Run engine | FerrariChat
Run engine
Discussion in '348/355' started by arne2808, Oct 22, 2011.
  1. arne2808
    arne2808 Rookie
    Feb 1, 2011
    6
    I just Got a 348 spider, my first Ferrari. I Will not drive the car during wintertime maybe 6 month, how often do I have to start the car, or maybe not start it? There is a lot of vacum when I take of the fuelcap is that normal? Regards Arne from Denmark
  2. 348holland
    348holland Formula 3
    Dec 11, 2005
    2,202
    The Netherlands
    I use a trickle charger and start het once a month and let it idle till the vents of the radiators start. I also pump some extra air in the tires (3 bar).
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    No need to start it at all unless you will be actually getting everything hot.
  4. ghardt
    ghardt Formula 3
    Apr 18, 2004
    1,260
    Texas
    Jerry
    Lots of vacuum when removing the gas cap is normal. Many have said, "don't start the car unless you are going to drive it". Use a trickle charger with a maintenance mode. I use a trickle charger year around; you don't know when you will have time to drive her.
  5. mdsassaman
    mdsassaman Karting
    Nov 4, 2006
    246
    Reading, PA
    Mike Sassaman
    Yes there should be vacuum when opening the gas cap according to my mechanic. I found that you should not tighten the cap too much or it can be hard to get off. I found that out the hard way, now I just snug it up.
  6. BLAMPEE
    BLAMPEE Man Card Status: Never Issued
    Do you put any Stabil or fuel additive in it at the beginning of winter?
    Define "everything hot."
    I obviously have moved to a colder climate here in Nebraska and have no clue about winterizing cars as Portland didn't get very cold and I could drive all year as there was never any salt on the roads.
    I've done some thread searching in here and as always I seem to find 8 different opinions. Tim, yours matters as you work on these things and you live in chilly Minneapolis!
  7. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    If possible get those tire pads for long term storage so they don't flat spot. Or set the car up on jack stands. Once you flat spot a set of those expensive tires, you'll learn. :)
  8. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    ......as long as you have more than 12 degrees centigrades in your garage you only have to connect the charger to the battery....the smart ones all the time.......and the old ones maybe once a month or so.
    If you store the car in a cold garage you obviously have to do a lot more.........
    When the weather is nice, sunny and dry....I start the car and roll her out of the garage and let the engine run idle till the fans start....happens only a few times during winter...
    .....and I have the same kind of weather conditions as you since I live the other side of the channel.
    All the best and good luck with the car!!!!!
    //B//
  9. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #9 2NA, Oct 24, 2011
    If you insist on starting it, the very minimum for me would be to run it until the fans are cycling on and off. If you are starting from a cold-unheated garage in the dead of Winter, you will probably do more harm than just leaving it hibernating til Spring.
    Fill the tank, add StaBil, connect a Battery Tender, put a cover on, leave it alone.
    Critters trying to build a nest in the car are another possible problem. Moth Balls or Bounce dryer sheets are popular repellents (not crazy about having my car smell like paradichlorobenzene). The air cleaners (among other places) make a cozy home for mice. Of course the big risk is chewing. A cat or two might keep the rodents under control (works for me) and give you someone to talk to about not being able to drive the car for several months. ;)
