Running car without Spider capote mechanism - possible? | FerrariChat
Discussion in '360/430' started by Malakas, Apr 27, 2025 at 6:04 PM.
  1. Malakas
    Malakas Rookie
    11
    Hey everyone, I have searched and searched, and besides the awesome thread by EastMemphis about creating a removable hardtop (that was closed) I havent seen anyone mention removing the soft top and running the car like a "barchetta". Having just sold my Morgan Super 3 a car without any type of top, I would be ok with the idea of removing the spider top, all of the mechanism, and whatever hydraulics are associated.
    Im wondering if anyone has done this.... or if its possible to do without running into a million little ECU issues?
    There are some members here so knowledgeable about the systems of the car, I was hoping for some feedback.
    (and for those that wonder why.... I think the loss of weight could be huge and beyond that, I wouldnt worry about putting the top up/down all the time or a dreaded leak or failure...)
  2. Qavion
    Qavion F1 World Champ
    13,835
    Ian Riddell
    So you are not worried about the "millions" of electrical and cosmetic issues which might be caused by the car being caught out in the rain? Not to mention the cost of producing a coverplate for the removed roof cassette.
    The roof wiring may include the electric glovebox release mechanism. The one between the seats. Is the car a 360 or 430?
    The roof warning system would have to be disabled. I don't know if there is is a digital or analog signal going to the Instrument Panel from the Roof ECU (which I assume you would be removing). You may have to fool the Window ECU into thinking the roof is up. This is also tied to the Roof ECU.
  3. Malakas
    Malakas Rookie
    11
    I had my Morgan for almost 2 years and only got caught in a drizzle once. Im just careful on when it gets pulled out of the garage. There is a guy in Wisconsin, Vintage Stitch, building my 55 Chevy who is a genius with fabric / interiors... he is going to make me a "tonneau" cover of sorts that i can latch to front of dash that pulls back to the roll hoops for days when its parked outside but I dont want to put the top back up.
    My top is working fine, I was just thinking ahead to "if" it has issues, why have it all? Perhaps the title of my post was a little off - I dont want to remove the entire "cassette" just the folding top components.
    Great points about the ECUs - I want to research all of this in advance to see if this idea is even feasible!
  4. iheartf430s
    iheartf430s Karting
    Feb 17, 2023
    202
    TN
    Ed
    I dont think it a terrible idea. But I'd be super worried about resell value.
  5. priericky128
    priericky128 Formula Junior
    613
    St. Louis MO
    Rick
    It’s been a while since I’ve been deep in the back part of the top mechanism but I think your issue would be fixing it down. Not saying it’s not possible but it would require some metal fab I think.
    you might be able to trick the ecu by leaving the micro switches in the car and bending them to the correct “open” state but I’d be more worried about fixing the capote cover. I also wonder about weight distribution but maybe that’s alright. I’m an accountant not an engineer.
    interesting idea but I think you’d be better served to just open it and leave it there (assuming you don’t care about your top fabric getting creased or worn).
  6. DiSomma6
    DiSomma6 Karting
    Nov 27, 2023
    136
    Erik
    I have been using mine manually. It takes 1-2 minutes total to fully retract and open. Drain the fluid and unplug the capote ECU on the driver's side. Now, it's 100% reliable and no need for any stalls or jams. You will get a few capote failure beeps upon starting the car, but it shuts off in about 10 seconds. No warnings, no worries.
  7. boba fett
    boba fett Formula 3
    1,038
    England UK
    I think the OP is more interested in the weight saving. From memory I think all the hood and associated parts are pretty heavy so you would see the effects of this weight loss.
    Any ECU gremlins could be just coded out.
  8. CoreyNJ
    CoreyNJ Formula 3
    2,367
    New Jersey Shore
    Usually, when you want weight savings in a convertible, you buy the coupe.
    066/8, Racer_X and houtie123 like this.
  9. boba fett
    boba fett Formula 3
    1,038
    England UK
    Oh right and then, what cut the roof off?
  10. CoreyNJ
    CoreyNJ Formula 3
    2,367
    New Jersey Shore
    Leave the roof for rigidity and strip out the entire interior... and add a drink button for that race car feel...
    Malakas likes this.
  11. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,825
    Memphis, TN
    I looked into removing the entire capote mechanism, leaving the tub, capote lid and the flaps intact. The actuators (hydraulic ram now) would have to be replaced with linear actuators and the ECU would probably have to remain with the proper contacts closed. That's it though. The hinges for the lid have a built in locking mechanism. I'd leave the microswitches for the capote lid functional so there would be an indication that the capote lid isn't secured. The capote area where the top was stored would make for a dandy "trunk" storage area. I think a few golf clubs could be stored there for fun.
    Overall, a very doable process that would be reversible. The 360 was designed first as a Spider, and then they added a roof, so there's no stiffness penalty for the Spider. The capote adds nothing to that either, except about 100 kilos. So that weight would be gone. Figure like an increase of 20 to 30 hp for the loss in car weight.
  12. GogglesPisano
    GogglesPisano F1 Rookie
    2,956
    East Bay, California
    Joe
    I think as long as the right microswitches are switched (or not switched) and placed off to the side, there shouldn't be an issue. It's not like the car knows you have a mechanism there, it's just looking for the right combo of switches to be activated. Easiest way would be to keep the harness intact and bundled out of the way.
  13. hessank
    hessank Formula 3
    1,873
    Canada, Florida
    Fred
    If it wasn't for the weight savings I would have suggested the Op put the top down (since it works) and leave it down.
    I put mine down in the spring and put it up for the winter hibernation period 7 months later. If I'm out and about and worried about rain I put the windows up and leave it covered with a 'Smart Car' cover (sort of a half size car cover over the top half). Been working it like this for 4 years now. No need to operate the top just to park it in a secure garage.
    EastMemphis likes this.
  14. boba fett
    boba fett Formula 3
    1,038
    England UK
    I would do this all day if I was not told leaving the top down is a bad thing from the specialist.
    Malakas likes this.
  15. GogglesPisano
    2,956
    Joe
    I
    It’s only bad if you don’t want creases :D
  16. hessank
    hessank Formula 3
    1,873
    Canada, Florida
    Fred
    I bought mine with creases but because I mostly drive it with the top down that does not bother me.
    In the summer when it gets really, really hot I put on the AC. Yes, I know that's probably bad for the enviro ;)
    ..... and to those offended, I already gave at the office
  17. Malakas
    Malakas Rookie
    11
    I hear you, but I wanted a driver... not too worried about selling it later... rather, more interested in enjoying it the way I want to. ;)
    Can you comment on how you operate it manually?? Did you remove the hydraulics?
    YES - THIS! I even though the linear actuators could be on a separate FOB so you could open / close as your walking to/from the car. @EastMemphis is the man. You guys need to see his thread about the hardtop. Super cool.
    So... I was told leaving it down for extended periods of time is bad because it strains the elastic straps....
  18. Malakas
    Malakas Rookie
    11
    great idea....!
  19. hessank
    hessank Formula 3
    1,873
    Canada, Florida
    Fred
    Never heard of this before. I replaced most of my straps 5 years ago (Summer, elastic straps, needle, thread and lots of beer) and is using the mod from @LorenzoR for the main bar. Works like a charm.
  20. DiSomma6
    DiSomma6 Karting
    Nov 27, 2023
    136
    Erik
    @Malakas No, I didn't remove the hydraulics. I just use the manual lock at the top of the windshield to unlock the top then fold it back. When I do that, the rear portion of the soft top automatically lifts up and allows access to the capote cover. I pop the engine cover to give me leverage to lift up slightly on the rear of the hard cover, then I close the engine cover, lift up on the capote cover to open it fully (now that I can get my fingers underneath it) and fold the top back and down into the tub. Then just slide the capote cover in place and you're in business. The only drawback has to do with the small cosmetic covers that are motor controlled. Those stay open. After a year and a half, nobody noticed them but it bothers me so I may connect a switch directly to the fuse box that allows me to remotely control that.
    It sounds like a ton of work but in reality it's 45 seconds and it's 100% reliable. I drive my car daily so I like the reliability of a manual top in a 24 year old car. I originally intended on fixing it but I have a bent piece in the drivers side linkage and I haven't been able to find it to replace. There was one on eBay but it sold quickly and nobody else has it. So, until then, it's manual lol.
  21. EastMemphis
    May 25, 2019
    1,825
    Memphis, TN
    @DiSomma6 - how do you lock the Capote cover?
  22. hessank
    hessank Formula 3
    1,873
    Canada, Florida
    Fred
    I posted this in another thread. not sure how you are doing it safely (for the car) by your self
    Mel Spillman likes this.
