the change certainly led to some more investigating....
    For what its worth i think the Redline Shockproof oils are about one of the best out there.
  10. Chicane
    Chicane F1 Rookie
    2,884
    Funkytown
    Dirk Diggler
    What would replacing the crankcase oil have to do with shifting? Did you mean you replaced the gear oil in the transmission.
  11. mwr4440
    57,852
    Mark W.R.
    DUHHHHH!?!?!?!?!.
    You are right. I replaced my transmission oil with Royal Purple. I don't use RP in the crankcase.
    Sorry. Was sound asleep on that one.
  12. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    The PO of my car put Royal Purple in the tranny and I was having 2nd gear probs esp when cold, I switched to Redline and no probs since, it made a huge difference in my car.
    Use whatever works best in your car, I guess.
  13. Llenroc
    Llenroc F1 Veteran
    5,434
    Colorado
    Vern
    I have used all the gear oils Redline makes at one time or another in probably 20 different cars, 5 of which were Ferraris. The shifting always seem to be better than what was in them in the past, but what I noticed is that the same oil might perform different in one 308 or 348 as compared another 308 or 348(using these 2 as examples) ie; shockproof in 1 308 worked fine but in the other not as good as another type of Redline. Every gearbox appears to react different(hope that made sense). Their 70-90w variants always worked the most consistant.
  14. enginefxr
    enginefxr Formula 3
    Aug 20, 2007
    1,753
    S&R Exotics
    Gary Sharpe
    I am very familiar with Royal Purple. I worked for a team and built engines for NHRA pro stock. We used Royal Purple only!! You only need to watch what type you use and the viscosity. We used 0000w oil, looked like grape kool-aid when pouring it. It contained chlorine molecules that breakdown under heat, but lubricate very well for a short period of time-- replaced the oil every two 1/4 mile runs-- and it was broken down and turned black. For a street engine you need to pick a street version of any oil you want to use, racing oils are designed for short term racing use, because cost/longevity isn't an issue. Also any racing type oil is designed for use with specific bearing clearances in the engine-- Joe Gibbs Racing Oil doesn't even list viscosity, they list their applications according to bearing clearances/intended use. Any quality, well known oil manufacturer's oil will perform fine as long as you use the viscosity recommended by Ferrari- as they're the ones that determined the engine clearances originally.
  15. CCCP
    CCCP Formula Junior
    490
    Italy
    Max
  16. OC Speed Junkie
    OC Speed Junkie Formula 3
    Aug 6, 2005
    2,473
    Southern California
    Joseph
    I have used it a few times. I noticed higher than normal oil loss with it compared to mobil one.
  17. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    I experienced the same thing in my GT4.I found it leaked more and burnt more oil this is with a recently rebuilt motor.I switched back to Castrol GTX and I am happy with it.
  18. ckracing
    ckracing Formula Junior
    May 20, 2006
    728
    Jacksonville,Florida
    Charles
    2 years ago NAPA auto parts stop selling it. They sold all the remaining stock for $1.00 a quart.
    Charles
