RPM FACE COLOR CHANGES--the whole process--LOTS of pics | Page 5 | FerrariChat
Discussion in '360/430' started by brokenarrow, Nov 30, 2007.
  1. spiderscott
    spiderscott Formula 3
    1,661
    Ratarossa HQ UK
    Ratarossa
    #101 spiderscott, Feb 21, 2011
  2. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,319
    Gibraltar
    360trev
    #102 360trev, Feb 21, 2011
    Looks excellent Scott but may I suggest you look into the EL panel mod too, so the entire rev counter gets illuminated.
    The electroluminescent panel (backlight which Ferrari used instead of conventional bulbs) that fits behind the Yellow dial plastic covers is cut slightly different on the Strad. The shape of the light cut out is different so you get a bit of an annoying shadow when illuminated which is shown on your pictures (not a problem, it doesn't stop you seeing anything you need to but just doesn't look 'perfect').
    You can actually buy an A4 piece of electroluminescent panel from ebay like beow;
    http://cgi.ebay.co.uk/EL-Lamp-electr...item35aff2f1b2
    Here's a cheaper alternative (check the size fits the width of the clocks mind before ordering!)
    http://www.rapidonline.com/Electroni...ource=googleps
    Another good source of info on EL panels...
    http://electroluminescence-inc.com/customPattern.htm
    ... And then simply cut out the panel to shape so it fit behind the dials to get full backlight working with the yellow dials. Otherwise you get some of the lighting missing if you retain the original 360 one. I've attached pictures to illustrate the problem
    The solution above is also a cheap alternative way to fix failed back lighting on the standard 360 clocks too.
    Very annoyingly Ferrari (tut tut... ) do not sell the back light panel seperately to the clocks themselves so you cannot buy just a CS backlight panel or for that matter a 360 Modena panel, you have to buy a complete dashboard clocks. This is unnacceptable really, very frustraiting and thankfully you can at least DIY fix it now !
    You can also choose different colors these days too so perhaps blue could look cool instead of the boring and now rather dated green. ?
  3. spiderscott
    1,661
    Ratarossa HQ UK
    Ratarossa
    yer agreed Trev need to update the backing light panel .... just measured the dash fce its roughly 360 mm x 170mm so im guessing im gonna need a sheet of the Electroluminescent around that size .... im on the hunt for one at a decent price :O)
  4. tazandjan
    39,021
    You can also check with FAI in California and see if they can just get a CS lighting panel for you. They stock most of the lighting panels for the 360/CS/575/F430/Strad/16M instrument panels and also provide a repair service for those panels. That way you know it will work.
    Taz
    Terry Phillips
    Franchorchamps of America, Inc.
    935 Sunset Dr Suite A
    Costa Mesa, CA 92627
    (949) 631-6373
    Rod Drew
    [email protected]
    Will White
    http://www.ferrarioc.com/
  5. pearsonhaus
    pearsonhaus Formula 3
    Jul 2, 2008
    1,464
    + 1
  6. ParkCity360Spider
    Sep 20, 2010
    155
    Park City, Ut
    Tim M
    Great pics and details. You're a great asset to this site. BTW, the Yellow looks great.
  7. burner42
    burner42 Formula Junior
    Jan 21, 2011
    624
    Dallas, Texas
    Myles
    I want to do this to my 360 dash... I think the yellow looks killer! Thanks for posting!
  8. Ky1e
    Ky1e Formula 3
    Mar 4, 2011
    1,252
    FL
    #108 Ky1e, Sep 1, 2011
    Thanks for the tips and for posting the details. Just installed as per your post (Ricambi Yellow Tach). Only tips I'd add are:
    1. Do remove both upper and lower steering column shrouds as you suggested but take your time and be careful.-- the top section has long plastic tubes that receive the screws from the bottom piece and they break easily.
    2. After you remove the top steering column shroud, put a cloth or towel over the bare column -- there are two metal tabs and they WILL scratch the silver paint of the dash face plate when you lay the dash down onto the steering column.
    3. Use the steering column tilt (up and down as well as telescope out and in) to help you gain access and make room where you need it.
    4. To help get the harnesses off, wedge a flat tip screw driver at the bottom of the harness and (gently) pry it up to get it started.
    Took 2 hours. It was my first go at dismantling/tinkering with the 360. Anyone can do it, just take your time.
    Thanks again for the post, it made my project possible.
  9. margarita
    margarita Formula 3
    Mar 20, 2011
    1,618
    usa
    hello guys where do i can buy the rpm face here in usa ,i like the one thats looks just like the cs , thankyou
  10. hmfic1
    hmfic1 Karting
    Aug 15, 2011
    165
    Scottsdale
    Jerry
    #110 hmfic1, Sep 1, 2011
  11. hmfic1
    hmfic1 Karting
    Aug 15, 2011
    165
    Scottsdale
    Jerry
    #111 hmfic1, Sep 1, 2011
  12. Ricambi America
    Sponsor Owner
  13. Eric360
    Eric360 Formula 3
    Jan 11, 2010
    1,428
    San Francisco, CA
    Eric
    Where did you get your gauge face? It looks like factory with the correct matching font style for the 360 numerals.
  14. hmfic1
    hmfic1 Karting
    Aug 15, 2011
    165
    Scottsdale
    Jerry
    There are CS style faces, from Ricambi, as I remember.
  15. margarita
    margarita Formula 3
    Mar 20, 2011
    1,618
    usa
    hello i just talk to ricambi and they told me that they dont sale the one with the horse, they have the yellow without the horse
  16. Skidkid
    Skidkid F1 Veteran
    9,493
    Campbell, CA
    John Zornes
    Correct. The horse is trademarked so no one is selling with the horse because Ferrari would decent upon them.
  17. margarita
    margarita Formula 3
    Mar 20, 2011
    1,618
    usa
    so that means that all have to buy the one without the horse?there no more options in the market
  18. Skidkid
    Skidkid F1 Veteran
    9,493
    Campbell, CA
    John Zornes
    Yes and no. I bought one without the cavalino but had a printer do an ink transfer to add it to my dial. There are otions but nothing pre-rolled that is an exact match.
  19. OceanSide760
    OceanSide760 Karting
    Jul 8, 2009
    185
    please let me know where you get the horse (decal)?
    I am planning to get it from Ricambi but I want to horse, thanks!
  20. alex360S
    alex360S Formula Junior
    Oct 30, 2006
    324
    Montreal, Quebec
    Alex
    Prosport sells the one with the horse
  21. margarita
    margarita Formula 3
    Mar 20, 2011
    1,618
    usa
    correct thanks prosport haa the one with thehorse
  22. Ky1e
    Ky1e Formula 3
    Mar 4, 2011
    1,252
    FL
    #122 Ky1e, Sep 3, 2011
    Here's mine I installed as per this threads great instructions. Exc mod-- I thoroughly enjoy it. Its something I (the driver) looks at all the time so to me it's a great mod. Goes great with the yellow cap on the steering wheel. Speaking of that... with the hose on the steering wheel one could make the argument that a horse on the tach as well is a bit overkill anyways... so to me the Ricambi one not having a horse was not an issue at all.
  23. jim94-348
    jim94-348 Formula Junior
    Aug 19, 2010
    981
    Greenville, NC
    Jim
    Does anyone have a link to Craig's post of how to initially get the console out? He mentions Craig but I don't see a link to the post.
  24. brokenarrow
    brokenarrow F1 Rookie
    Sep 25, 2006
    3,737
    Txass
    Bill
  25. samba-lee
    samba-lee Formula Junior
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
