Rubber Door Window Weather Strip / Scraper: Source and HowTo? | FerrariChat
Discussion in 'Mondial' started by schelle_pelle, Jun 20, 2022.
  1. schelle_pelle
    schelle_pelle Karting
    Oct 22, 2021
    197
    Berlin, Germany
    Hi there,
    on my 3.2 the weather strip for the window in the doors is not perfect anymore and I would like to change it. It does not seem to be an overly complex rubber profile so I thought it might be a standard profile which could be sourced anywhere... Is anyone aware of a reference?
    The part would be available through Maranello and is not really expensive, but an alternative would be nice:
    60635900
    https://www.ferrariparts.co.uk/part/ferrari/60635900
    Next: How do I change the rubber? Do I have to pull the glass?!
  2. schelle_pelle
    Oct 22, 2021
    197
    Berlin, Germany
  3. ronfrohock
    ronfrohock F1 Rookie
    4,156
    MA
    Ron Frohock
  4. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,668
    Argent/Brasil
    Guido
    This part comes loose when lifting from one side with a plastic or wood dowel.
  5. Mondi Cab
    Mondi Cab Karting
    Oct 9, 2019
    170
    EU
    J.Schulz
    Hi Schelle Pelle,
    By coincidence I received a list this morning:
    Not sure if this fits your vehicle, but try this link:
    https://www.cicognaniguarnizioni.it/Ferrari-163/mondial-163-l34/guarnizione-raschiavetro-interno-bordo-inox-_set-completo_-16334933_7859
    Hope to have helped.
    Mondi Cab
  6. 350HPMondial
    350HPMondial F1 Veteran
    5,325
    Edwardo
    a Fiat part. I got some from Centerline.
    Trim to fit.
    Note; Removing the trim from the car always breaks the plastic fasteners. Replacing is tricky, I used ss lock wire , accessed from the inside of the door
    good luck
  7. schelle_pelle
    Oct 22, 2021
    197
    Berlin, Germany
    That was a good hint! I found the profile on an Alfa Spider <93. The profiles are just a bit short (77cm) on the Mondial you need 100cm.
