RPM needle | FerrariChat
RPM needle
Discussion in '365 GT4 2+2/400/412' started by JMFC, Nov 21, 2016.
  1. JMFC
    JMFC Rookie
    Dec 19, 2015
    41
    The RPM needle stopped working all of a sudden.
    Any clues. How would you fix it?
  2. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,220
    Gold Coast, Aust.
    Patrick
    It means your engine is off
  3. simon klein
    simon klein Two Time F1 World Champ
    Feb 25, 2009
    29,801
    North Qld
    simon klein
    ....and this is precisely why you're a doctor.
  4. Ak Jim
    Ak Jim F1 Veteran
    9,627
    North Pole AK
    Could be that the tachometer is broken or a wire has broken or come loose.
  5. JMFC
    JMFC Rookie
    Dec 19, 2015
    41
    Thanks AK Jim.
    Any pointers to address the problem?
  6. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,465
    Canada
    Newman
    Lol
  7. Ak Jim
    Ak Jim F1 Veteran
    9,627
    North Pole AK
    Well if it was my car here is what I would do. I would start off going here Wiring Diagrams 308 365 400i 512
    and get an electronic copy of your wiring diagram. Your profile isn't filled out so not sure what car you have but they have diagrams for the 365 GT4 and 400i.
    I would then trace the wire on the diagram to see where it goes and then look for the wire in the car and see if I could visually see any thing like a loose or broken wire.
    If I didn't see any thing obvious I would take the instrument panel out and then look at the wires hooked up to the tach.
    I'd then take my dwell meter which also has a tach function and connect it to the wires on the tach in the car and then start the car.
    If my dwell meter showed an RPM reading then I would ascertain the tach was bad. If the dwell meter didn't show an rpm reading I would further investigate to wiring in the car.
    Definitely not an easy job but not impossible.
  8. aidanparte
    aidanparte Formula 3
    Jul 18, 2004
    1,231
    You could remove the instrument panel - not too tricky - to access the tachometer and disconnect it. Then rev the engine and see if the jobby is turning - I'm assuming it is mechanical!
  9. Ak Jim
    Ak Jim F1 Veteran
    9,627
    North Pole AK
    Not sure when they changed over but our cars have electronic tachs.
  10. ricar116
    ricar116 Formula Junior
    Aug 2, 2005
    409
    Bolivar, Missouri
    Rick Carr
    Mine is mechanical 1974
  11. Ak Jim
    Ak Jim F1 Veteran
    9,627
    North Pole AK
    #11 Ak Jim, Nov 22, 2016
    Interesting, must have changed for 1975.
    POS computer. I have tried posting this picture multiple times. I rotated and saved the picture in all orientations and it is still upside down.
  12. aidanparte
    Jul 18, 2004
    1,231
    It's perfect for our Australian chums.
  13. simon klein
    Feb 25, 2009
    29,801
    North Qld
    simon klein
    Yep,thanx for clearing THAT up!
  14. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    you beat me to it....
  15. bjwhite
    bjwhite F1 Rookie
    4,806
    Seattle, WA
    Brian White
    You must be a Mac user. :)
  16. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    Can't be a mac if he said POS, it can only be a PC ;)
  17. JMFC
    JMFC Rookie
    Dec 19, 2015
    41
    Thank you Ak Jim and aidanparte for your constructive inputs.
    Wishing you all a very Happy Thanksgiving!
  18. Ak Jim
    Ak Jim F1 Veteran
    9,627
    North Pole AK
    iPhone 6S and the computer is an Ailenware Area 51.
  19. Ashman
    Ashman Three Time F1 World Champ
    Sep 5, 2002
    33,271
    MA
    Southern hemisphere car? ;)
    The only hack I have for a iPhone is to copy the picture onto a word document right side up and then save the image from there. Then the image seems to attach correctly. Beats standing on my head to look at the picture! :)
